SOURCE: self clean light blinks when you turn oven on (oven does not work)
I had this same problem with mine (still posted under unsolved) This is the simpler model with the old turn style knob and the lever you slide over to lock the door for cleaning What I think (keep in mind I know little about ovens, more about cars) is that the switch that tells the oven the door is latched is staying engaged, and this is part of the lever mechanism. I cleaned and lubed this mechanism (obviously I would guess you want to use a food safe lubricant) and then moved the lever several times with the oven on so I could see if it turned on. After a few tries the cleaning light went off and the oven light came on. No, its not really a technical answer, all indications to me where that the problem was in the switch which is part of the latch mechanism. Good luck
SOURCE: self cleaning oven
This is the link
http://safemanuals.com/user_guide_instructions_owner_manual_ELECTROLUX_316257104EN.htm#
SOURCE: Self cleaning MAytag Gemini GAS oven
A wonderful feature is that the ovens self-clean with the press of a few buttons. Only one oven can be programmed to self-clean at a time. Remove the oven racks. Turn off the oven light and close the door. Press the "Clean" button and then press "Auto Set" to automatically clean the oven for 3 hours. Press the "Auto Set" pad again to set the oven for a 4-hour clean cycle, or press the button one more time for a 2-hour cleaning. The oven locks when in cleaning mode. When the oven is finished cleaning, the word "Cleaned" will be displayed on the control panel, and the oven will remain locked until the oven has cooled, which takes about an hour. To cancel the self-clean cycle, just press the "Cancel" button. Simple!
SOURCE: I have lost my manual to my GE Profile Gas Range, self cleaning, convection and conventional oven
what does f2 mean when I am self cleaning my ge profile oven.
SOURCE: How do I use the self-cleaning oven feature
An easier option for you would be to download a replacement manual. Go to managemyhome.com and register. This is a FREE service. Once registered, log in and go the "Home Manager" link at the top of the page. Look for the "Owner's Manual" link under the drop down menu and click on it. Enter your Brand Name and Model Number. Your Owner's Manual is listed in a downloadable .pdf format that you can save to your computer or print out for ready reference. I hope you find this information helpful. If you have further questions, please let me know.
Thank you for your post, Jewell!
From the information you have provided you would like a manual for your Frigidaire oven. I would be happy to research and see if that information is available. In order to research for any available manuals I would need your model number. You can locate the serial tag (which lists your model number) on the door frame of your oven or on the inside left hand wall. Once I have that information I would be able to better assist you. -Matt
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker
