Question about Welding Tools
Miller big 40 starts and stopd after a few secvonds
  • flo flo Nov 18, 2009
    installed new carb need help adjusting carb and gov linkage
  • Bruce Hathcock May 11, 2010
    what di it do? stop welding stop feeding wire stopped running more information please.
    Problem Solver:
  • 13 Answers
Low oil sensor?
Posted on Mar 06, 2010
No power from welder
Same as "my car won't start" Gotta start finding then problem. If I had a magic wand, I'll help you.
Sep 04, 2014 | Miller Big 40 CC/CV
Miller big 40 serial number hgo63411 it will not
The carburetor needs to be taken off and taken apart cleaned out and possibly rebuilt.
Aug 27, 2014 | Cars & Trucks
Miller welder problem
If it has a timing belt it broke or lost a few teeth. The camshaft became disengaged from the crankshaft. Any Automotive mechanic can fix it.
Jul 30, 2014 | Miller Big 20
Have a 71 miller big 40 won't ark and no power out of plugs put a new ingniter on welded for an hour then shut it off when back the next day and it wooden weld ageen S\N HE802998
hi, you have 2 big resistor with ajustable tab on it,check for visual damage on it and rusted connector or tab,
replace tab at same place if you disasemble it
Feb 16, 2014 | Welding Tools
I have a Miller big 40 bout an 87 modle that runs and welds great but wont idle down. Any thoughts?
There is a solenoid that controls the idle speed and the run speed- it is stuck in run speed. It may be a binding linkage, it may be bypassed by a previous owner.Chances are, as the idle relay is controlled through a load sensor on the control board and it may simply be a wire is off, damaged, or the solenoid is stuck.
There were a few different engines available for that model so exact connection will vary,
This the main manual
http://www.millerwelds.com/om/o450n_mil.pdf
The manual for the engine option you can scroll down to the "Big 40" in the list and just below that are the manuals for the different engines used.
Mar 26, 2012 | Welding Tools
I just started up a Miller Big 40 welder after 18 years, it runs like a charm, but the 110 plug is dead and there is no arc when trying to weld.
After 18 years, the welder has either lost its residual magnetism (which allows the output voltage to ramp up) or the voltage regulator is defective. Another possibility would be the brushes for the field not contacting the rings like they should - damaged brushes or weak springs. Contact Miller/ Hobart for a service manual, these checks are relatively easy to perform. The manual will give you specs that can be used for go or no go testing.
Aug 21, 2011 | Garden
Have a Miller big 40 welder and the engine won't turn over
I'm not familiar with this particular unit--do you mean to say that the cooling system froze during the winter? If so, and the engine has overhead valves, the cylinder head, block, or both may have cracked causing water to leak into the cylinders which would have rusted the rings and cylinder walls (together). You are looking at major overhaul or even engine replacement (not what you were hoping). Good luck!
May 12, 2010 | Welding Tools
My 88 model big 40 isnt generating. where do i start
check you gfci outlets first those seem to go.
Nov 21, 2009 | Miller Welding Tools
I HAVE AN OLDER MILLER BIG 40 RUNS BUT NO WELD OR AC POWER
check the ground ,make sure is tight.look around the machine and see if theirs a switch or a nob to turn from mig to arcweld...
Oct 25, 2009 | Miller Welding Tools
Welding Tools Logo
63 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
