Question about Kenmore 24902 Top Load Washer
My kenmore will not spin, it makes a noise but will not spin. It pours water but will not wash or spin. what can it be.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Nov 19, 2009
Water will not drain out of front Load Kenmore 44072
Kenmore front loading washing machines will give you years of service. Sometimes things do go wrong, especially after the warranty runs out. Troubleshooting a Kenmore front loading washing machine could save you a lot of money on a repair bill. Before you call a service technician to fix your machine, attempt to resolve the issue through simple fixes first.
Washer Code Messages Your Kenmore front loading washing machine has an LED display that will give you error codes.
Will Not Spin If your washing machine does not spin, check to make sure the door has latched completely. Also remember that if your machine is in the SUD cycle it will not spin until it has eliminated the suds.
Washer Is Noisy
  • If the washer is making noise or vibrating, check to make sure it is still level. If it is out of level you can change this by adjusting the feet. Metal belt buckles and buttons in your laundry could be causing the noise as well.
  • Door Stays Locked After Cycle
  • At the end of the wash cycle, the lock will disengage after about 30 seconds. If it does not, it may be because the machine still detects that the water has not completely drained. Just select "Drain" and "Spin" and let the washer go through the cycle. Your door should unlock.
Nov 03, 2011 | Washing Machines
Kenmore Washing Machine won't agitate, spin, or drain
It sounds like the motor needs to be replaced, you can drain the water by taking the drain hose from the drain and lowering down water will drain.
Jun 01, 2009 | Kenmore 24032\24036 Top Load Washer
Washer wont spin in the spin cycle.Washer was full of water and making a buzzing noise.If you have any suggestions what it might be that would be great. Kenmore 80 series washer about 11 years old.
sounds like the lower bearing on the trans mission shaft is seizing up on you. had a frigedair that did the same thing. i took it apart to replace, but could not buy separate. it only came with a purchase of a new transmission,which ran $175- 275. so i junked it out. washer was only 5 years old.
May 29, 2009 | Kenmore Washing Machines
My model 80 top load kenmore washes but won't spin.
INSPECT LID SWITCH IT S WERE THE LID CLOSES SHOULD MAKE A CLICKING NOISE IF NOT IT NEEDS TO BE REPLACED
Jan 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer make high pitched whining noise
cold water screen in hose was half plugged causing it to either shut off the spin cylce due to lack of water or increase the spinning speed.
Hope this solves the problem.
Dec 10, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Super Capacity Washing Machine
If your washer is the one you have chosen a Whirlpool built kenmore unit than your washer doesnt have any bearing that fail, It could be the spin tube mounting block becoming stripped ( most common) or a clutch or brakes not releasing issue (not likely). Also make sure the machine is agitating it may just be filling with water and draining and making motor noises. In this case the motor coupling has broken. both the block and coupling are inexpensive parts and easy to install.
Jan 14, 2008 | Kenmore 3.2 cu. ft. Top Load Washer
Kenmore elite washer 26922
I would take body of washer find out where noise coeing from.. got 2 screws in each side of head, flip head up and take clamps off .. pull whole body off washer run thu cycle and see if ya can locate the noise.. sometimes water pumps get something in them that well make weird noises.. but are in all cycles.
Sep 07, 2007 | Washing Machines
Kenmore 24902 Top Load Washer Logo
103 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
