Question about Orion HCCA-D5000 Car Audio Amplifier
I have a d5000 amp and its wired up to a 15.2 hcca orion sub when i turn it up high volume,it cuts out anyone know why
Make sure you have the frequency cuts right. if ur giving the sub anything lower then 30hz (assuming ur using 15's) the amp will cut out to protect the woofers from overload
Posted on Feb 10, 2010
For da orion 2500d, what would be the difference between 10'', 12'', & 15'' orion hcaa subs besides a matter of price and inches? I have two of the orion 2500d amps and am ready for the subs. I would...
I honestly would go with 2 12 inch dual 2 ohm subs and wire them one per amp. That will give you a 1 ohm load to each amp and will give the HCCA's 2500 rms per sub... It will be stupid loud... 10s hit tighter than 12's usually and 12's tighter than 15's but u will get more air movement out of a 15 than the 12's and 10s... but... 2 10's require say a 4 cubic foot box to perform well... 2 12's require a 5 cubic foot box to perform well and 2 15's require about 7 to 10 cubic foot to perform to their fullest... no matter what if you put a sub in a box that's too small it will not perform or sound like what you want it to... go 2 12's and like a 5.50 cubic foot box or a 6 cubic foot box and you will love it...
Dec 01, 2009 | Orion HCCA-D5000 Car Audio Amplifier
I have 2 jl-w6 subs n a orion hcca 250 amp how do i run wirering
Hello brianmitchel,
From what I am able to determine, the Orion HCCA250 is a bridgeable 2-channel amp that is stable to 1ohm when bridged and outputs 800 watts RMS into that load.
The JL W6's in both 10" and 12" versions are dual voice coil with 4ohm coils so they can be wired to present either an 8ohm load (series) or a 2ohm load (parallel). They can handle 600 watts RMS.
With this combination, the best configuration would be to wire the sub voice coils in parallel for a 2ohm load and then parallel both subs to the amp bridged terminals for a final impedance of 1ohm. The subs will each be getting 400 watts.
In any event, I would not recommend running subs in series. There is some evidence for distortion being caused by something termed "back EMF".
Hope this helps.
Aug 03, 2009 | Orion HCCA-D5000 Car Audio Amplifier
My Orion d-5000 amp which is wired to an Orion hcca 12.2 sub cuts out at high volumes , it's wired with 0 guage wires
Your speaker is a dual 2ohm sub. If you have both voice coils wired Parallel that will drop the ohm load to 1, which the amp can not handle. You need to wire the voice coils in series. Treat each voice coil as a speaker.
Jun 30, 2009 | Orion HCCA-D5000 Car Audio Amplifier
My orion d5000 cuts out at high voloume for a few seconds then comes back on ????? why
Hello m3_sam,
You did not say what you have the amp wired to and what impedance. Since the amp produces more power at a lower impedance, it does make a difference.
At 4 ohms, the HCCA-D5000 delivers 1000 watts RMS. The higher the volume, the more the amp needs to draw from the battery.
Assuming everything is installed according to specifications, especially the dual 4AWG power and ground connections, it's likely that your vehicle battery/alternator is simpy not able to keep up with the current demand of the amp at high volume. You should probably consider upgrading your vehicle alternator and/or battery. In addition, consider a "Big Three" upgrade. This involves replacing or supplementing the battery positive, vehicle negative, and alternator cables to ones of larger gauge that will allow more current flow. Installation of a capacitor could possible solve the problem, but with the current demands of your amp, I wouldn't count on it.
Hope this helps.
Apr 22, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250 digital reference & orion XTR 12" 500w dual subs
If you have one sub dual voice coil, just paralel the sub and conect to brigde amp. Simple...
Mar 02, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250 digital reference & orion XTR 12" 500w subs
the speakers most not go lower than 2ohms.when the amp. is bridge you are connectin 2 channels.your speakers are most important,the impendence of it,in ohms e.g 4ohms or 8ohms.note make shore the amp.can go down to 2ohms when bridge,or connect the speakers in series.if you not shore.
if its hot its drawing to much current sound as if you have something improperly hooked up..if i could see your wiring i could help u out better steve
Feb 27, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250
i can make this relatively simple.
2 stages:
Stage (1) wiring the Sub inside the box;
Unscrew the SUB from the Box, (& undo the wires)
Connect both +Positive terminals on the SUB to the +Positive terminal on the inside of your BOX.
Connect both -Negative terminals on the SUB to the -Negative terminal on the inside of your Box,
Then screw the SUB back into the Box.
u Have just wired yr sub in parallel. any Amplifier will see it as 1woofer with 1OHMs resistance.
Stage (2) bridging your amp
(please check Amplifier instructions on which terminals to use)
generally you use "LEFT -Negative" and
"Right +Positive"
and connect to the corresponding terminals on the Sub Box.
Hope that helps someone.
Feb 25, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion HCCA-D5000 Car Audio Amplifier Logo
301 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
