Question about Philips Magnavox Learning Universal Remote
Change channels on philips magnavox tv , model pr1904b101
  • 1694 Answers
SOURCE: Magnavox TV
Bad IC inside tuner = replace tuner..............................T.
Posted on Nov 18, 2007
SOURCE: Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
how to get capation off my philips magnavox tv with remote can not make remote to go up or down . what buttons do i use help
Posted on Jun 13, 2008
rulds2008
  • 3866 Answers
SOURCE: change input source for philips magnavox
use the up/down channel until you get to the input you have connected. You did not say you had a remote so i am using the standard fix for this.
Thanks
Posted on Apr 28, 2009
SOURCE: Need Unlock channels
I called Philips Magnavox at 1 888 744 5477 and they told me the default ACCESS CODE number is 0711. It works on my TV though it didn't solve MY problem of the TV defaulting to Chanel 9 every time I turn it on. Drats. Hope this helps.
Posted on May 18, 2009
  • 59 Answers
SOURCE: Philips HD tv has no picture
common fault this , normally the fuse has failed on y-main board due to shorted thick film unit
unfortunately its not a cheep repair job.
Posted on Aug 18, 2009
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
TV stuck on one channel will not change? help
Go to http://www.m4c.magnavox.com/ then click on product support, select your model, then click on software and downloads. Download the latest software release for your tv and follow the instructions for installing the software.
Aug 09, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
TV keeps shutting off and changing channels
hide all your remote controlls and put some tape over the front cover of the tv where you think the remote control reciever may be , if this fixes it then it means something is amiss with a rogue remote , most likely batterys..could even be sunlight ??
Jul 03, 2009 | Philips Magnavox 27MS343S 27" TV
My t.v. will not auto install the channels with my antenna.
Try the link.It may help.
http://www.ehow.com/how_2378904_ready-change-digital-tv-broadcast.html
Jun 01, 2009 | Philips Magnavox 27MS343S 27" TV
Change input source for philips magnavox
Thanks
Apr 28, 2009 | Philips 19PR19 19" TV
Magnavox PJTV model 51mp392/17 -pressing channel buttons changes
You need a professional.
Your TV has "lost is mind"
Stop using the TV until it is repaired.
Continue to use it and your problems will multiply and grow more expensive.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Philips Magnavox 51MP392H Rear Projection...
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Feb 03, 2008 | Philips Magnavox Learning Universal Remote
Philips Magnavox Learning Universal Remote Logo
166 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
