Question about Whirlpool Dryers
Dryer stops after after a few mintues
Dryer stops after running for a few minutes. the timer continues to run,but the dryer will restart for varying amounts of time
    Guru:
  • 1,738 Answers
Your safety sensor is bad.
Posted on Nov 19, 2009
Dryer runs 20 mins, stops, must be restarted over and over. run time becomes less and less after each restart.
check thermal switch on back of dryer,join wires together(tape with electrictape so i tdoes not touch body)then turn on,if runs properly there you go.or change timer
Mar 28, 2014 | Maytag Neptune MDE7500AY Electric Dryer
I have a Kenmore dryer, model number is 11074602300 and it only works for a few minutes then stops. Can you assist me what seems to be the problems? Thanks. Kimberly
if the dryer just stops most likely it's the motor,the only way to tell is by starting the dryer until it stops and check with a meter to see if power is still going down to the motor,what happens when it stops and you start it again?does it run or is it dead,what happens if you move the timer by hand after it dies,is it on time dry or auto?try running it in different spots on the timer,it could be a few things.like i say you need to get in there with a meter to find out,i've found in most cases it's the motor when this happens but don't go out and get one and put it in until you know for sure,if you start it when it dies does it make a loud humming noise?let me know what you find,try moving the timer and try to restart it and let me know what you find
Oct 12, 2010 | Kenmore Dryers
Dryer runs for a few minutes then stops after it sets for a few minutes you can restart it
you will have to perform continuity test on run fuse as well as hi and low relay to find out which is the problem which ever has no continuity when u perform the test would be the problem piece
Aug 12, 2010 | Roper Dryers
Kenmore 800 dryer shuts down after running down to 40 minutes on the timer. When I restart it at that point it runs for about 30 seconds and shuts down. If I turn the timer back to 90 minutes it runs down...
Sounds like you may have a bad motor. If the motor is overheating it will shut down on its overload.
If its a shorted contact in the timer you could mark the spot where it stops and restart it again. It should stop exactly at that point.
Jan 22, 2010 | Kenmore Dryers
Dryer stops running after 5 minutes
you may have a defective door switch.
Oct 27, 2017 | Dryers
Dryer keeps running and timer continues to move around dial.
Change your timer. It has a malfunction in it. it's about a 100 dollar fix. Also your start switch may be bad.
Mar 02, 2009 | Kenmore Dryers
A common problem, had it happen to me.
Replace the timer control. takes about 15 minutes and the skill to remove screws, disconnect plug from old timer, remove timer, install new timer, connect plug, replace screws and panel, run dryer.
Reply the model number, and I'll get you the timer P/N.
Jan 15, 2009 | Kenmore 97572 Dryer
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
83 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
