Question about Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
Flahes from FL to the temperature (13) after refiling. Temperature level will also not increase.
  • 366 Answers
FL is usually a flow sensor/switch fault. If you have just filled the tub, the pump may not be properly primed. The best thing is to fill the tub through the skimmer when you first start filling it, that ensures the pump is filled with water and is not air locked. You may have to force water into the skimmer to push the air out of the line or loosen a union on the discharge side of the pump to get it primed. FL will not let heater run because it thinks that there is no flow.
Posted on Nov 19, 2009
Temperature light on and off
Check coolant level. If low, refill and check for leak. If coolant level is good and coolant is flowing thru radiator, trace the temperature wire for a short against the engine. If the wire is good, replace the sensor.
May 20, 2017 | Cars & Trucks
Tempature doors on rear hvac module
Does the temperature increase when the hvac is on? What model is it? You will need to include further information.
Elisa Jed ' http://www.metroair.biz/Air-Conditioning-Services-Heating-Services-Largo-FL.html
Mar 14, 2014 | Dodge Grand Caravan Cars & Trucks
Temperature at 10 power level
It does not work that way. The microwave OVEN generates (electromagnetic) microwaves that are absorbed by the molecules of the food in the oven, the container and the air.
The absorption rate depends on the molecular composition. After enough microwave energy is absorbed the overall temperature increases and the food is warmed, heated or cooked. If your mixture is inhomogeneous some parts absorb more energy while other absorb less and you can have hot spots.
The power level by itself won't give you an indication of the temperature because you need to know the time that the power has been applied. In simple terms Energy =time*power. The temperature reached is somewhat proportional to the energy, that makes it dependent on the time and the power.
Dec 22, 2013 | Haier MWM0925T 0.9 cu. ft. Microwave With...
Temperature in degree centigrade at 10 power level
What temperature should a refrigerator be
there are different levels they do not indicate temperature but level 4 I find is the best setting .If you have a side vy side It helps to keep the freezer well stocked .this increases the temperature for the fridge side.
Jul 27, 2012 | Whirlpool Refrigerators
Which side ofintake manifold does temperature gauge sending unit go on
Water Temperature Indicator Sender Unit
The water temperature indicator sender unit is installed on the engine into an engine coolant passage. The water temperature indicator sender unit reacts to the engine coolant temperature. Its resistance decreases as the engine coolant temperature increases.
Water Temperature Indicator Sender Unit Removal
swb~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not mix Standard (green) Coolant with Extended Life Coolant (orange). If mixing occurs, drain engine cooling system and refill with originally equipped coolant type. If this contamination occurs the service change interval on Extended Life Coolant will be reduced from 6 years/150,000 miles to 3 years/30,000 miles.
  1. Partially drain engine cooling system as described.
  1. Disconnect engine control sensor wiring (12A581) from water temperature indicator sender unit (10884) .
  1. Remove water temperature indicator sender unit.
Jul 30, 2010 | 1998 Ford Mustang
I have a code P0128, what is my problem is this in the cooling system?
This code is for your Coolant Thermostat - It's detected that the Coolant Temperature is below the Thermostat Regulating Temperature
This code may mean one or more of the following has occurred:
  • Low engine coolant level
  • Leaking or stuck open thermostat
  • Cooling fan running too much
  • Faulty coolant temperature sensor (ECT)
  • Faulty intake air temperature sensor (IAT)
Check the following to see if it resolves your problem:
  • verify coolant strength and level
  • verify cooling fan operation and replace if necessary
  • verify ECT sensor operation and replace if necessary
  • verify IAT sensor operation and replace if necessary
  • if all above checks out, replace the thermostat
Oct 16, 2009 | 2002 Buick Rendezvous
1998 VW Passat How do you check and fill transmission?
There is a drain plug on bottom of transmission and you need a lift. Vehicle needs to be lifted, and ran to operating temperature. With vehicle running, level, and at operating temperature, remove drain plug and fluid should steadly leak out. To fill you need a pump to pump fluid in from bottom. Thanks
Jun 08, 2009 | 1999 Volkswagen Beetle
Performance issue
Did you check the ignition timing of the engine before you fire it up? Increase in temperature with increase in load is usually caused by retarted ignition timing.
Apr 17, 2009 | 1995 Suzuki Sidekick
Adjust temp level of the oven .. model 34ja-5tkxw
Press the bake key.
Adjust temperature to 550 degress.
Press the bake key again and hold it for 3 seconds.
The temperature +/- should appear.
You can then adjust temp +/- 35 degrees.
Mar 24, 2008 | Magic Chef CER3725AA Electric Kitchen...
Qca Spas Dream Series Dream Master Hot Tub with Flex Cover Logo
670 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
