Question about Singer Sewing Machines
My singer sewing machine won't run...first it would stop and then a bit later run again...now, nothing---could it be the belt? or a short in the wire? or the pedal?
SOURCE: need manual for Singer sewing machine model#100, about 12 years old
I have a manual for this machine..is there something specific you needed to know from the manual?
Posted on Mar 27, 2008
SOURCE: How to set timming on Singer Touch & Sew 638 Sewing Machine
I have a timing problem with my Touch&Sew Singer model 638.
Jean
rlacasse@ntl.sympatico.ca
Posted on Sep 17, 2008
SOURCE: Beeping Sewing Machine
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
Posted on Nov 03, 2008
  • 4 Answers
SOURCE: Manual for 1908 singer sewing machine
Hi Lorraine
I too have an old treadle machine . What my Dad did for me was go to a Harness repair shop and have them cut a piece of narrow leather and that became my belt, take it home and and replace the belt you now have or you can shorten the one you do have , but not too snug,around the wheels , need a bit of slack,,, join the 2 ends together by using a shape needle or whatever it takes to make the hole in the ends of the leather and use a fine strong wire to fasten the ends to meet, looks rough but it works.
Posted on Apr 19, 2009
  • 43 Answers
SOURCE: NEED MANUAL FOR SINGER IZEK SEWING MACHINE
You can get a free downloadbale / printable copy by goig to http://www.singerco.com/accessories/manuals.html and cliking on the "Free Download!" button to the right of the English version description.
Posted on May 06, 2009
I have a IZEK singer sewing machine, I wound 3 bobbins with it and when I went back to sew it would not work
Sandy, I'm not familiar with IZEK machines, but it sounds like the bobbin winder has not correctly disengaged. Put it back into bobbin winding mode and run it (no need to wind a bobbin, just check that the bobbin winder turns), then stop and disengage the bobbin winder and try sewing again. Hope this solves it for you. If it won't turn the bobbin winder either then it may have slipped or broken the drive belt and you will need to take it to your local sewing centre.
Mar 02, 2015 | Singer Izek Computerized Sewing Machine
My mom's old singer will start sewing then slows down to a stop.
Try loosening the new belt. The object is to put the belt as loose as you can but tight enough that you can stall the hand wheel without the belt slipping. Once you've done that, loosen the clutch and let the motor run freely for a while. Sometimes people put too much oil on the motor. It only needs 1 drop every 10 years or so. Running it for a while lets some of that excess burn off.
Aug 11, 2014 | Singer Sewing Machines
I have a singer 247 it was sewing really good but started going slower and slower til it stopped could it be the motor
It is more likely that a bushing internally warms up then seizes partially. A good cleaning and lubrication could solve this. To test the motor remove the drive belt and run the motor with no load, see if it slows down if not see idea above.
May 13, 2014 | Singer 7462 Mechanical Sewing Machine
Why does my new Singer cg-500 stop working, then start for a little bit and stop again?
Probably thread wrapped around something....takeup crank, motor pully...if you can get inside to have a look great, if not, find someone who can.
Oct 25, 2011 | Singer CG500 Mechanical Sewing Machine
My machine continues to run after i take my foot off the pedal.
Undo the foot control and take out the little square bit called a suppressor which you don't need these days anyway and it should be fine.
Jan 19, 2010 | Singer CE-200 Quantum Futura Computerized...
Hi Lorraine
Apr 11, 2009 | Singer Sewing Machines
Machine No. K1831(256) No.28 how do you set up the stop motion wheel to wind bobbins. It either winds bobbins whilst sewing or just free wheels. I think there must be a way of adjusting this action....
Oct 26, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
136 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
