When I switch it on from cold it goes to come on them goes on standby so I switch it off then on again then it comes on why is this pls
  • 400 Answers
Air conditioners or refrigerators do not like to be switched on and off in a short period of time. You should allow a minimum of three to five minutes between switching either on or off or from heating to cooling.
Posted on Nov 19, 2009
St70 550
Check and replace damaged component/s at it main board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
May 08, 2014 | Grundig Televison & Video
Acer p241w stays standby
CHECK IN BIOS MODE ,THIS PC NOT GOES TO STANDBY SO PROBLUM IN YOUR OS .FORMATE PC NOW CHECK .
Aug 31, 2017 | Acer P241W 24 inch Monitor
Hi my samsung crt tv come up on start up but couldn't stay for more than few seconds before it goes standby. I've tried to check settings but could not even get anywhere before it goes back to standby
Whenever a television starts doing this the motherboard/main board and or power supply is usually at fault. The power supply can usually be rebuilt for around $150 depending upon the knowledge and skill of your local television repair shop. To replace the parts is usally more expensive then it would be to purchase another television ($300 and up). Are you sure this is the model number of your television because this model number is not for a CRT television. For troubleshooting you can unplug it overnight to try and power cycle it but it sounds like your problem is beyond doing any type of power cycle to get the television back going again. It would need the repair shop or to be discarded for another.
Oct 29, 2011 | Samsung LNT3242H Television
Am not getting d picture wen i click.. it goes to standby mode.. i switched off and again i on.. it has no effect in it.. pls help me..
Restore your mobile with factory setting.. using restore factory settings in settings menu......
If problem does not solve than flash your mobile from the mobile phone shop........
Problem will be solved..........
May 18, 2011 | Nokia 7210
Samsung 50" r p tv switches off
Replace your Lamp BP96-01073A Fox has them $109.00 1-800-227-5369
Dec 29, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung 50" rear projection tv switches off after a few seconds
probably need to replace the Ballast and Power Supply Board. If lamp has not been replaced, I would replace that too. can call 1-800-samsung for nearest service center.
Bike switching off when coming to a stand still when hot
Your fan is not comming on, check your Antifreeze.
Mar 26, 2009 | 2005 kawasaki ZX-6R
TV goes to standby without touching it
Soounds like the typical cold or bad solder connections somewhere in this set on the printed circuit board. Not the ez fix for a consumer. Must know how to solder and test solid state electronics
Sep 16, 2006 | Philips 28PW6006 28" TV
No Power
I mwas gonna suggest that you need the speakers attached but you stated later that it did the same thing with the speakers attached. The unit switching off after it checks its self is NOT a normal thing. TAKE IT BACK BEFORE ITS TOO LATE!! GOOD lUCK
Jun 18, 2006 | Denon AVR-1706 Receiver
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
