Question about KitchenAid 32685 Mixer
K45SS cycles on low speed, then has only one higher speed
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 143 Answers
It sounds like you may have an issue with either the governor assembly and or the main control. If the speed you are getting is constantly going up an down in RPM then this could indicate that the governor has simply become worn and its resistance is gone. If however you get no speed at all and then all of a sudden you get a high speed then it will most likely be the main control. Part number for the governor assembly is 17830. Part number for the main control is 240904−2. Both are relatively simple and cheap to replace. Hope this helps
Thanks
Posted on Nov 19, 2009
  • SAP Smart Dec 28, 2010
    Or it could just be a disconnected wire - open the back and make sure all the wires are connected - one of mine got loose and was working only on speed 10 and then it stopped...I just reconnected the wire - very easy as the wire has a little clamp on the end and you just have to slide it back on the the board
I bought a brand new Artisan Stand Mixer 3 years ago and just opened the box this week. When I plugged it in and turned it on, it works for a few seconds then shuts off on the stir-4th speeds. The 8th-10th speed works okay. What should I do?
Posted on Dec 06, 2009
KitchenAid mixer speed surges high and low uncontrolably
You can get the high speed back if you want to play with those three screws. there is a timing scheme for your mixer and it is set and adjusted by manipulating those 3 screws. The bottom center screw is for speeds 6 8 and 10. The best choice is to replace this switch, about $10 bucks on ebay.
Nov 13, 2012 | KitchenAid K45SS Classic Stand Mixer
Mixer doesn't work on all speeds
First the K45SS does not have a hall effect sensor. the pro series the epicurean seines and the pro series 5 use them, The K45ss system uses a phase control board a speed control plate and a governor for speed control. the governor rarely goes out the phase control board is a likely culprit but the system would work only in high gear if it was bad. I agree with the guest above in that it sounds like the retaining nuts on the adjusting screws of the speed control board have worked themselves loose and the adjustment screws themselves have vibrated out of proper position.
Sep 20, 2012 | KitchenAid K45SS Classic Stand Mixer
My kg25h7x varies the mixing speed on its own
The Kitchenaid uses a centrifugal switch to maintain a constant speed. This must be sticking to cause this. You mixer will need to be disassembled and inspected.
Jul 03, 2012 | KitchenAid K45SS Classic Stand Mixer
We have a K45SS mixer problem. When it is on the lowest setting it hums and the beaters barely turn. The next setting up has a noise but the higher speed settings work just fine. What is the problem?
the lower setting is for stirring. this is a high quality machine that is made to take a beating. you are just hearing the motor wind up. think of it like a jet engine starting, its made to run its smoothest at high rpm's, so it sounds funny at low rpm's but nothing is wrong with it.
Dec 20, 2011 | KitchenAid K45SS Classic Stand Mixer
I have a Hobart KitchenAid Mixer Model K45SS and it runs fast on low (Surges speeds up and down)what is causing this problem
Hello Mayfix,
The problem with your mixer is the speed control switch, this switch is located at the back of the unit. It is usually black and has all of the wires coming into it, the Item # 1394070 and cost $27.95 it can be located at RepairClinic.com he is a link
http://www.repairclinic.com/Kitchenaid-Switch-Parts?z=100&gclid=CKSD5NriuKcCFUVqKgodIE2b_g
You will have to adjust after you install you will adjust the two screws at the top of the switch while the machine is running inorder to make sure that you are getting all the speeds. Be careful as there is a possibility of electrical shock if you touch the wronge thing.
Thank you for using FixYa.
Jul 04, 2010 | KitchenAid K45SS Classic Stand Mixer
My K45SS started making a VERY loud noise when in use, and the lowest and highest gears don't work. Machine is about 20 yrs old.
This sometimes happens when the two nuts holding the motor in place become loose. To check, open up the back and move the foam around the edge to see the two nuts. Tighten them if they are loose. If the low speed still does not work, the screw adjustment at the bottom of the control plate may need adjustment.
Jan 25, 2010 | KitchenAid K45SS Classic Stand Mixer
My Kitchenaid mixer (k5ss lift bowl?) smells hot
I think you have a K45SS. It sounds like there is a problem with one of the gears, probably the worm gear. The worm gear is designed to be the first to fail if the mixer has struggled with a heavy dough or other difficult to mix substance. The best way to establish the cause will be to open the head up and check the gears for signs of damage.
Jan 25, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Question regarding KitchAid mixer, Model K45ss. excessive noise.
Maeveda, Congratulations on your 30 year old KA mixer! Was it a wedding present? Do you still have the K45SS Parts List? If not, you can download a PDF version from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number (in your case, use K45SSW select Parts List (1) and then check to see it this matches your mixer). You can check on page 4 & 5 for the disassembly and reassembly of your mixer, along with all the parts. It will be messy but gratifying. Once apart you can check for any other unseemly wear and tear on the gears, etc.
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com (this vendor the best prices for my wife mixer's parts, but sadly they had to back order them, which was disappointing to SWMBO). Prices for the same part vary widely between vendors, so do your comparison shopping. Here's a link to a site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html
Good luck and have fun. I hope this helps. Howard, Burke, VA
Nov 02, 2009 | KitchenAid K45SS Classic Stand Mixer
K45ss kitenaid mixer surges at low speeds
Hi. Go to mendingshed.com and download their free Kitchenaid Service Manual. This valuable document will help you to tune up your mixer, and covers the K45SS model. They also sell kitchenaid parts.
Go to kitchenaid.com and search for a parts manual for your mixer. Enter your model# thusly k45sswh.
If this solution has assisted you, please rate it. Good luck! ricardok45.
Apr 12, 2009 | KitchenAid K45SS Classic Stand Mixer
KitchenAid 32685 Mixer Logo
367 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
