We have a Proscan tv that the screen looks like a ''strobe light'', flickering all the time...can this be fixed?Also, a lost remote. When I contacted a tv repair place, they told me throw the tv in a dumpster, Proscan went out of business and there are no parts available. I see that KMart sells this brand..
  • 11,361 Answers
Do not go to that TV repair place again!!! Thet are still in business.
PROSCAN WEBSITE: http://oncorpus.com/
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 19, 2009
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
My coby flatscreen comes on and works but strobes flashing light but works good just with strobing light ! whats going on?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Feb 22, 2015 | Coby TFTV4025 40" LCD TV 1920x1080, 60 Hz,...
Proscan 40LC45S screen flickers, red light flickers, won't turn on
check bad component parts at the power supply board as will as burnt parts.
Sep 07, 2012 | Proscan 40LC45S 40 in. LCD TV
My tv keeps flickering like a strobe light, how do i fix it
Hi,connect the tv to a stablizer..dont connect it direct from power source and make sure you place it in a place where enough air can reach it.
Jul 31, 2011 | Proscan 42LA30H 42 in. LCD Television
I have a 42" Proscan
It sounds more like a backlight problem to me. The first thing I would try before tearing the set apart is simply unplugging it for about five minutes and plug it back in. TV's do weird things sometimes and need to be reset. Odds are, if you have to open up the TV, there's not a whole lot you can do anyway. Check the backlight on signal and also see if your inverter is working. I would suspect that if you're strobing your backlight is probably dying. In that case all you can do is replace the panel; you could try finding a replacement backlight and installing it, but I wouldn't advise even trying this. Replacing backlights is quite a task if you're not familiar with televisions. Anyway, best of luck.
May 01, 2011 | Proscan 42LED55SA 42 in. LCD TV
TV IS BLINKING LIKE A STROBE LIGHT AND WONT STOP EVEN IF I UNPLUG IT AND TRY IT AGIAN
Please make sure any device that is connected to the tv is disconnected.
Unplug the tv for 2 minutes. This will ensure all mechanics in the tv are given enough time to reset.
Plug it back in.
If the tv still strobes let me know.
Nov 20, 2010 | Proscan 42LA30H 42 in. LCD Television
FLICKERING BACK LIGHT
Sounds like you have an LCD tv with backlight problems. Check power board for domed capacitors and replace them. next check connections on the inverter boards. they are on the sides or just one side. Becareful there is high voltage output from these boards. If the cable from inverter board is not good to the screen you can get a strobing. the inverter boards may need replaced. or cales to screen may be bad. The panel also could be bad.
Mar 25, 2010 | Televison & Video
PROSCAN 42' LCD COLOR TV MODEL 42LA45H
I am sorry Sir, the display panel is bad. If you purchased it new, it should under factory's warranty. Please call Proscan for a warranty repair.
Proscan Customer Service:
1-800-968-9853 (US and Canada)
May 31, 2017 | Proscan 42LA45H 42 in. LCD TV
Problem with proscan 19LA25Q
Watching a movie tonight...and slowly there was odd behavior from the screen. No volume at first, then flickering, fragmenting and now, as the others only shows the red power. I have noticed some strange flickering the past 2 weeks or so. I thought it may be the cable, so did not concern myself too much. I believed that was the problem tonight as well. But the screen is definately not responding to the remote or manual button.
Thanks
Mar 16, 2008 | Proscan 19LA25Q 19 in. LCD Television
Televison & Video Logo
550 people viewed this question
Top Televison & Video Experts
Electro Med Services...
