Question about Sony Mavica MVC-FD200 Digital Camera
I get the message disk protected - Sony Mavica MVC-FD200 Digital Camera
I have a kingston data traveller (pen drive)32 Gb which when i connect to the computer the drive gets detected but when i try to load some data into it, it give me an error message disk not found. When i...
Write protected and disk not found are the typical messages that a pc gives when you try to access a memory stick in which the actual memory chip has died. Nothing more can be done to fix it - it's dead. Junk it.
Aug 08, 2010 | Computers & Internet
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
"disk is write protected" receiving message on external hard drive and memory sticks
it might be in your security settings
right click on the drive in my computer-->properties-->security tab then click "edit" to change permissions check each user, system ,administrator and, your account name make sure it looks like these pictures2296299.jpg6b25e6a.jpg5b159b0.jpg
May 10, 2009 | Computers & Internet
128mb Sony Memory Stick Duo
            This is a common problem and its quite easy to resolve.
I had a very similar problem with a friends nokia 5200 memory stick , it refused access to the card , i got the message disk is write protected I couldnt even access it from a PC card reader or format it .
             Somehow he had accidentally set a security code for the memory stick and the mobile then forgot he had done it , I tried the usual code of 1,2,3,4 and this didnt work.
        When I tried the number 1 on its own , suddenly I could access the memory stick again and format it and didnt get the message (disk is write protected)...Reset your P800 security codes with the master reset function in the main settings menu.This will remove any codes that restrict access to the memory stick...
Sep 03, 2008 | Sony Ericsson Walkman W810i Cellular Phone
How to remove write protected memory card
when i attach the card reader with system and when i store the software or any thing in memory card then msg show that(cannot copy because write protected error)
Aug 29, 2008 | Nokia 3230
Disk Protect
undo the disk protection tab on the floppy disk
Jun 06, 2006 | Sony Mavica MVC-FD87 Digital Camera
Sony Mavica MVC-FD200 Digital Camera Logo
20 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
