Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Panel light indicates "Control Panel Lock" - Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
  • 126 Answers
Hold the button down for 3 seconds to unlock.
Posted on Nov 19, 2009
My dryer ran through the dryer cycle turned off. Hours later I noticed the "control locked" light is on and the dryer will not even light up to set program.
Hello. I really need the make/model number to help you accurately. However, depending on the model dryer you have, look on the control panel for a button or buttons that have a "key" symbol or the word "lock" underneath. Normally, you would hold the button down for 3-5 seconds until the lock light goes out. This is the indication that the control panel is unlocked and normal operation can be initiated. The manufacturers put a panel-lock feature on the units to prevent "busy little hands" or others from changing settings, for unattended safety, etc. Dishwashers, ovens, ranges, and other appliances also have locks for the control panel. If your dryer initiated a control lock by itself, this would indicate a shorted button on the control panel--soft touch buttons and glass touch-control panels are notorious for doing this. If I have the model number, I can usually provide the part number and/or procedure for getting into diagnostic mode to see any stored error codes(if any) which would help pinpoint a problem. I hope I helped you!
Oct 03, 2015 | Dryers
Kenmore ultra wash machine won't run even with indicator lights on. Symbol on machine says Lock on
You have the control-lock function turned on. There should be a key located near (above or below) the lighted lock symbol. Usually, it's the Heated Dry button. Whatever it is, press and hold that key for 5 seconds. That should unlock your dishwasher and you can now use it normally.
Jul 15, 2014 | Kenmore Dishwashers
It says CONTROL LOCKED.... how do I get it unlocked??
  • Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
  • Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
  • Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
  • They designed that mostly for kids sorry pain I know just be calm feel saving some ones child thanx
    Dec 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
    Control lock lit, no other buttons work
    Instructions
      • 1 Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
      • 2 Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
      • 3 Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
    Read more: How to Unlock the Control on a Whirlpool Duet ' eHow.com http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html#ixzz2HVS4i8hL
    Jan 09, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
    How do I use the Child Lock option on Samsung WF-B1456GW?
    You can use the child lock feature in 2 ways.
    1. To prevent operation of the washing machine when no wash cycle is running
    To set this feature, switch the machine on using the POWER button at the top-left of the control-panel. Next, press and hold both the SPIN and RINSE buttons for about 3 seconds - until the child lock light indicator on the control panel illuminates. All functions of the washing machine will now be disabled apart from POWER ON/OFF until such time as the child lock is deactivated.
    To deactivate the child lock, press and hold the SPIN and RINSE buttons again until the child lock light indicator on the control panel goes out.
    2. To prevent any tiny fingers from tampering with the machine while a program is running.
    After pressing the START/PAUSE button to start the wash cycle, press and hold the SPIN and RINSE buttons until the child lock light indicator illuminates. All buttons on the control panel will now be disabled until the child lock has been disabled. When the wash cycle has finished, you will need to switch the child lock off again to reactivate the buttons. Once you have finished using the washer, reactivate the child lock again before switching the power off as above.
    The feature can also be used when using the delayed start feature, but needs to be set after pressing the START/PAUSE button.
    Hope this helps. Please let me know if I can be of further assistance.
    Regards,
    BElectric
    Feb 09, 2011 | Washing Machines
    I have a problem with the remote control that is not working, I have taken it local technicians but nothing . My TV is in child lock so I need a remote for the tall big telefunken TV
    Hi what you can do is to buy a universal remote control for this TV to remove the child lock. You can get that online or on any electronic shops in your area. Once done here is the instructions on how to remove the child lock using remote.
    Look at the "Power" indicator light on the front of the television to check if it is blinking. When blinking, the child lock is enabled. You can also check by pressing the "Power" button on the television.
    Point the remote control at the television and press one of the buttons on the number keypad. The "Power" indicator light will stop blinking, indicating the child lock is turned off.
    Lock the television again by pressing and holding the "Power" button on the remote control until the indicator light starts blinking. It takes approximately three seconds before the light turns on. Thanks
    Feb 01, 2011 | Televison & Video
    The contol lock red light is lit and I can't get it to work
    Jun 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    My duet washing machine is saying control panel lock out and nothing will come on. Any suggestions
    May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Have replaced the water filter - how do i reset/turn off the "change filter" light ?
    Press and hold the "Reset Filter" button until the indicator lights go off if your model refrigerator has a "Reset Filter" button on the control panel.
  • Step 4 Hold the "Lock" and "Light" buttons on the control panel until the filter indicator lights turn off if your model refrigerator does not have a "Reset Filter" button. For models that do not have a "Light" button, press and hold the "Lock" and "Water" buttons.
  • May 18, 2010 | Maytag MZD2766GES Side by Side...
    Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
    43 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
