Question about Welding Tools
Miller welder starts fine bur appear to run out gas need help adjuting linkage to fuel control
  • flo flo Nov 18, 2009
    replaced carburato need help with adj. and gav adj
  • 3,600 Answers
You need to adjust the throttle governor on the side of the carburetor you will see a adjustment screw do a weld to get the welder to runs at high speed then adjust the screw till it runs continuously, if it still dies out change the fuel filter and try again drain the carburetor bowel if it's diesel replace fuel filter and run fuel threw the water trap.
Posted on Nov 25, 2009
I have a 2007 miller bobcat it has spark cleaned carb new plugs new filter and it won't start
did you try a touch of starter fluid in the carb just to verify that the engine is getting spark? ethanol gas... if it hasn't run in a few months and you left the gas in it... you better revisit the carb cleaning
Dec 13, 2015 | Bobcat Miller 250 Welder Generator 907212...
My miller blue star 185 wont idle up when you start welding
Check your idle control module,
take the roof off of your welder, located at the top right of the inner control panel, it is the little red box with multiple white leads connected to it and labeled with alphabet letters.
pull the connectors, insure they are clean, reconnect them, start your welder and see if that corrects the problem, if not, you will need to purchase a new idle control module
Feb 25, 2015 | BlueStar Miller Bluestar 185 Dx Gas...
My miller 225 welder will crank but not start, no spark, i tried jumping the oil psi sensor. what do i do next?
I had a problem like this a few days ago try taken of the air filter to were u can see the choke it may not be opening rite just cause it opens don't mean itsnot opening rite get a small spray bottle put gas in it and as u start ur welder spray the choke with with the gas a lil if it starts turn ur switch to run for while it workd for me if that don't maybe change the spark plugs
May 20, 2012 | Bobcat Miller 225 Welder Generator 907209...
I have a miller trailblazer 301 G . my problem is that i turn the start switch to run and it doesnt run in high speed. this welder only has 24 hours on it.
i have the same machine, had same problem, changed broken springs on carburator and choke, problem gone. air gas ( authorized service tec. showed me how)
Jul 19, 2011 | Miller Trailblazer 302 Welder Generator...
Miller syncrowave 250 tigrunner with gas flow
Your problem is in one of two areas. The controller board inside the unit or a bad trigger on your gun.
Nov 25, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Welding Tools Logo
100 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
