Question about Samsung TXN2798HF 27" TV
Problem for Samsung TXN2798HF 27" TV Shuts off by itself after about 15 minutes. Sometimes longer sometimes shorter. Don't know much about the inner working of a television but I am pretty handy at fixing almost anything(never tried a tv). Is this something I can fix myself?
  • Samsung Master
  • 610 Answers
The power supply board is failing and needs replacing.replacing board is the easiest thing to do, lay tv down on a soft blanket(screen down), remove back cover and you will see the board. 4 screws and a couple of connectors and it is done. call 1-800-samsung to find the closest service/parts center to order board.
Posted on Nov 18, 2009
Testimonial: "Thanks a bunch! Samsung said the part was discontinued so I just fixed what I thought was a faulty solder and its been workin ever since. Thanks!"
Flat panel TV comes on by it's self
It sounds that the voltage output from its internal power regulator board is not proper. Check it.
Feb 04, 2013 | Samsung UN19D4003 TV
I have a Samsung led, high definition (1080i) bvd, srs tv, after about 10 or 15 minutes the screen goes blank but you can still hear the sound, if you turn it off and on it will work for around 15 minutes...
Hi, i have the same problem but not always at 15 minutes, sometime longer and sometime shorter. However it is the same symptom. I put a table fan right at the lower back of the TV and blow it upward at about 45 degree to make sure the air blow inside of the TV as much as possible. I used this way for a month and haven't had any black out problem. The only thing that you have to live with is your fan's noice. Good luck to your.
Jul 19, 2010 | Samsung Televison & Video
looseconnections on power supl.board.
Jul 10, 2009 | Samsung TXN2798HF 27" TV
WHITE horizontal lines across screen
You need to adjust Screen voltage (decease a bit) to disappear white lines on TV. If you want to do it yourself, let me know to help you further.
Regards,
Aug 13, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Magnavox MS3252S431
Replace:
Q7461 C33725
O7463 C32725
C2455 47uF@50V
May 23, 2008 | Proton MM2701VT 27" TV
Magnavox MS3252S431
Replace:
Q7461 33725
Q7463 32725
C2455 47uF@50V
May 22, 2008 | Proton MM2701VT 27" TV
Problem with tv turning off by itself.
I had a friend with the same problem. He had to clean the components and fans in the set. The accumulated dust had caused the set to run hot and a safety switch was the tv off. He purchased a few cans of compressed air and, as he blew the components and fans out, used a vacuum to capture the blown dust. Good luck.
Dec 27, 2007 | Samsung HL-S4266W 42" HDTV
Samsung TXN2798HF 27" TV Logo
62 people viewed this question
Jerry Greenberg
Jerry Greenberg
