Question about RCA F27442 27" TV
Wifes ge tv won't stop changing channels just keeps rotating like it's on scan and won't stop even when we go to menu it keeps rotating through options
    President:
  • 1,284 Answers
I suspect one of the buttons on the front of the TV is stuck. Best thing to do is try playing around with them while the set is in operation and see what happens. If that doesn't seem to be the case then you have a diode or capacitor on one of the control lines that is shorted or leaky causing this to happen. This would require a technician to troubleshoot that issue. Please take a few moments to rate my answer. Thank you...
Posted on Nov 18, 2009
The channels on my ge 32gt720 tv keep changing by them self
Channel change button on the remote or on the side of the TV coule be stuck.
Jul 20, 2014 | GE 32GT720 32" TV
I HAVE A RCA 42" LED TV. I RECEIVE MY SIGNAL FROM AN ANTENNA. I CAN ROTATE MY ANTENNA, SCAN THE TV FOR CHANNELS, AND THIS WORKS FINE. THE PROBLEM IS IF I HAVE TO ROTATE THE ANTENNA FOR OTHER CHANNELS,...
on B:Press the MENU button on the remote.Select Setup.Select Auto Program.Choose Air or Cable.Select Auto Program to let the TV reprogram the channels.Check that the channel is programmed into memory. There are a couple of ways to do this: Use the TV menu system. Accessing this setting varies depending on the model TV that you own. Here are two options that are common on many TV's: Option A:Press the MENU button on the remote.Use the VOL and CH buttons to move through the menu and add any missing channels try this if not r
Do a full reset if this dosnt work
Dec 25, 2013 | RCA L42WD22 42 in. LCD Television
Can`t retune samsung le 37 r88.
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Oct 01, 2009 | Samsung LE37S71 37 in. HD-Ready LCD TV
Samsung le26r74bd won't retune digital channels
Sep 30, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Samsung LE32R7 will not retune since switchover
Sep 30, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Tuning option on menu is greyed out. cannot retune channels
If the channel icon is greyed out and you cannot tune the channels press the TV/DTV button on the remote control unit the icon is not greyed out and tuning is possible.
Sep 30, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Re scanning
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again.
If the channel and other icons are greyed out and you cannot tune the channels press the TV/DTV button on the remote control unit so that the icon is visible again and not greyed out. This will allow you to tune the TV.
Sep 30, 2009 | Samsung LE37S71 37 in. HD-Ready LCD TV
Cannot keep all channels on tv
When you say you "lose" channels, you probably mean there's no signal there anymore but they are still in the channel memory. This is normal if you have a rotatable antenna. You need to mark the rotator (or just keep a chart nearby) with the heading for each channel.
If you mean you're losing channels from memory when rescanning after turning the antenna, the only solution I can offer is to record the channels found (and their signal levels) after scanning a direction. Then change directions and rescan. See what new channels have been found, what have been lost, or how signal level has changed on common channels. Then you can manually add whatever you need, and you'll know what direction is best for each. It's tedious, but you should only need to do it once.
Nov 24, 2008 | Insignia Digital-to-Analog Converter for...
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
After programming my new universal remote, the tv keeps changing chanels! wont stop!
you need to program your remote control. take the battaries out. and maually turn the tv on. then hit the source you want to view. for example, I want to control the tv set. I push, code search and hold it then push the source button and then release the source button and then release the code search button. now, aim at the tv and then keep pressing power button till it goes off. when the tv is off, hit return or set or something like that.( every remote has different calling for it but still the same function) it should work. try it and let me know.
Mar 06, 2007 | GE HO976855-Device Universal Remote with...
RCA F27442 27" TV Logo
222 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
