Question about La Marzocco Linea Series Group 3 Espresso Machine Espresso Machine
The machine rattes aggresivly whenever the boiler re-fills itself with cod water
    President:
  • 1,618 Answers
The inlet solenoid needs to be replaced, it is on its way out.
Posted on Jan 25, 2010
Sir, LA CIMBALI 39 DOASTAROM 3 GROUP MACHINE MOTHER BOARD BROKEN Sir, We try to install the new mother board, most of the things are working, the boiler is heating up, but when we turned on the...
hi. Im not sure excactly what is going on with your explaination about your machine, but I gather the the original mother board has died, and you have replaced it with a new one. It sounds like you have a water fill issue with your machine. If the boiler doesn't have enough water in it, then the pc board will shut the machine down. Ive never worked on a m39, but they are from the Faema corporation, and Faema/ La Cimbali electronics canbe very complicated. Dont now why they make such complicated electrics, cause there are hundreds of other brands with simple electrics.
If your boiler was empty, then the water fill cycle might be a timed cycle, and is shuting down before the water level has reached the water level probe inside the boiler. If this is the case, then once it has stopped, turn the machine off, wait 10sec, then turn it back on again and let it start the fill cycle over. You may have to repeat this a number of times until it has reached the water level probe inside the boiler. Some machines are designed to have a slow water fill, because when you draw hot water from the boiler for making tea, fresh cold water is pumped back into the boiler to replace what you have taken out, and if it fills too quick, then your steam pressure drops. So by filling slower, the machine will maintain its steam pressure. Good idea in theroy, but its only good for cafes that do 300 coffees per hour.
Im hoping that your machine is configered this way, cause it will probably just have to be turned on a few times until it has reached the water level probe as I explined in the begining. If you have a sight glass, you can check to see how high your water level is. If your level is correct, and its still not working right, then id recomend calling a repairer. There are number of things that could be wrong, causing your board to die. Faulty solenoids. switches, touch pads, pressure switches can cause main board issues. Hope all this helps with getting your machine working properly. Dazza Repairer
Oct 23, 2011 | Espresso RMI La Cimbali Espresso Machine
My Rancilio Epoca ST1 would not turn on yesterday so I unplugged the machine and plugged it back in and it started right up. Today I turned the machine on and it warmed and pressured up as usual and then...
That's a tough one, the only thing I can think of is checking the reset switch and the element with an ohms meter to see if they are functioning correctly, before moving on. The only reason the machine would turn itself off, would be lack of water in the main boiler and if it does not know there is water in the reservoir, or it cannot take water from the reservoir to fill the boiler, or the element is overheating so *** trips the reset.
Jul 12, 2011 | Rancilio Epoca ST-1 Espresso Machine
My shaerer expresso machine (ambiente) is giving error, level steam probe, when this happens it will not steam. This problem does not happen all the time and can be cleared by shuting machine off then...
"level steam probe" occurs when it takes more than two minutes to fill the water in the steam boiler. The easiest solution is low water pressure to the machine. Does it have a water filter? replacing it will probably help. Other problems could be the fill valve is not opening fully and or scaled water lines going to the steam boiler. The first thing I would do is activate the hot water tap and look at the pressure. If the water is coming out slow then I know its a restriction to the machine.
Nov 10, 2010 | Schaerer Siena Espresso Machine
Am unable to prime water pump
Water is not being drawn from reservoir into boiler. The valve at the base of the boiler seems to function properly. After repeated attempts, I am unable to prime pump and fill boiler with water.
Dec 24, 2009 | Saeco Vienna SuperAutomatica Coffee...
The auto fill led light flashes and the boiler shuts down. after about 15 min and doing nothing to the machine it restarts itself and works fine. it does this 2 to 3 times a day
The machine cannot get water in a timely manner, check the water filter is there is one on the unit it may be time to replace it, and second check the level probe it may need to be cleaned also.
Oct 07, 2009 | Nuova Simonelli Mac 2000 Espresso Machine
Push ok to start boiler
Try opening the steam valve before pressing ok.
This will let water into the boiler before the heat element comes on.
Apr 23, 2009 | Saeco Incanto Classic Espresso Machine
Nuova Simonelli Mac 2000 - Boiler continues to fill up
I had the same problem of the boiler filling up all the way with water and the water was coming out of every hole in the machine. Turn the machine off, drain the boiler completely,
MAKE SURE VALVE #2 is CLOSED, this is the one under the drip pan all the way to the left. Turn on the water supply to the system and turn the system ON. The cup warmer on top will come on and stay on for anywhere between 10 to 20 minutes..... let it be,,, do not turn it OFF,, it will go off automatically. That should do it!
Hratch
Jan 21, 2009 | Nuova Simonelli Mac 2000 Espresso Machine
Saeco Primea Cappuccino Ring--stuck on "boiler filling" mode!
Hello, I had the same problem, therefore the machine has gone to a repair centre. The problem is caused by a mechanical switch in the machine, that doesn't work properly. To repair it you've to open the machine completely, but that’s not easy. Because there is nothing broken you’ll should have warranty because it is a production failure. The solution in my case was to heat up the switch and push it a little together so that the contact works properly. It is the switch that you hear when you turn on the machine.
Oct 29, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
How to clean bar 14
Cleaning the calcium carbonate accumulated inside the boiler.Put only 200 ml of water in the water tank then add a 100 grams of citric acid cristals.Do not use coffee holder and open the machine and wait the heater ready lamp .Start the pump .Collect the pumpes acidic water in a cup.When the cup is filled stop the pump and recyle the water collected in the cup to water tank.Ater repeating this recycling 2 -4 times all crystals will be dissolved and the boiler will be filled with this weak acid solution.Wait the machine closed 2 hours.Then put fresh water and run the pump and remove the solution.Now your machine is free of scales inside the boiler. You will notice less noise during boiling of water inside the boiler(not pump noise).After some usage if you notice again that high noise of water boling it is time for another cleaning.
Oct 22, 2008 | DeLonghi BAR 14 Espresso Machine
Water leaking into machine
This happens when the boiler develops a leak, usually due to scale buildup. Order a new boiler and o-rings and replace.
Sep 29, 2007 | Saeco Magic De Luxe Espresso Machine
Open Questions:
Coffee Makers & Espresso Machines Logo
102 people viewed this question
Top La Marzocco Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Goldsmith
Jim Goldsmith
steve morris
steve morris
Are you a La Marzocco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
