Question about Ricoh Aficio CL2000N Laser Printer
Our printer has an error, the message reads Color Regist Error
Our printer has an error, it reads, Color Regist Error
    Problem Solver:
  • 6 Answers
Clean printer heads and take to pieces to see if anything stuck
Posted on Nov 18, 2009
How do I fix CEC2 error on Toshiba copier?
2nd transfer roller releasing position detection
abnormality
May 20, 2014 | Toshiba e-Studio 4540C Multifunction Color...
On the printer window, it says: Color Regist Error
Hi there
I beleave it is to perform the manual color registration adjustment.
Press Menu. Then scroll to Maintenance and press Enter. Scroll to Color Regist and press Enter. Scroll to Color Regist Auto Adjust and then press Enter to Auto adjust.
But you may have to do this manully adjust all till get right,
Sorry cant help you any more than this.
All the best Pineworks
Feb 09, 2010 | Ricoh Aficio CL3500N Laser Printer
My printer is not printing at all. The following
Please press Menu. Then scroll to Maintenance and press Enter. Scroll to Color Regist and press Enter. Scroll to Color Regist Auto Adjust and then press Enter to Auto adjust. If after completing the procedure the error persists, please contact your service representative for support.
icalled the comapny for you and this is what they said for your machne. Please give me good feedback on fixya
Oct 09, 2009 | Ricoh Aficio CL3500N Laser Printer
Colors aren't blending
We have a problem,after the calibration on the begin the printer gives an error: "Color regist. error",but the toners are full ! How to resolve?? Thanks in advance.
Mar 05, 2009 | Ricoh Aficio CL2000 Laser Printer
ERROR CODE SC45-20 MINOLTA 500
Color registration problem Restart copier and leave the front door open,will bypass the error code page.Press HELP,then press KEY OPERATOR MODE, scroll down to 21 EXECUTE ADJUST OPERATION, select COLOR REGIST AUTO ADJUSTMENT, then press OK, PREVIOUS SCREEN. After adjusting, it will back to normal. If the code number back on again, then it was the transfet belt off alignment. If you know how to pull the transfer back to center position, problem solve, if not, call technician.
Feb 11, 2009 | Konica Minolta bizhub C250 All-In-One...
Color Regist. Error
I had this problem too and replaced the Black PCU and it solved the problem.
Jan 22, 2009 | Ricoh Aficio CL3500N Laser Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Ricoh service mode to reset
    This is the solution from Ricoh website:
    I'm told this works as well...
    On the main board put dip switch 101-1 on and then off and then enter 97 and press the aps key. Then power cycle the printer.
    Jul 09, 2008 | Ricoh Aficio CL3500N Laser Printer
    Ricoh Aficio Color Registration Error
    One of our Ricoh CL3500N printers- less than a year old- gave us a "color regist error" after changing the transfer belt.
    Ran the "adjust color regist" without results. It would just finish and pop back up with the same error.
    Color test page printed no color, just BW
    I reseated everything, and even replaced the PCU without positive results.
    A couple hours later I went back, took everything out (be sure to keep the pcus out of the light!), and vaccuumed the heck outta that printer.
    For whatever reason- maybe there was a chunk of toner hanging out, maybe I knocked something loose or back in place, whatever- but when I put all the parts in and turned it on, the error was gone and color printed great!
    Dec 11, 2007 | Ricoh Aficio CL3500N Laser Printer
    Ricoh Aficio CL2000N Laser Printer Logo
    261 people viewed this question
    Top Ricoh Office Equipment & Supplies Experts
    OfficeServiceAjnc
    OfficeServiceAjnc
    fares
    Level 1 Expert
    SOURAV KAPOOR
    Level 1 Expert
    Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
