Question about Cornea CT 1810 18.1" Flat Panel LCD Monitor
Cornea 1810 monitor power cord
I have a Cornea 1810 monitor (actually two) the original power cord went bad on one of them, I ordered and used one from 12vadapters.com, within the 90 day warranty period the new cord failed. they replaced at no charged but now after the warranty expired the second cord from 12v failed. where can i get a more dependable cord or is that really the problem
  • 748 Answers
Apparently the monitor's power consumption is near or slightly exceeds the specified value.
My suggestion would be to purchase an adapter with higher rated output current - if for example your original adapter was rated 12V 4.5A, go for a 12V 6A rated adapter. A 30% safety overhead will hopefully contribute to higher reliability.
Posted on Nov 18, 2009
Testimonial: "thanks, my concern is the feed to the monitor,I had this monitor at home with no problem, also 2nd one no problem, had new tower, could it be that"
Where can i find a power cord for a Cornea CT1700? I live in Greensboro, North Carolina
josdcabr, do you need only the cord or the "black-brick" switch-mode-power-supply" 12vdc @ 3.5 amps rating. You might try unitedsale. com in Valley Stream N. Y. 12fixlouie
Aug 10, 2010 | Cornea CT 1700 17" Flat Panel LCD Monitor
Green power light comes on then flashing orange
You need to try it on another PC and also check the VGA cable, if it still does not work, then you will need to open it up if you are going to DIY repair, please read below and look at the pictures so you will know what to look for inside.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
May 07, 2010 | Cornea CT 1810 18.1" Flat Panel LCD...
I need Cornea 15'' Monitor MP503 manual
Hello! Well, it's like looking for the holy grail. I use diplodocs.com to find a lot of user manuals. There are 4 Cornea user guides--from the 1701 to the 1904--no mp503. The main site for your monitor is corneasystems.com. NO contact info at all...try an 800 number search--might well strike pay dirt. Don't look on the web...actually call the 800-555-1212 number and have an operator do the search--I've experienced "no joy" too many times!--Good luck!---Rick
Sep 21, 2009 | Computers & Internet
Need to know amprage and polarity
According to several sites this monitor needs a 12-volt 4-amp adapter. Virtually every laptop that uses a coaxial power plug has the center pin positive and the outside shell ground. A Google search for "ct1810 replacement adapter" turned up several sources. Here's an eBay auction currently running for one vendor. If you're outside the US you should be able to find a suitable replacement on the Internet or perhaps locally.
Apr 27, 2009 | Computers & Internet
Cornea CT1700 monitor has no power.
i think that is not monitor problem, that is your computer (cpu) problem.plase chack your ram memory,open your cpu door and remove your ram and clean it with cloth and restore back.your problem will be solve thank you.
Dec 22, 2008 | Cornea CT 1700 17" Flat Panel LCD Monitor
Polarity for power supply for cornea mp 704 lcd monitor
There may be a virtually invisible polarity symbol on the case next to the connector.
Apr 20, 2017 | Cornea MP 704 17" Flat Panel LCD Monitor
Power Supply for Cornea CT1700 LCD Monitor?
cornea lcd monitor, Monitors Projectors, Computers Networking items on ... Power Supply Adapter Cornea CT1700 LCD Monitor (12V 5A) $18.99: 12vAdapters Dot Com ... Items that are listed in a currency other than U.S.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Cornea CT 1700 17" Flat Panel LCD Monitor
Power supply
Bs more specific with your problem.
Jun 23, 2007 | Cornea CT 1810 18.1" Flat Panel LCD...
Cornea Monitor Troubleshooting CT1700
it could be something as simple as your power settings in control panel> power options, then the first window called power schemes pops up and all monitor, harddisk and system standby should be set at never. Also check on you monitor menu for any power saving options and turn them off. If the monitors still turn off then there has to be a deeper fault with the monitors and not with the power options.
Apr 28, 2007 | Cornea CT 1700 17" Flat Panel LCD Monitor
Cornea CT 1810 18.1" Flat Panel LCD Monitor Logo
228 people viewed this question
Top Cornea Computers & Internet Experts
David Payne
David Payne
Are you a Cornea Computer and Internet Expert? Answer questions, earn points and help others
