Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
My phone works but the display screen is clear. can not access anything even phone numbers. please help. motorola k1m
Need to unlock motorola k1m, cannot find IMEI#, only DEC which has 11 digits
You can find your IMEI number using the *#06* .
It's possible to unlock your Motorola K1m using the codes.
I found unlocking service at Wickedunlock.com .
Once you get the code, you may follow the instructions at Mobileunlockguide.com . This will help you to unlock your mobile easily.
Dec 25, 2011 | Motorola Mobility K1m Cell Phone
My screen is white cant see anything
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
Take care.
Aug 06, 2010 | Motorola Mobility MoroKRZR K1m Cellular...
How do i master reset motorola k1m if i forgot my pass code
Please remember after you finish all of this, you NEED to reboot your phone for everything to take effect. And only do this with a K1m, not a K1.
Master reset/clear is not in testmode on K1m. You need to either use software2_bing.gif such as radiocomm etc or you can do it from opcode screen.
Perform at your own risk!!! This will delete everything (contacts, pics, etc...), not just contacts!
Goto opcode screen:
Enter: CLR, 0, 4, 8, 2, 6, 3, * (Note: Must be done quickly.)
From the opcode screen:
Enter 18* and click center radial button on phone. Then enter 0 and click on center radial button.
-wait and it will say success after a short time.
Enter 18* and click center radial button on phone. Then enter 1 and click on center radial button.
Exit out. Contacts, Pix & Flix, Called #’s, etc should all be deleted…
Note:
18* enter, 0 enter – does master reset.
18* enter, 1 enter – does master clear.
WARNING: There are other #’s that can be entered…but I think you can really BREAK/BRICK your phone in there quite easily…
Performing master reset/clear using software like radiocomm is proven and works well, but if you do not have the software and want to wipe phone before selling, returning, etc… then…
Apr 03, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola krzr k1m + 2gb memory - won't read the card
for your added information, it is by chance that the 2 gb sd card can be recognize by your phone. normally, krzr 1 doesn't support 2 gb. you may think that others do have. it all depends on the firmware they have and sometimes on the brand of the sd card like micromax
it is really by chance that it will be recognize. most of the time, it can be hardly recognize.
take care.
Feb 07, 2010 | Motorola Mobility KRZR K1m Cellular Phone
The screen on my motorolla k1m has gone blank
KRZR's are JUNK...The wire in the hinge has a problem, I've gone through 4 in under a year
Aug 03, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
BOOTLOADER USB INIT ?????
the phone need to be reflash so take it to a mobile center to have it done or mobile technician.
Jun 06, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola k1m
try 1234 or press the menu key when the phone prompts for the security code enter 000000.
May 30, 2008 | Motorola Mobility MoroKRZR K1m Cellular...
Internal screen is white
NO YOUR DISPLAY IS DAMAGED YOU HAVE TO CHANGE UR PHONS DISPLAY AND IT WILL WORK EVEN CHANGING THE DISPLAY IF IT DONT WORK CHECK THE DISPLAY CONNECTOR.
Nov 23, 2007 | Motorola Mobility E815
Krzr problem with display
hey, i have the same EXACT problem. it was a great phone until that happened.  I took it to a technician and he had to send it in and said it was something with the connection where the screen flips open.  He had to send it in and they gave me a new one because i still had a warranty.
Oct 10, 2007 | Motorola Mobility MoroKRZR K1m Cellular...
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
59 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
