Question about Autodesk AutoCAD 2004 for PC
Where can i find administrator in the compatibility tab? Trying to run autocad 2004 using vista
  • 4,806 Answers
Right click on the desktop icon and select Properties. Then select the compatibility tab. At the bottom of the tab you will see Privilege Level. Check the box that says "run this program as an administrator"
If you have not installed the program yet, right click on the installer file (usually setup) and select run as administrator.
Regards.
Posted on Nov 18, 2009
How to run autocad 2004 in window 7 home premium 64 bit?
You can try in WinXP compatibility mode but I doubt it will work. Right click on the AutoCAD icon and select Properties. Select the Compatibility tab and then set it to run in Windows XP SP2 mode.
Nov 14, 2011 | Autodesk AutoCAD 2004 for PC
AutoCAD 2004 for PC: Are AutoCAD 2004 and Windows 7 compatible?...
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
May 18, 2010 | Autodesk AutoCAD 2004 for PC
Autocad 2004 and win vista
Apparently, autocad is not compatible with vista.. Might as well, go back to wndows xp.. Please see the required specs to run autocad 2004
Mar 22, 2010 | Autodesk AutoCAD 2004 for PC
I am trying to install AutoCAD 2004 on my new computer with windows 7 and wont install. Any ideas?
AutoCAD 2004 and Windows 7 are NOT compatible. You will need to upgrade to AutoCAD 2010 either 32-bit or 64-bit. Even with the upgrade, there are known limitation issues.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14056444&linkID=9240617
Jan 03, 2010 | Autodesk AutoCAD 2004 for PC
AutoCAD 2004 / Windows 7 compatibility?
If it works in Vista you shouldn't have any problems. Easiest way to find out is to install it!
You can always just uninstall the program fi you run into problems.
Dec 05, 2009 | Autodesk AutoCAD 2004 for PC
To run autocad 2006 on Windows Vista Ultimate 64bit
Right click on program, Properties, Compatibility, choice: Run this program in compatibility mode for: Windows XP Service Pack 3, Click aply and OK. Now it should run. If not try right click again and Run as Administrator
Nov 26, 2009 | Autodesk AutoCAD 2006
My auto cad 2004 dont run on vista
dear windows vista can not accept some software due to incompatibility of software.so you install windows XP and enjoy.
this software specifically designed for windows xp.
Apr 13, 2009 | Autodesk AutoCAD 2004 for PC
32 bit program to 64 bit opperating system
From the Autocad webiste:
System Requirements AutoCAD® Civil and AutoCAD® Civil 3D® 2009 Recommended System Requirements Recommended configuration (excluding server components used with project management capabilities):
  • Intel® Pentium® 4 (3 GHz or higher); AMD Athlon™; multiple processors supported, dual-core supported
  • 32-bit only: Microsoft® Windows Vista® Ultimate/Business/Enterprise, Microsoft® Windows XP (SP2)
Note: Windows XP 64 and Windows Vista 64 are supported in 32-bit compatibility mode only.
Here's how you should be able to run it in compatibility mode:
1. Right click on the Autocad Icon in your start menu
2. click on Properties
3. click on the Compatibility tab at the top
4. check the box next to Compatibility Mode and select Vista 32 bit if it is given as an option.
I don't have Vista here, but that is how it works in XP and I did do a search and it appears to be the same in Vista.
Feb 07, 2009 | Microsoft Windows Vista Home Premium with...
Help me for this problem please
Hi Hamzawork Autocad 2004 is designed to be used with Microsoft Windows XP (Professional, Home Edition, or Tablet PC Edition), Windows 2000 Professional, or Windows NT 4.0 (SP6a or later) therefore I'd suggest to run your Autocad 2004 using Compatinity Mode --> Right click on the program icon--> properties-->Compatibility--> select one of the versions above
Nov 07, 2008 | Autodesk AutoCAD 2004 for PC
Conflict with Autocad 2004 (using Windows Vista)
May 23, 2008 | Autodesk AutoCAD 2004 for PC
Autodesk AutoCAD 2004 for PC Logo
129 people viewed this question
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
