Question about Brother HL-4040CN Laser Printer
My brother hl 4040cn is printing fine, except there is a blank vertical line in the middle of the page. what is this?
    President:
  • 2,306 Answers
Usually just toner dust on the laser lens, you remove the toner and drum and look on top inside for a window about 1/2 inch wide. You wipe that window with a dry cloth, and also check for paper scraps inside or on the drum assembly.
Posted on Nov 18, 2009
Printed pages have streaks vertically along edge
Sounds like the end seals in the cartridge are bad. Remove the cartridge and see if there is toner built un inside printer. Also look at the drum on the cartridge to see if it has black lines that line up with the pirnt defect you are seeing. Try a new toner cartridge and run about 50 pages through.
Apr 30, 2011 | Brother HL-4040CN Laser Printer
Can someone please help me i have just printed off 400 prints with my brother hl 4040CN laser printerits brand new and its now saying my cyan toner has ran out this is impossible i am right in the middle...
Your toner usage will depend upon how much of each color toner is used on each page. (To conserve colors when printing in Black and White only, specify monochrome in your printer setup) <div>I had similar problems when printing publicity flyers. The toner cartridges claim to be good for about 2000 prints each, but I was lucky to get 3 or 400 pages when printing blocks of color. The TN115 cartridges hold significantly more toner, and the cartridges that come with the printer are TINY.</div>
Jul 06, 2010 | Brother HL-4040CN Laser Printer
Prints only blank pages
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 06, 2010 | Brother HL-2040 Laser Printer
Printing problem
Vertical line is probably scratch in Toner/image drum or one of the erase LED bar lamps is out. Start by replacing the Drum and see if it is better. LED erase lamp assy is more expensive so I hope for you that it is the drum.
Saw this scratched tomer drum on a ton of HP I serviced while in Europe
Cheers!
Jan 27, 2009 | Brother HL-4040CN Laser Printer
Difference between Brother HL-4040CN and HL-4050CDN printer
The D stands for duplex printing (both sides of paper)
Dec 16, 2008 | Brother HL-4040CN Laser Printer
Brother HL-404CN color laser priter unable to print error message E1.
I have a Brother HL 4040Cn printer that has stopped working completely with the exception of the side exhaust fan running. This machine has printed low volume of work over it's 18 month period and I have read another post today describing the same problem!! Any ideas? Brother want a minimum of €150 to take a look at it.
Nov 25, 2008 | Brother Office Equipment & Supplies
Printing envelopes on HL4040CN
I just bought a HL-4040CN and all my envelopes wrinkled, regardless of the size, paper thickness or software settings (thin envelope, thick envelope, etc.). Here's how I solved the problem....Open the rear panel and you'll notice a small gray lever on each side, which is probably pointing to "A" on the scale (A, B, Envelope). Move both levers to "Envelope" and close the back panel. The troubleshooting manual says the levers should be moved back to "A" after printing the envelopes, but I left them in the Envelope position and can't see any difference when printing regular or test pages or envelopes, except the envelopes are no longer wrinkled. I called Brother and asked them if there was any reason why the levers can't stay in the Envelope position, and they told me they could be left there if it wasn't negatively affecting other documents. Now, I have a great printer that prints everything without any problems. Hope this helps.
Sep 08, 2008 | Brother HL-2040 Laser Printer
Printing dots on Brother HL 4040CN
do this procedure
1.print test page then stop the printer on the middle print proses by turn the printer of or open the rear cover
2.remove the paper jam carefully
3.look to the paper if the problem found change the drum unit els the fusser unit cause the problem
Apr 01, 2008 | Brother HL 1440 Laser Printer
Brother HL-4040CN Laser Printer Logo
569 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
