Question about Brother MFC-5440CN All-In-One InkJet Printer
My fax onmy mfc is beeping when i dial and press start there is no dial tone when i press hook is it connected?
    President:
  • 2,306 Answers
If it is connected you would hear a dial tone when you press hook. There are 2 possible places to connect the phone line, the proper one has an L on it and the other a picture of a phone that is for a phone or answer machine.
Posted on Nov 18, 2009
Testimonial: "thkz a bunch"
How do i set my fax machine to recieve and send faxes
Dear
Connect the telephone line to the LINE socket of the fax machine and a telephone receiver unit to the EXT socket of the fax machine.
To send a fax, put the document on the platen glass (face downward) or face upward in case of ADF.
press on hook dial, (here the dial tone on machines speaker)
dial the fax no. ( wait for call connection and here the fax Rx. tone)
press START.
To receive a fax two procedure can made, manual- lift a hand set of telephone receiver on incoming ring, here the TX tone(periodical beep tone) press * 9 * of the telephone receiver. In auto mode go to fax setup select ans. to ring or auto fax etc. to activate atuo reveive of fax.
Hope this may helpful.
Thanks.
Aug 11, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
I cannot send fax
Hi there!
For you to send a fax with the Brother Fax you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook/speakerphone button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still, connect it to another working outlet. If you don't have a dial tone still, connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Apr 02, 2011 | Brother IntelliFAX 2600 Fax
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
Thanks!
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
I have a Brother mfc 290c. My problem is it won't send faxes, it keeps saying "no response, busy" I have a duet line. I have tried every combination in the book but still can't seem to find the solutions...
If you get the "busy/no response" message it is because the fax machine does not get a response when it tries to dial out.
Make sure you have a dial tone by pressing the "hook" button. If you do not have a dial tone, make sure the phone line is connected to LINE on the machine.
If you have a dial tone, try dialing the fax number. If you hear a recording, there is a problem with the line.
One of these two possibilities is causing the problem.
Thanks,
Pat
May 12, 2010 | Brother Office Equipment & Supplies
No dial tone when pressing hook fax is returned
The only thing that could stop you from sending a fax or not get a dial tone, would be the connection to the phone line. Make sure the telephone wire is plugged into the line jack (not ext jack) and should go straight to the wall, without splitters or extensions. If you still cannot send a fax, try another wire or jack
Apr 06, 2010 | Brother Multi-Function Center MFC-240C...
No dial tone pressing hook, NG and Poor line condition transmission report on sending and receiving. Confirmed good dial tone on line in and on phone on ext. Copy, display, everything else fine. I hear...
Make sure that you have your telephone line from the wall jack plugged into the port on the fax that says "LINE" and that your telephone is plugged into EXT.
All your cables and jacks seem like they are working since your phone gets a dial tone, the onyl thing could be that the wires are mixed or the modem on the fax is broken.
Thanks,
Pat
Mar 27, 2010 | Brother Multi-Function Center MFC-240C...
I need to know how to send a fax from a brother MFC-295cn all-in-one printer
Hello Frank,
Sending a fax is fairly simple.
1. Make sure you have a telephone line connecting to the LINE jack on the side of the MFC-295CN
2. Check if you have a dial tone by pressing the "hook" button on the machine while the line is free.
3. Place a page face down on the flatbed scanner or in the document feeder on the top of the machine.
*Note: If you are using the document feeder, once the page is placed in, you should see "enter fax #" on the LCD
4. Enter the fax number the same way you would dial a regular phone number.
5. Press "Start"
*Note: If you are using the flatbed option, after the sheet is scanned, you will be asked if you want to scan a second page. For additionnal pages, press 1, to end scanning and start faxing, press 2
6. If the fax goes through properly you will see "completed" on the LCD
Mar 25, 2010 | Office Equipment & Supplies
Brother mfc-260c not recieving fax, has dial tone.
Im not very familiar with that that model in particular. I would check to see if the is an auto recieve button on the control panel or in the fax settings. Just a thought not an absolute solution.
Jun 02, 2009 | Ricoh Aficio 450 Copier
Sending a fax
First make sure that the fax button has been pushed and is llit...
The 2820 should have a handset. In order to use manual transmission (when you get to hear all the beeps and whistles) you will need to load the document then pick up the handset. then dial the number, when you hear the recieving fax tone then hit the start button.
The 2820 should also have a hook hold button pressing this will allow you to hear the dial tone and the numbers you dial along with the receiving fax tone. If you dont hear anything when you press this button then you may want to use the volume buttons to increase the volume.
Also remember that if you have not picked up the handset or pressed he hook/hold button the unit will use automatic mode, which is to say that all you will do is load the document, dial the number, and then press the start button.
May 19, 2008 | Brother IntelliFax-2820 Laser Fax
Brother MFC-5440CN All-In-One InkJet Printer Logo
64 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
