Unable to open my Battery Door Satellite 1800-S274. I didnt want to use tools to pry open if unnecessary. Is there a trick to opening the door/cover? Thanks
  • 43 Answers
The battery can be removed from Laptop by pulling the battery out after sliding the sliding buttons given near battery. you don't have to use any tool to remove battery out of the laptop.
Posted on Nov 19, 2009
How do I get the battery compartment open on the Leapster GS Explorer?
To open the battery compartments firmly press down on the arrows with your thumbs and push it out. You should feel the cover unlatching as you firmly press down and out.
Dec 02, 2012 | LeapFrog Leapster Explorer Learning...
How to replace rear view mirror
Instructions
Disconnect your negative battery cable, if your Ford Focus has power side mirrors. If it has manual side mirrors, disconnecting the battery is unnecessary.
Pry off the wing mirror's inside sail panel (shaped like a triangle). Insert a trim panel tool between the door skin and the plastic panel to pry it off.
Carefully pull the sail panel away, minding the wiring if the mirror is power-operated. Unplug the electrical harness and set the panel aside.
Open the door and hold the outside part of the wing mirror steady. Remove the mounting bolt with a socket wrench, and then remove the mirror screw with a Phillips screwdriver (the mirror bolt and screw is visible with the panel removed).
5
Pull the wing mirror assembly from its mount (from the outside). Insert the replacement mirror assembly in place; tighten the bolt and the screw.
6
Attach the wiring connection to the replacement mirror. Position the sail panel in place and push it against the door to snap it back on.
Apr 18, 2012 | 2005 Ford Focus ZX3
I am trying to take the passenger door panel off of my 2003 kia spectra however it still seems connected towards the front side of the door but i tryed to removed the two tan screws just free spin i do...
hello,
Disconnect the negative battery cable to prevent shock when handling the door components. Loosen the cable's nut with the pliers and slide it away. Pop off the side-view mirror interior panel with the tweeter on it. Use the door panel trim tool or a flat-bladed tool, such as a putty knife, wrapped in masking tape. Once the panel is off, unplug the speaker connection from behind it. Push the connector's tab in with a flat head screwdriver and pull the connector away. Open the door fully to expose the screw cover on the front part of the door panel. Pry out the screw cover with a flat head screwdriver. Pry out the small centerpiece; not the ring surrounding it. Behind the cover, you'll find a Phillips screw; remove it.
Open the screw cover flap behind the inside door handle. Insert the tip of a flat head screwdriver into the upper-slot; push down to open the flap. Remove the Phillips screw from behind the flap. Pull off the plastic door handle surround piece. Insert the door trim tool behind the panel; pull it back to pull the panel off. Slide the surround piece away from the door panel.
Remove the circular screw cover from the inside door pull storage compartment. Pry it up with the flat head screwdriver. Remove the Phillips screw behind the cover. Remove the screw cover from the rear-edge of the door panel. This cover is similar to the one on the front part of the door panel; pry out the center part, not the ring surrounding it. Remove the Phillips screw behind it.
Remove the two Phillips screws visible along the bottom part of the door panel.
Pry around the perimeter of the door panel with the door trim tool. Pull the tool handle back to pop the door panel clips out. Do this for each side, except for the top. Once the clips are unhooked, the panel is ready for removal.
Gently pull the door panel away from the Optima's door, but only enough to access the area behind it. The connections for the power equipment must be unplugged. Reach around and depress the connection tabs with the tip of the flat head screwdriver; unplug the connection. There are three connections to unplug. Once they are unplugged, pull the door panel away.
Thanks
May 21, 2011 | 2003 Kia Spectra
How do I replace third brakelight in 2005 Escalade
High-Mount Brake Light Removal & Installation Except Avalanche and Cadillac To Remove:
  1. Disconnect or remove the following:
    • Negative battery cable
    • Open the hatchback door
    • Pry open the center high-mounted stop lamp (CHMSL) access cover with a trim removal tool
    • Electrical connector
    • Screws and the CHMSL
To Install:
  1. Install or connect the following:
    • CHMSL with the screws. Tighten to 17 in lbs (2 Nm)
    • The CHMSL access cover
Cadillac except Escalade EXT To Remove:
    • CHMSL retainers
    • Lower the hatchback door
    • Raise the CHMSL
    • Electrical connector and CHMSL
To Install:
    • Mounting screws into holes. Tighten to 10 in lbs (1.2 Nm)
Avalanche, Escalade EXT To Remove:
    • Rear compartment cover
    • Cargo box bridge center mounting screws
    • Panel assembly from the vehicle
    • Electrical connector.
    • CHMSL fasteners.
    • Remove the CHMSL from the cargo box bridge center bar.
To Install:
    • CHMSL to the cargo box bridge center bar with fasteners
    • Electrical connector to the CHMSL
    • Panel assembly to the vehicle. Tighten to 62 in lbs (7 Nm)
Oct 15, 2010 | 2005 Cadillac Escalade
How do you remove interior door handle form 1993 Ford Tercer The window won't roll up and I can't get the handle off to get the panel off to get to the window tract
It's easy!
  1. Remove triangle-shaped plastic cover Fwd of door window - gently pry it off
  2. Remove screw from the plastic cover behind door open lever
  3. Remove door lock plunger. (unscrew)
  4. Remove screws down inside the door pull hand-hold area
  5. Look for other phillips screws - sometimes around the lower 1/2
  6. Pry hidden plastic hold down fasteners from around the edge - pull the panel away from the door and where you see it 'stuck' to the door, slide a pry tool, a stiff putty knife works well, up in that area and pop the fastener off.
  7. Lift door liner enough to get to the mirror power connector and unplug.
  8. For some model years, with door panel loose, you can access the bolts / screws that hold the interior trim piece in place and remove.
  9. Remove Mylar cover for access to 3 Mirror mount studs, speaker screws, door lock actuators, window motors, etc.
  10. Remove nuts, (hold the mirror up from outside) and remove mirror. (Feed electrical harness through door openings as required to facilitate removal.
  11. Reverse order for installation.
Jun 01, 2010 | 1993 Ford Taurus
Dvd movies do not playback smoothly on my toshiba 1800 s274
format your laptop and install grfic dirver useing the laptop cd ..........and install recvier program and after working fine.......www.compudesk.in
Jun 22, 2009 | Toshiba Satellite 1800-S274...
Vga controler for toshiba satellite 1800 s274
Hello, do you know the grafics card that you have on your Toshiba? Brand, model...? Regards
Jun 11, 2009 | Toshiba Satellite 1805-S274 Notebook
Stuck battery/ScanDisk card
Unfortunately, you have to force the battery door (very carefully) to open it, and find what is wrong with it.
It is more likely that when closed the battery door, it was forced and it slided out of one guide channels.
You need to practice a little bit before to try it with force (genlty but with firm force), but the only way to do it is slide the button to open it, and at the same time slide to the side and pull the battery door, everything at the same time. Try it until you are able to open it.
Using any kind of tool (such a plastic pry tool, a small screwdriver, etc) to force will leave marks in the housing, and it's very possible that the plastic locking tabs will break, causing that you will open it, but unable to close properly again.
Best regards,
Mar 10, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Cant open the glove box
No trick, it is most likely locked, use a putty knife an pry it open carefully near the center where the latch is, it will pop open
Nov 14, 2008 | 1999 Volkswagen Passat
Computers & Internet Logo
David Payne
David Payne
