Question about Canon imageRunner C3100 Copier
I have error code e000020-0081 on a conon c3100 copier
The copier need toner cartredge
Posted on Dec 14, 2011
  • 78 Answers
Take drum out and clean patch sensor you may need a new drum
Posted on Nov 30, 2009
2 Suggested Answers
canontech
  • 1219 Answers
SOURCE: I have error code e000020-0081 on a conon c3100
You need to clean the image patch sensor, wich is located above the drum unit in copier.Use a lint free clotch.
OR, how many copies do you have with your drum? If over the 60000 replace the drum unit.
Posted on May 03, 2010
How to repair kyocera 1024mfp error code c3100
http://www.fixya.com/support/t6140540-also_need_service#solution-section
Feb 14, 2015 | Kyocera Office Equipment & Supplies
Error C3100
This code means machine's scanner home possition error. Try to check scanner home possition sensor if fixed in its possition. if not try to check scanner lamp unit movement .
Jan 20, 2013 | Kyocera FS-1035MFP
Canon Imagerunner C3100 shows error code E00012-0001
Drum motor error
Check the connector and replace the motor
Jan 17, 2013 | Canon imageRunner C3100 Copier
When i get my c3100 started i get an error code e 000013-0000 . can you tell me what the problem is
Waste toner bottle full, open front door, one screw, make sure small cut out in the neck of the bottle is clean afterwards.
Oct 31, 2010 | Canon imageRunner C3100 Copier
I am geting an error code of c3100 call for service I am geting an error code of c3100 call for...
C3100 Scanner carriage problem
The home position is not correct when
the power is turned on or at the start of
copying using the table.
Poor contact in the
connector terminals.
Check the connection of connector YC4 on
the scanner PWB and the connector on the
scanner home position switch, and the continuity
across the connector terminals. Repair
or replace if necessary.
Defective scanner
PWB.
Replace the scanner PWB and check for
correct operation.
Defective scanner
home position
switch.
Replace the scanner home position switch.
Defective scanner
motor.
Replace the scanner motor.
The mirror frame,
exposure lamp, or
scanner wire is
defective.
Check if the mirror flames and exposure
lamp are on the rail. And check the scanner
wire winds correctly.
took this from a diffirent kyocera copier but it will be the same scanner related code
Oct 13, 2010 | Kyocera Copystar CS-1820 Black and White...
Apr 20, 2010 | Canon imageRunner C3100 Copier
What is Canon C3100 error code E000008 0001
The reading of the fixing roller life counter has reached its upper limit.just reach the counter reading at svc mode.
Mar 06, 2010 | Canon imageRunner C3100N Copier
U4 error code - Xerox 5328 copier
U4-2 Low fuser temp problem U4-3 High fuser temp problem U4-4 High fuser temp problem U4-6 High fuser temp problem
replace thermistor in fuser unit
Oct 03, 2008 | Office Equipment & Supplies
461 people viewed this question
old marine
old marine
