Question about Insignia IS-PDVD10 Portable DVD Player
No disc When i put dvd in it will say loading and then come back NO DISC. but will pay music cd just fine.
  • 1 more comment
  • rb11811390 Apr 12, 2008
    I have the same problem,I have cleaned the pick up head and check the disk,
    unit has worked for 1yr with no problem!
    Help!!
  • ja10 Apr 20, 2008
    when i put a disc, it will say loading then no disc..cd and video will not play..my portbale dvd is less than one year.
  • ja10 Apr 20, 2008
    the player will just load then ill say no disc. its less than one year..
    Novelist:
  • 170 Answers
The optical lens is out of alignment. This is why it will read CDs which have much larger data pits that DVDs.
The unit should be able to read and playback CDs (both production and burned) and DVDs (both production and burned). If the optics are out of alignment and exceed their tolerances, the player will not read discs.
This is caused fromt he player being dropped or jarred.
This is not an easy fix for the home user. This is something that a qualified professional needs to correct.
Posted on Apr 17, 2008
2 Suggested Answers
SOURCE: INSIGNIA NS-PDVD10 Problem
I have a NS-PDVD8 . I purchased DEC 2006. I used it in April 2007 and then again in Jan.2008. When I went TO use March -2008 I received message NO DISCwhen attempting to play DVD.i messed with for an hour by rebooting and and dusting with compressed air.No help
next day I tried a CD and after very long loading time played music.
after I let it run for an hour I attempted DVD but same response.NO DISC
I cleaned the optical lens with a damp soft cloth and dried with soft cloth ( I do not recommend using a cloth but I was fed up and needed the player for flight next day) I believe you can purchase a cleaner kit.
I also ran the lens back and forth 5 or 6 times to make sure it could move fully along track.I heard clicking and wondered if this was ever going to run again.
I tried a CD first and the Cd loaded almost immediately and played
Next I tried a DVD and loaded successfully and played entire movie.
I turnred on and off about 10 times and reloaded movie without any problem.
Posted on Mar 27, 2008
WILL NOT PLAY A DISC
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Apr 03, 2009 | Mintek MDP-1770 Portable DVD Player
Disc does not spin and shows on screen that there is no disc
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Mar 29, 2009 | Mintek MDP-1810 Portable DVD Player
Ps2 slim not reading discs
You can buy new DVD pickups online for about 15-20 It will take a very small phillips screwdriver and needlenose pliers to change out the old one
Mar 22, 2009 | Sony PlayStation 2 Slimline Console
Screen says "no disc" when there is a disc
has it ever spun and do music cd's work cheack the regon number on the dvds and the player
Jan 24, 2009 | TruTech PVS12701 Portable DVD Player
Dvd player refuses to read any disc I load into the machine
Hello I was looking to try and help you with your DVD player, we will start by loading a music cd store purchased, no burned cds please, if the cd loads and plays then your dvd player is either out of adjustment or going bad, most dvd players, i have worked on, will load and play a music cd, but will show loading errors when trying DVD's. If the music cd dosen't load then there could be an issue with the drive or tray. If the music cd plays just fine, then your laser is either out of adjustment or going bad. You can call the manufacuter to see if there is a process for resetting the DVD player, not all DVD players have this option, if resetting the DVD player dosen't work, but music cd's do then your laser lens is dirty or going bad. At this point you have three options 1) Take it to a repair shop, 2) Get an new one, 3) Get your hands dirty if your really handy and know what your doing to clean and replace the laser. I hope I can be of further assitance and I look forward to helping in the future, Thank You and have a nice day.
Jan 14, 2009 | Televison & Video
Won't load disc
Not sure exactly what happened, but the unit works beautifully now. Perhaps cleaning did the trick? spinning definitely got it to work manually. After sitting an hour or 2, I tried it and all worked fine, CD's and DVD's too.
Jun 12, 2008 | Coby TF-DVD7005 Portable DVD Player
My tv dvd combi 21pt6820/05
These units use a belt for the loading mechanism. If the belt slips at all, the loading will not complete and lock. This will prevent the unit from reading the disc. Try loading a music CD. If hte CD plays ok, then the optics assembly is in need of at least a cleaning or replacement.
Dan
Apr 16, 2008 | Philips 27DV60S 27 in. TV/DVD Combo
Jan 23, 2008 | Insignia IS-PDVD10 Portable DVD Player
I have a problem regarding my D1816 dvd player
Put in an audio cd and see if it will play music. If it does, you may be able to get a dvd/cd cleaner and run it to clean off a possible dirty lens.
Aug 16, 2007 | GPX D1816 DVD Player
Insignia IS-PDVD10 Portable DVD Player Logo
208 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
