Question about Coleman Powermate Powermate 5000W Generator
Coleman Pressure Washer gets no pressure even when running.
    Problem Solver:
  • 4 Answers
It sounds like your pressure regulator or back flow preventer is stuck closed either by corrosion or trash . Try tapping it and see it will open. If this does not work you can try rebuilding or replacing it.
Posted on Nov 25, 2009
I need to know where to put detergent in the pressure washer I have no model number
These units come with a detergent bottle that attaches to the spray wand. The manual describes what detergents to use and the attachment reduces the pressure and siphons the right amount of detergent from the container. It is not a good idea to try to run detergent through the pump.
Here is a link to the operating manual for a similar pressure washer.
http://www.ppe-pressure-washer-parts.com/files/1961581/uploaded/pw0501400.pdf.
Mar 05, 2015 | Coleman Powermate DuraBuilt 1400 PSI...
Where can I purchase a pressure hose for a Durabuilt Model DB1303 washer - 1300 psi 1.6 gpm?
Well I don't know where you can get the exact hose but in my area there are company's who specialize in Hose's.
the place I buy mine is called EVCO . House of hose. Try looking them up .
They should be able to get you up and running in now time.
Feb 22, 2011 | Coleman Powermate DuraBuilt 1400 PSI...
I have the Coleman powermate 2400 PSI pressure washer and on initial start it sprays and has great pressure. But once I release the spray handle it will not spray again, not even one drop of water. I have...
Sounds like the valve in the handle is sticking closed. May have a broken spring, or maybe a part is stuck..
I say take it apart, and the answer will present itself.. Play with it with nozzle out too... Maybe something is stuck after storing so long and will loosen up.. Fingers crossed
Oct 22, 2009 | Coleman Garden
Coleman 1600 pressure washer
Remove spray tip and clean with a paper clip, Check pump oil resevior and add 10w 30 pump oil if needed, also look for turn knob ,usually black with -+[plus /minus symbols ] and turn towards plus for extra pressure. May need new pistol/wand assembly and make sure hose is clear by seeing if water will run through hose freely and generously.
Thanks Kf1013 and please vote me a Fix Ya!!!
JJ505
Apr 13, 2009 | Coleman Pressure Washer PW0881800
Lance
Here is a link where you can look up your exact model and replacement parts from coleman...
http://www.ppe-pressure-washer-parts.com/coleman-powermate-pressure-washer-parts
Looks like your model may be out of production though so here's a generic kit that will 99% work with your washer...
http://www.silverbin.com/FAIP-PowerWasher-Universal-Pressure-Washer-Gutter/A/B000EEQ9KM.htm
Hope that helps...
Feb 09, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Coleman Pressure Washer Problem
your pressure relief valve is stuck open. i know that may sound too simple but it depends on if you use a cleaner with the water when your using it , not flushing with clean water after use can cause the housing of the aluminum housing of the relief valve to corrode. the valve can't move back and forth as it should because the o ring won't slide.
Jun 20, 2008 | Karcher 2500 PSI Pressure Washer
Coleman Powermate Powermate 5000W Generator Logo
418 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
