Question about Sony Video Cameras
Sony CCD-FX311 Video 8 Handycam: will not close with tape in the compartment...makes a screeching noise & kicks the tape out.
welcomejee
  • 10594 Answers
SOURCE: SONY HANDYCAM MODEL CCD-FX730V
Its arround 1993 model camera and part supply has an end by Sony. Problem is Capacitors mounted on boards. If you can change them, go ahead.
Posted on Aug 03, 2008
mukund_ce
  • 186 Answers
SOURCE: I NEED INSTRUCTION MANUAL SONY CCD-TRV47E SONY HANDYCAM
Search manual from here :
http://www.sony.co.in/support/SupportModelSearch.action?site=hp_en_IN_i&sectiontype=support
Posted on May 15, 2009
SOURCE: How do I hook up a Sony Handycam Video 8 CCD-TRV41 NTSC to view on television?
The connector for video/audio is located under a cover next to the red Start/Stop button on top, near the lens. If you don't have the right cable, they are available at Best Buy for example. There are analog outputs only, if you want to capture on a computer you'll have to get a video capture device for the computer. I use Pinnacle. -Stan
Posted on May 22, 2009
satavlad
  • 405 Answers
SOURCE: Sony Handycam CCD-TR64 cassette door won't close
Common problem with this mechanism. In order to fix the problem you will have to replace part called CHASSIS LS. Expensive repair, probably not worth the effort.
Posted on Dec 04, 2009
Testimonial: "Thanks. We ended up getting a new camcorder. That Handycam was as old as I am (18 years), so it was time for an upgrade anyway."
SOURCE: I have a Sony Handycam Video 8 ccd-TR330E PAL.
how to transfer video to computer, any cable ? raymonddcrus@yahoo.com
Posted on Aug 31, 2010
Sony video handycam ccd fx420
The take up spool is no longer working. Time for a new V8 machine.
Jun 10, 2017 | Video Cameras
Tape door won't open or close to release tape
Sony Handycam CCD-TRV58 Hi-8 Analog Camcorder
1. Per the manual on esupport.sony.com
- if the power is disconnected door won't open, and if the battery is the dead the door won't open.
Plug it in and hopefully you can get the tape out.
Did this work?
Feb 11, 2013 | Sony Handycam CCD-TRV58 Camcorder
Handycam CCD-TR618E Hi-8 Analog Camcorder: I have a Sony Handycam CCD-TR61. It has worked fin...
that is look to be the cassette in switch
located on the side of the cass housing
or a sensor ...
hope that will help and this kind of trouble
is easy to fix for experienced tech an hour max
hope you will find one
regards Alan
May 18, 2010 | Sony Handycam CCD-TR618E Camcorder
HELP, I have borrowed an older camcorder from a friend. A sony Hi8 CCD-TR101 handycam. My child put the tape in backwards and now it wont eject. What should I do??
Tape can not be inserted backward in.It is impossible to to insert cassette inside video wrong way.
If it is not ejecting its eject switch might have got broken by physically pulling its cassette compartment outward before closing last time.
Its mini switch is very fragile in all sony models. so only way is to take to technician to bring it out.If i were you,I would buy used one from ebay at lower price than repairing.
May 07, 2010 | Sony Handycam CCD-TR87 Camcorder
Sony 8 MM HaNDYCAM PROBLEM
Yes It Is Possible.
1. Cable options you can use S-video or RCA.
2. VHS payer that has a recording option. Make sure that it supports the Sony Handycam 8mm.
3. The procedure on how to transfer the 8mm to VHS is the same as how you view your video on the TV.
4. S-video or RCA should be connected on the Handycam and the other end is on the TV.
5. You can follow the instruction on page 27 (Sony Handycam CCD-TRV37)
6. You can also follow page 52 (Sony Handycam CCD-TRV37 )
Go to this Link for the user manual and the full instraction on how to connect the cables.
http://www.derrybryson.com/manuals/Sony/Analog%20-%208mm%20&%20Hi8%20Camcorders/CCD-TRV57.pdf
Apr 03, 2010 | Sony Handycam CCD-TRV37 Camcorder
Sony ccd trv43 doesn't play hi8 after placing an old video 8 tape
Try to clean video head with cleaning cassette, if same position than video head need to be change
Mar 28, 2010 | Sony Handycam CCD-TRV43 Camcorder
Tape door will not stay closed. shut tape compartment door...runs for 3 seconds...reopens.
It is possible on the CAM mode the tape reached to the end, or this is
typecal problem from Sony the sensor it detecting 2 reels to turning the tape were faulty.It require to replace the cassette compartment or it call LS chassis assy. It will cost about $200, $250 in Australia to repair it
Jan 08, 2010 | Sony Handycam CCD-TR96 Camcorder
Dec 04, 2009 | Sony Handycam CCD-TR64 Camcorder
I have a sony Handycam videoHi8 camcorder, my problem is that it
Try using different tape or a new tape in the Camcorder.
Clean the video heads using the Sony V8-25CLD cleaning cassette.
You may also try pressing and holding the Reset button for 30 seconds to reset all the settings in the unit to the factory defaults.
Good luck!!!!!!!!! !!!!!!!!!
Sep 19, 2009 | Sony Video Cameras
Aug 03, 2008 | Sony Video Cameras
Video Cameras Logo
269 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
