Question about Cell Phones
The key on the outside of my phone cannot be locked and everytime it is in my pocket it takes lovely photos of the inside of said pocket. is there anyway to disable this key?
Our schlage lock with thumbturn on inside and keyed on outside. inside lock position AND outside keyhole are sideways. is this normal??
I've never seen a lock like that was intended to be that way, but have made that mistake when the shaft that goes through the bolt portion of the deadbolt is square and is 90 degrees off in the square hole it goes through. If so remove two screws on the inside and take out assembly with the key hole, position key hole bottom, then put key side assembly with shaft through bolt portion of lock. Test the key to see if it locks and unlocks, maybe you need to position shaft 90 degrees to left or right to work, then put cover on inside house and the two screws.
May 19, 2016 | Schlage Locks & Locksmithing
I have a 1988 420sel Mercedes Benz and the alarm goes off when I open the door..place help me
When you open it from the outside? If this is the case, try putting your key in the drivers door and turning it, whether it is locked or not. I have seen many people who keep their key fob in their pocket have all kinds of issues. So, don't keep your key fob in your pocket. If it is doing it from the inside after driving, that's a different story. It all depends on the specific conditions, if you would like to elaborate.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kim_3202917d7c587455
May 08, 2016 | Mercedes-Benz Cars & Trucks
What is the problem of lock key
Its a wake lock issue.
phone wakes with a random delay everytime u press power button..
Aug 07, 2013 | Samsung GT-S5300 Galaxy Pocket
Rebel xsi review time doesn't show
Let the camera in the zip bag reach the same cold temperature outside before you take a picture. You may need to warm the battery in your hands/pocket for the battery to operating temperature.
After you have taken your photos, place the camera back in the zip bag so when you return inside a warm house you won't get condensation on the camera/lens. You need to let the camera reach room temperature before you take photos inside the house.
Jan 30, 2013 | Canon Digital Rebel XSi Digital Camera
My Lg Neon's Screen is crack on the inside PLEASE HELP!
I had the same problem. Take it to a local cell phone repair shop. They can order you another LCD Screen and you will be back up and running!! note: do not keep your phone in your pocket!! Please use a phone case and purchase the LG Neon LCD protector!
Oct 08, 2009 | LG Neon GT365 Cell Phone
Kaypad lock won't go away.
If you are not able to unlock you mobile with the unlock key press. Try this trick
Just dial the emergency number when the phone keypad is locked.
Dial 911 or 911 it will start dialing. Then you can cancel the call and you will find your keypad unlocked.
Don't forget to give feedback
Aug 30, 2009 | Kyocera Strobe K612B Cellular Phone
2007 vw passat 2.0 tdi Boot lid open itself
My Passat did the same thing for a while. Where do you carry your keys? My key was activating in my pocket over a long range and popping my trunk open. If that isn't a possibility, you can simply lock the truck in via the control switches over the speaker. Just turn the key to locked. Try that if nothing else, just remember to unlock it when you need to us the trunk :)
Jun 14, 2009 | 2007 Volkswagen Passat Sedan
The outside camera on my phone always comes on in my pocket. How can I put my outside camera on lock and still use my camera while my phone is flipped open??
this might work it did it to mine 2, the camera button on the side might be jammed. try to unjam it. another problem is that it might be to sensitive
May 28, 2009 | Verizon Communications LG VX8350 Cell...
Keyguard
if you just need to lock the phone temporarily just hold the pound button for about 3 seconds and it will turn on key guard without changing settings.
Sep 19, 2008 | LG enV VX9900 Cellular Phone
EnV2 keyguard
I just called Verizon about the keyguard being too easy to unlock and they were clueless. But here's a solution: As above, using the OUTSIDE keypad, click OK, go down to keyguard settings (number 6), then hit unlock options (number 2). This gives you the option of using a one step unlock process (hitting the OK key) or a two step (hitting the OK then the Clear). I think it is still too easy to accidently answer the phone but at least this will cut down on the dialing.
Jun 22, 2008 | LG enV VX9900 Cellular Phone
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
