Question about HP Deskjet 870cse Printer
Replaced the cartridges and the yellow flashes
HP 870 cse I replaced the cartridges and the yellow light above the power button contantly flashes evem after unplugging and turning back on.
    Genius:
  • 1,011 Answers
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Nov 18, 2009
Hp deskjet 948c. What Do The Button's Do
buttons and lights The HP Deskjet printer buttons let you turn the printer on and off, cancel a print job, or resume printing. The lights give you visual cues about the state of the printer
sayurisan20_33.jpgcancel button
print cartridge status symbol and light **The light above the Print Cartridge Status symbol flashes when a print cartridge is low on ink or incorrectly installed.
sayurisan20_35.jpg resume button and light
**The light above the Resume button flashes when an action is required such as loading paper or clearing a paper jam. When the problem is fixed, press the Resume button to continue printing.
sayurisan20_36.jpg power button and light **
The Power button turns the printer on and off. It takes approximately five seconds for the printer to turn on after you press the Power button. The green light above the Power button flashes when printing is in progress. Caution! Always use the Power button on the front of the printer to turn the printer on and off. Using a power strip, surge protector, or a wallmounted switch to turn the printer on and off may cause premature printer failure
Jun 17, 2011 | HP Office Equipment & Supplies
My hp17680 is flashing a green light down by the memory slots on the bottom right of the unit and a code is being shown "B81AA24C". Since this appeared I have tried to cut the power, power back...
I had this problem recently after replacing the yellow ink cartridge. After much wrangling with HP, they sent me a new cartridge (since it's date code was not expired) and that seemed to fix that particular issue. You might also try getting a replacement cartridge from the vendor that sold you the one in question since it's likely to be faster and less painful than going to HP directly.
Nov 11, 2010 | Office Equipment & Supplies
HP Business Ink jet 1200. Yellow cartridge lite is on. Changed cartridge, but lite is still on,
Ink cartridge lights: Black, Blue, Magenta, Yellow
When light is on - ink is low (below 25%)
When light is flashing - out of ink - printer stops - replace cartridge
To get a printer status / configuration report press the info button (to the left of the on button)
Oct 07, 2010 | HP Inkjet 1200dn Printer
The Hp deskjet 932c went to the far left position and the light is flashing. That is supposed to mean its out of color ink but its not. I uninstalled the software and reinstalled. It will start to print a...
Follow each of these steps until the problem is resolved:
  • Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  • Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present
  • Remove and then reinsert the print cartridge(s) into the printer.
  • Print the document.
  • Try printing again. If the problem continues, replace the print cartridges.
Aug 04, 2010 | HP DeskJet 932c InkJet Printer
Hp color laserjet 2840 - prints one page in color, next in black & white. Yellow ink cartridge light blinking. Says "replace supply, using black only". Yellow wasn't showing as low previously.
Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
Print the document.
If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
http://www.fixya.com/support/t5717191-hp_deskjet_6540_printer_yellow_light
Jun 18, 2010 | HP LaserJet 2840 Printer
The yellow light blinks and it won't print
I also started having problems with my HP 870Cse when I began using refilled cartridges and had ink leakage (cartridge contacts corrupted). Check for this problem. If so, remove cartridges and gently clean the spillage. Then try using HP brand cartridges and see if this doesn't remedy the problem.
Jan 21, 2009 | HP Deskjet 870cse Printer
Hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Jan 09, 2009 | HP LaserJet 2500L Printer
Urgent printing!
Replace color cartridge so the printer doesn't consider it an error. You can print grayscale only in your print settings.
Nov 02, 2008 | HP DeskJet 970cse InkJet Printer
HP Deskjet 870cse Printer Logo
118 people viewed this question
Seeker5211
Seeker5211
