Question about SanDisk MobileMate SD Plus 5-in-1 Media Card Reader (860571) Hard Drive
Micro sd I have a micro sd 1GB and I have a new computer, I want to know how can I erase and record on it.
  • 1 more comment
  • Big Pro Jan 11, 2008
    Yes I do.
    thank you. i'll let you know if it works.
  • brian c
    brian c May 11, 2010
    Do you have a SD card reader?
  • 589 Answers
Once you plug it in, it should appear under "my computer" as removable storage. From there, you can right-click on it, and perform the format, etc.
If you want to copy to it, you can either copy / paste the file from to the card, or just drag the file to it.
Posted on Jan 11, 2008
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
I have a 1gb micro sd card whichi is deteted by both phone and computer but unable to open or format. Please help Bijaya Tripathy
Do you mean detected or deleted? Make sure on the side of the card you do not have it locked. Restart both devices and try again. Clean the contacts of the card with a pencil eraser. If none of these ideas work you may have a defective card. It happens sometimes. Let me know more details as the last thing you did at the time or if this helps and thanks for using FixYa.
Jan 27, 2011 | SanDisk 1GB microSD Memory Card
My sandisk 1.0 GB memory card with a lock switch on the side, no longer has the switch when i tried to unlock it the switch came off. what can i do to unlock it
1.Download and install Sony EzRecover and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 2.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 22, 2010 | SanDisk 1GB microSD Memory Card
Computer isnt recognizing micro sd but cell phone does. I'd like to transfer mp3 files from computer onto cell with microsd
leave the sd micro in cell and connect the cell via usb to pc/laptop..go to my computer on pc you should see a new drive yes the cell card copy/paste or click/drag your mp3 files to cell from your music folder
Jul 01, 2010 | SanDisk 1GB microSD Memory Card
Sd memory card says card can not be read why?
you can try formatting the disk. otherwise, it may be erased or damaged.
this same thing happened to me with my sandisk 8gb micro sd in my phone.
I lost everything on the disk, it never worked again , and still not sure how it happened?
maybe they zap em from satellite to make us buy new ones? LOL who knows.
more than likely if it cannot be formatted and cannot be read it's done.
p.s. did you check to see if the disk is locked?
Mar 26, 2010 | SanDisk 1GB microSD Memory Card
It doesnt work when i insert the card with my micro memory card and asks for a disk
Hi likkle_miss_,
The Micro adapter has no memory in it. It is just an adapter to use so you can plug your Micro SD memory card into a larger (SD) slot. The SD Micro memory card needs to be inserted into the adapter.
Kingston Tech Support
Apr 22, 2009 | Kingston 1GB Secure Digital Memory Card
Micro sd
let me understand this...to erase from it, just pull it up after going to my computer and finding the usb port it is in and delete anything that is on it....
now you 2gb memory/card/stick is new? is this a memory card for your camera?
If your sd card is plugged in to removable disk k and you send your photos to it, then they should be on there. That is all you have to do is select, send to and choose disk K.
if you want to make sure they are going there, have disk K open and running at the bottom, it will not hurt a thing.
Hope this helps
Feb 12, 2008 | SanDisk MobileMate SD Plus 5-in-1 Media...
What size micro sd for my Samsung Sync cell phone
I have a 1gb card that works, and i just got a 4gb that does not.
Nov 25, 2007 | Samsung SYNC SGH-A707 Cellular Phone
My New Micro SD Memory Chip
i need help. i insert my lexar 1gb micro sd memory card into my phone and my phone doesnt show that there is a memory card inserted and i have no idea how to work it on my phone. my phone is a samsung blast.
Jul 31, 2007 | Samsung SGH-D900 Cellular Phone
Problems with my Micro SD Card
sorry if your v3i only supports a 1GB micro sd card that's just the max no more than that.
Mar 27, 2007 | Motorola Mobility RAZR V3
Computers & Internet Logo
62 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
