Question about GPX D1816 DVD Player
Color dvd's will only play in black and white on tv screen even though the dvds are colorized.
  • Debbie6637 Jan 10, 2008
    Thanks for the help. Everything is ok now. How do I get a manual so I don't have to bug you guys again?
    Thanks again
  • Anonymous Mar 27, 2014
    hooked player up to other TV and now DVDs have no color
  • 589 Answers
It could be a result of wrong broadcast system matching between the player and the TV set.
Press PAL/NTSC button in STOP mode to switch the broadcast system between PAL and NTSC.
Do you have the manual?
Posted on Jan 10, 2008
  • brian c
    brian c Jan 10, 2008
    It can be downloaded here:
    http://www.gpx.com/supp_dnld.php?&co...
    Choose "dvd / home theater" as the category.
    Choose the model (the d1816SIL is the closest match).
    You can either view it (its an abode pdf file), or download it and print it.
    Good luck, and thanks for the rating!
Will only play DVDs in Black and White
Onkyo DV-CP706B 6-Disc DVD Player (Black) - Amazon.com
www.amazon.com/Onkyo...Player-Black/.../B001AMS...
Amazon.com, Inc.Color: BlackChange .... It's quieter than it was before, and it plays ALL DVDs, even if you can see some visible damage ..... THere was no color-just black & white.
Onkyo dvd player no color only black white Questions ...
www.fixya.com > Forum > Tags > dvd player no color only black white
Onkyo dvd player no color only black white related problems. Ask your Onkyo dvd player no color only black white questions. Get free help, advice & support ...
Onkyo dvd player plays black white Questions & Answer
Dec 29, 2015 | Onkyo Dr-s2.2 5.1 Dvd Home Theater...
Cant get DVD to play how do I hook it to my TV
depends on the tv and dvd player. old dvds you plug in the cable with three colors. red white and yellow to the tv input of the same color. now a days dvds and flat screens use the hdmi cable.
Dec 04, 2013 | Audio Players & Recorders
Why GE TV plays color DVD/VCR tapes in black and white
Some inputs on tvs won't process the color signal. Try one of the other inputs. Mine does the same. If u have already used the working ones on something else, U will need a switch to select one or the other available at Radio Shack if u can find one.
Jan 22, 2018 | GE Televison & Video
Koss dvd player kd305a plays black and white.
Check the av channel on the tv,the av is normaly av2,if it say`s any different then press the av button on the tv r/c until it plays in colour
Oct 15, 2009 | Televison & Video
Bose lifestyle 48 dvd black and white only
Go to the "Bose" menu screen viewing on your TV (make sure no dvd is in the player) Go to your Video controls and check your output, chances are, if your using the component output your player is set to "S-Video". Should fix the problem. Hope this helps. If it's still not viewing correctly, post a comment and I will help you some more
Jul 26, 2009 | Bose Lifestyle 48 System
DVDs all play in Black & White
Could be because it is set to NTSC. Needs to be set to Pal.
Mar 27, 2009 | Panasonic Televison & Video
Only black and white
If you are playing different region dvds, they can be of different color formats also
(US = NTSC, Europe = PAL). If your television is not multi-format then non-compatible
DVDs will play black and white. The solution is to purchase a mutli-format TV (accepts
both PAL and NTSC formats)
Aug 31, 2008 | Sony DVP-NS50P DVD Player
Color to black and white and back again
Since you're using a composite cable (yellow RCA) that carries both luma (brightness) and chroma (color) information, it's not the cable that is the problem.
That means it's either the DVD player itself, or the TV. If you have another video device (VCR, etc) that you can connect to the TV, try that. If the other device also goes from color to black and white, then it's your TV. Otherwise the problem is your DVD player.
Since your TV only has mono audio (white RCA, but no red) I would recommend getting a new TV if the TV is to blame.
Jun 13, 2008 | Sony DVP-NS57P
Go Video Playback Problem
Have you checked the NTSC/PAL setting of your DVD?
Feb 25, 2008 | Curtis DVD8017 Portable DVD Player
Toshiba MW27F51
It is not clear whether one DVD or all DVDs play in black and white. If it is only one make sure that the format of the DVD is correct. If it is all DVDs, given that the VHS tape and cable play with color, there could be a problem with the chroma circuit in the unit. This is probably something that a technician would need to diagnose. Good luck.
Jun 30, 2006 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
GPX D1816 DVD Player Logo
153 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
