Question about Abit NF8-V Motherboard
Trying to install Windows XP SP1 onto HD with this Motherboard. System will not boot from HD to start install.
  • Keith Gee
    Keith Gee Nov 19, 2009
    Making sure the cable is connected is basic repair and yes, it is connected properly. Ive been building computers for 10 years and know about Master/Slaves. The only reason I'd go into the BIOS is to see if the computer sees the HD and it does. Boot order will not affect anything other than to tell the computer where to boot from. All beginner ideas.
    Ive been to the Abit website and they suggested I boot from the MoBo install disk but my computer doesn't see the disc as such. When I looked at the files it did not look like it could boot anyway.
    Microsoft wasn't much help either. They suggested I go to the i386 folder and run Winnt.exe but that failed to work too.
    I heard win XP doesn't see HD bigger that about 127 GB or so (was using a 320GB) - so I bought an 80 GB HD.
    Either the XP disc isn't copying the right files to the HD or there is a strange reason why I can't run Winnt.exe
    I only wish there wasn't a power surge in the first place...
  • Keith Gee
    Keith Gee Nov 22, 2009
    The motherboard that took the power surge was already in the recycle box when I presented this question. I bought another working Mobo of the same type. I have already tried to find manufacture information and what they gave was of no help. The info said to boot from the utility CD but this failed. I looked on the CD and could not find any indication that booting from it was even possible. I suppose I could use FAT to set things up but to get the full use of XP I would then have to convert to NTFS once things are set up. Further searching on the internet has told me that the Mobo uses NvRaid and I have info on how to install this driver. The reason I brought this up was that I was hoping to find someone who owns this same type of Mobo and see if they had the same problems trying to install XP...
    President:
  • 2,351 Answers
Make sure your IDE hard disk drive is connected to IDE1 port and that the data cable is fully connected. Also check the jumper on the IDE drive. If you are using only one IDE hard disk drive set the jumper on the drive as a Master without a slave. If you are running two IDE hard disk drives set the primary drive's jumper as a Master with a slave. Set your second IDE disk drive's jumper as a slave. The master drive should be connected at the end of the data cable and the slave drive should be connected to the next data connector. Than check your bios settings. Power on the system and press the Delete key every 2 seconds until the bios menu loads. See page 3-1 in your manual. If you need the manual for the NF8-V MB click on the link provided below and download it;
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF8-V&fMTYPE=Socket+754
You'll also need the program Adobe reader to view the manual. Adobe reader is a free download; http://www.adobe.com/products/reader/
Once you’re in the bios go to page 3-4, Standard CMOS Features.
Follow the instruction listed for IDE HDD Auto-Detection. Your HDD should be listed here. Than see page 3-7 in the manual. Open Advanced BIOS Features. A normal boot menu for the Abit would read;
First boot device Floppy disk drive (If one is connected). 2nd boot device should be (CD-ROM/DVD-ROM). Third boot device should list your primary hard disk drive's (Model number). Load your windows CD into your CD-ROM drive.
Once the settings above are set, press the F10 key to save your changes and exit the bios. Your system will auto restart. Windows should begin to load.
Cheers!
Mike
Posted on Nov 19, 2009
  • Mike Peluso
    Mike Peluso Nov 21, 2009
    When answering questions from user's it is important to know all facts. You failed to include the MB experienced a power surge!
    However, if the bios see's the hard disk drive and you are using Windows XP with SP1. Windows should see your entire 320GB drive. Suggest you download the manufactures bootable utilities/tools software and setup the drive "from within a Dos like mode".
    Their software will allow you to set the HDD up. Set the cluster size and FAT. If you are unable to do this with the drive connected to IDE1, try using IDE2 port. I have found, 9 times out of ten one can set up their drive with the manufactures software far better than windows can. If this option still fails than the power surge may have impaired your MB.
My pc says"boot failure,insert boot diskette in A"
If XP was not installed on the HD from your computer then the computer won't boot from it. Reinstall it.
The system may not see your HD. As you boot, go to the boot menu and see if the HD is listed. - If it's not, see if the HD is well connected to the motherboard. - If it is then re install XP.
Sep 16, 2011 | Microsoft Windows XP Home Edition
I have an windows vista and receive always error:ox8000FFFF when trying to install SP1
make sure you bring your system in clean boot. Uninstall you security software. Install SP1 and then install your secuirty software.
Make sure you turn off your system for five minutes before you start installing SP1
Mar 22, 2011 | Computers & Internet
Hd audio device driver wont load on my intel dg31pr motherboard. downloaded latest driver for xp. running a dual boot and it works fine with windows 7.
fristly check which operating system you are using is compartable to your motherboard drivers many mother boards drivers does not support xp sp1 it may the effect of lowest version of window
Apr 08, 2010 | Intel Motherboard
Can't install windows XP on a new 500GB Hard Disk
go to the manufacturers website and see what bios updates there are ? If any relate to recognizing hard drive capacity then it will be worth while installing the update onto the motherboard.
If not then check your motherboard for enabling LBA and if you read the manual it should explain what each option is for.
Also might be worth while slip streaming your xp installation disc with the sata drivers for your motherboard ( the sata drivers you can get from your motherboard manufacturers website, download and extract them and then use nlite to combine the sata drivers with the xp disc and re burn the xp disc ensuring to make it bootable )
Nlite website
Seeing as you are combining drivers it may be worth while getting all the other drivers ie network card, graphics, audio etc and combing that with your bootable xp disc.
Apr 11, 2009 | Intel Motherboard
Problem installling Windows xp SP2 with P4VMA-M Mainboard
If your trying to install it over the current installation then select Format at the installation screen of XP setup. In order to do that you would have to boot from the disc, that way you don't have to load windows. Also when you have completed and installed XP, try to locate some software to detect what drivers you need. I use driver detective and it worked fine for me, or alternately send me a message and ill run you through how to check the motherboard for the version manually.
Mar 09, 2009 | Biostar P4VMA-M Motherboard
Won't boot from 500GB SATA drive
Windows XP original support up to 137GB
Windows XP sp1 support up to 250GB
Windows XP ps2,3 have not change.
you have to enable 48 LBA in order for the system to recognized the drive.
the exact porcedure is list in the link ;
http://support.microsoft.com/default.aspx?scid=kb;en-us;303013
Nov 17, 2008 | EliteGroup PM800M2 Motherboard
ECS 761GX-M754(V3.0A) Motherboard, No Graphics Acceleration in Xp
Were the correct drivers installed into XP.
It seems to me no video drivers are in XP and you are running on the windows ones
Nov 12, 2008 | EliteGroup ECS 761GX-M754(3.0A) Socket...
2 hd
Leave the other drive in; no the other windows will not cause problems cos its not set as boot 'C' drive, you can deletewindoes off the drive or format it within windows.
I don't think that the drivers you installed are the cause of the boot problem it may be the other drive, remove old drive and try again, but make sure in the bios (F2 or Del on boot up) it is correctly recognising the new drive.
delete this path:
multi(0)disk(0)rdisk(1)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Aug 29, 2008 | Microsoft Windows XP Professional With...
Shuttle mv43n v3.1
The problem is your motherboard itself. There is a short somewhere in it and is wreaking havoc on your attempts to get a system running.
I recommend getting your board exchanged if you're under warranty.
Please let me know if this helps. Good luck!
Mar 01, 2008 | Shuttle MV43N Motherboard
Abit NF8-V Motherboard Logo
171 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
