Question about Indesit W 123 Front Load Washer
How to change the bearing on indesit wil 123 s uk
  • Gayle Stevenson May 11, 2010
    how do u change bearing?
  • 105 Answers
You take the back off then using a 40 torx u take the wheel off, recomend you use a slide hammer not a pri bar, idid and now ive got leaks, so next you take the concrete wieght off then you take the spider shaped support bar it has two bolts on each end its tight but can be done with out moving anyting then you slide hammer the spider shaped bearing carrier off once off you drift the bearings out using a 1\2 " extension bar and a socket and hammer
Posted on Nov 28, 2009
  • maintfit Jan 09, 2011
    I would add to this that to change the bearings you only need to remove the spider,the inner drum is permenantly sealed inside the outer drum. Both bearings are a standad size which can be purchased from any bearing supplier at a cost in the region of £5 each. Most towns
User manual
www.theusermanualsite.com/ex/mfg/.../indesit/.../manual_request
Apr 22, 2009 | Indesit W 123 Front Load Washer
Bearings getting noisy
no need to remove the drum
u just unscrew the screws and spyder wil come and u can change the baring
Mar 07, 2009 | Indesit W 123 Front Load Washer
Indesit W 143 S UK Sounds
either bearings or a foreign object in machine
bearings are a pig to replace on this machine
Oct 16, 2008 | Indesit W 123 Front Load Washer
Indesit wash machine drum bearing
depends on the model that you have some indesit machines you only have to undo the spider and others can be a bit of a pain because you have got too split the drum would recomend an engineer regards jason
Jun 13, 2008 | Indesit W 123 Front Load Washer
Indesit washeing machine
Karen, that was nice.........
May 31, 2008 | Indesit W 123 Front Load Washer
Indesit wil 113
this is a cold fill only machine as nearly all machines today are designed that way to save energy , as you only heat the water that you need
Mar 28, 2008 | Indesit W 123 Front Load Washer
Indesit washer
if you mean the wires that go to the back of the drum from left to right= green circle=brown wire pushon tellow/green(earth) square =2 lite blues yellow circle=dark blue if this isnt what you needed please respecify and ill do my best to answer ,ian if you add to this post it will inform me for a faster reply
Nov 03, 2007 | Indesit W 123 Front Load Washer
We have a indesit wil 143s faulty
the pressure switch should be easy to replace. it will be a round unit with wires going into it and also a small clear plastic tube attached. it is usually mounted around the top edge of the case. i would also check that the pressure system is not blocked (the other end of that clear plastic tube) as blockages may keep pressure at the switch leaving it in the "full position" pop the pressure tube off of the switch and force some air down the tube to check.tony.
Jun 03, 2007 | Indesit W 123 Front Load Washer
Indesit W123s
There is a bearing at the back of the machine that normally goes.don't just replace the bearing.buy a complete bearing kit and replace that.
Feb 23, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
561 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
