Question about IBM ThinkPad T20 2647 Notebook
Thinkpad screen displays only the top half of the picture. Cannot access start up menu
  • 56 Answers
Goto display setting you can fix it from there. for any other problem send me an email [ ariftariq12345@gmail.com ]
Posted on Nov 19, 2009
Bad home key on thinkpad g41 keyboard is there an alternate way to increase brightness?
Try using Thinkvantage Application to adjust as follows:
ThinkVantage Control for Display Brightness
  • 4 Click the "Start Menu," then click "All Programs" and locate the "Access IBM" program group.
  • 5 Click "Thinkpad Configuration" and click "LCD" to open the brightness control dialog. Select the brightness from the drop-down menu and click "OK."
  • 6 Click the red "Exit" button in the upper-right corner of the Configuration utility to close it.
Read more: How to Adjust the Brightness on an IBM ThinkPad Display ' eHow.com http://www.ehow.com/how_5818403_adjust-brightness-ibm-thinkpad-display.html#ixzz277iQ4g48
Sep 11, 2012 | IBM ThinkPad G41 Notebook
Why is my screen opening at half screen?
not sure what half screen you are referring to
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
on the top of the internet page you should see some tabs file edit view favourites tools and help click on the view tab on the drop down list you should see a zoom size %
click a different percentage also a text size you might try a different text size although this will not increase the size of the page only the text fonts inside it
if you do not see these tabs in the top toolbar
right click in the top toolbar you will see a number of toolbars and options select the menu tab this will add at it to the toolbar
or if its actually half of the screen
you will need to connect to another monitor or your television to your computer with the vga lead monitor connection
click start control panel display change display settings adjust resolution this may vary depending on your operating system
you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system
when you select the no 2 tab this should be the extended desktop always click apply after making any changes
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
if you can get an extended desktop your monitor is faulty
if you cant get an exended desktop
hope it helps
Aug 09, 2012 | HP Computers & Internet
How to lighten the screen on the desk top of my IBM computer to be able to read what is on the screen tgo dark
if you use Windows Vista or Windows 7
go to START, Control Panel, click on EASE OF ACCESS, OPTIMISE VISUAL DISPLAY
scroll and adjust accordingly
please leave positive feedback for me
Oct 17, 2010 | IBM ThinkPad R51 Notebook
My T23 IBM enters splash screen,but will not enter the bios page.
While the "To interrupt normal startup, press the blue Access IBM button" message is displayed at the lower-left area of the screen, press the F1 key. The BIOS Setup Utility menu will be displayed.
Jan 22, 2010 | IBM ThinkPad T23 2647 Notebook
How do I put new windows on the thinkpad I have got the cd
this is sometimes due to the boot sequence. identify the key to press so that you can access its bios at start up. a shot message is usually displayed for a short time at start up.
please go to the bios and change the boot sequence to start from HDD.
Dec 18, 2008 | IBM ThinkPad 600E 2645 Notebook
Replace LCD screen
All modern thinkpads are similar, you start by taking apart keyboard and top cover, then you unscrew hinges and remove screen. Here is some movie:
Thinkpad LCD Removal
Removing Thinkpad 600 Series Display - Part 1
Replacing Thinkpad 600 Series Display - Part 2
IBM ThinkPad R40 -- Fixing the black-out LCD Screen
This is not an easy job, there is risk to cause further damage to your laptop if you do not have enough experience.
May 28, 2008 | IBM ThinkPad T60 Notebook
No picture on plasma
Service time! Get quickly to the retailer or service port for what ails this set...accordianman
Mar 04, 2008 | Televison & Video
Dozens of horizontal lines across display!! HELP!!!
Bring up the menu and if the lines are not on the menu replace the small signal board that is your video prossor. If the lines are still the replace the Y main board that contrl the top half of the screen.
Feb 10, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Flat panel displays half screen, mirrored on bottom half of screen
Have several problems with either a bad LVDS cable from Main unit to the LCD controll bd. Sometimes the cable is just not connected properly. If you reseat this cable and the problem still exists you most likely have a bad LCD control bd.
Jan 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
IBM ThinkPad T20 2647 Notebook Logo
57 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
