Question about Panasonic DVD-CP67 Multi-disc DVD Player
H07 on panasonic
Hi, I have a code number H07 show on my dvd. It currently can't read the disk. Does anyone know what the code stands for?
Thanks
Hi Replace spin motor
John Cabarita TV
Posted on Mar 06, 2009
Normal 0 This solution is most likely being submitted way too late to help "dingo 1295", but perhaps it will help others who run into the same problem.
Just this past week, in January of 2009, I ran into the very same problem with a Panasonic DVD-CP67 DVD Player. The player would no longer play disks and displayed the H07 error. Now, I can't answer the question about what exactly the H07 code is suppose to mean, but I can offer one possible solution for the DVD Player's inability to play disks and the subsequent display of the H07 error. What happened in my case is that a film of dirt had built up between the electrical contacts that are suppose to form a closed circuit when the player's disc drawer is closed. The two metal plates that make contact rub against each other and the abrasion eventually both creates and traps dirt where the plates touch. Therefore the player could no longer tell that the disk drawer was closed because the dirt blocked the fragile electrical circuit from being closed. Since the player could not tell the drawer was closed it would not spin up and play any inserted disks. I'd also like to note that before the player quite playing disks and started displaying the H07 error I was watching a DVD and did see the picture quality degrade until the video finally cut out and the disk stopped.
The Solution in this instance was to carefully remove the cover from the player, after removing seven screws on the back and sides of the player's case, and to clean the metal contacts with a non-abrasive eraser. The pink eraser on a NO. 2 pencil works perfectly.
On the back of the disk drawer, on the right side is a silver metal plate and at the back of the player, mounted on the plastic frame work around the platter that picks up any disk placed player, is a folded copper plate held down with a screw. Simply unscrew the copper plate and clean it with the eraser were it normally touches the silver plate on the drawer when the drawer is closed, being sure you do not get any eraser dust inside the DVD player. Although the copper plate will most likely be the plate with the most dirt on it you can also clean the silver plate without removing it. Once cleaned, you can reattach the copper plate with its screw.
Testing... You must place the cover back on the player before it will play disks. The cover must be fully seated, but does not necessarily have to be screwed on. You may have noticed when cleaning it that the copper plate has an upward folded tab that presses against the player's metal cover when the cover is closed. Without the copper plate touching the player's metal case through its cover the previously mentioned electrical circuit won't be closed and the player won't play disks. With the cover properly back on the player go ahead and try and play a disk. If it works then the problem is solved and you can finish screwing the cover back on. If the player still doesn't work then something more serious may be wrong and I would suggest contacting a service center.
I hope this helps.
Posted on Jan 11, 2009
Hey I just messed around with mine it was showing that code H07 like the others its kinds the same except it holds 4 more disc, I took the top off then I took the thing that holds cd still off!, there should be a brass thing I think thats for the ground, so I ended up putting some synthetic oil on the rails silver poles that the laser slides on, and where the disc sits on that black circle under it, you can see the motor it has a white thing on the motores pole so I just put a few drops on there then spinds it put some more on hoping it works its way DOWN INTO THE MOTOR thats the H07 not spining fast enough!! I put a disk in while everything was apart and its playing right now, the oil I desided to use was the stuff I use for my paintball gun lol! its really thin and slippory and im sure it will last for awhile!.... going to add more after 15 minutes of playing just to make sure its really lubed! hope this helps!!!!
Posted on Jan 13, 2008
DVD stops spinning displays code H07. Repair procedure?
H07 is the error code for Disk not Spinning. Open the case, open the DVD rack. Put 2 drops of 3-in-1 Oil on a Q-tip and rub the side of the spindle (located under the optical "eye"). Don't drip! Then close the DVD-rack with a DVD in it. Work the DVD in clockwise direction. Hopefully it will start to spin again.
hope this helps
john
Jan 21, 2011 | Panasonic DVD-RV32 DVD Player
Player "reads" the DVD and then the display says "H07" and ends.
The "H07" is an error code, this particular error code refers to the dvd spindle drive motor. Effectively the spindle motor that spins the DVD isn't turning correctly and on occassion this can be that the spindle & bearings need lubricating due to partial siezure. But really this should only be done by somebody with a bit of technical know-how to avoid further damage to the machine or indeed an electrical injury to the person under taking the task. I can only suggest that you contact a Panasonic repair shop and to see if it is cost effective to repair.
Hope this helped,
James
May 02, 2010 | Panasonic DVD-RV32 DVD Player
Panasonic dvd players error codes
I tried the WD-40 and it worked........thanks a million !!
Mar 28, 2010 | Panasonic DVD RV22K
I am getting an H07 code
If memory serves me well, code H07 means that spindle motor has to be replaced. It is ease enough to test, remove top cover from the unit, load DVD disk, when disk is loaded try to give it clockwise push. If unit starts and works - spindle motor is the problem, if it will not start then spindle motor plus driver IC has to be replaced.
Nov 14, 2009 | Panasonic DVD-RV32 DVD Player
Error code h07
HELLO
I have just recently posted a cure for this - but here we go again. Fault H07 is the fault code for the spindle/disc motor and to cure it do this!
With the lid of the player removed, locate the spindle and where the motor shaft goes into the motor itself, use a little light oil or WD40. Let it soak in a while and try it again - you should now find it works.
Why this works I just don't know - it just does! (:-)
Sep 09, 2009 | Panasonic DVD-RV32 DVD Player
H07 error msg
This normally means the spindle motor is faulty
Jul 12, 2009 | Panasonic DVD-RV32 DVD Player
H07 code appears on the read out
hi..the reason to this problem is the motor.It may
be either spindle motor problem or the motor is not
spinning up.
check this out..
thank u..
kindly rate my response..
Jun 09, 2009 | Panasonic DVD-RV32 DVD Player
My dvd player do not play. it says no disc, no matter what I do
I just removed the top part and clean the laser beam with Q tip and after that it started to work back again.
Mar 19, 2009 | Panasonic DVD-S25
Error Message H07
You can reset this fault by holding in the reverse, pause, and the on-off button, all at the same time. If it comes back then the spindle motor is the bad componet, and unless you know how to disasemble a mechanism for a changer I would let a pro handle it.
Jun 19, 2006 | Panasonic DVD-S35S DVD Player
Panasonic DVD-CP67 Multi-disc DVD Player Logo
439 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
