Question about Refrigerators
Model phsc39eess5 was in garage over winter not being used. When I hooked it up recently water leajed at the valve. Probably froze? Will I need a 241734301 and can i install that myself
  • 4,070 Answers
2015 Puma Unleashed 27 SBU. There is a valve under the trailer....it is located under the refrigerator...when I open the valve..it releases water. Should this valve stay open or closed and where is t
Sounds like it may be a low point drain for winterizing. I would disconnect from city water and turn your pump off. Then open the valve. If only a little water comes out then stops have some one watch it while you turn your pump back on. Assuming you have some water in your tank!! If it squirts out under pressure it it probably a drain and should remain closed unless you are winterizing. If it just drips a bit it may be a drain for the defrost function of your refrigerator. After you have figured all that out,hook back up to city water and check it again. Good luck.
Jan 18, 2016 | RVs
I have a 1992 Cadillac Eldorado 4.9 I've recently installed a new radiator and water pump, had my header machined at NAPA. This stopped all my leaks until afew days ago water started leajing from the front...
freeze plugs ( welsh plugs ) rut out with time
this is a very good possibility'
If it has then replace as many as you can get to as they will all be much in the same state.
Mar 13, 2015 | 1992 Cadillac Eldorado
The pressure washer leaks from inside casing letting out water/soap might be affecting pressure of hose?
If your part of the country reaches freezing temperatures during winter, the pump probably froze. This can cause cracks to brass and (especially) aluminum pump heads. It is worth opening up the case; sometimes I find loose fittings (caused by freezing) which can be tightened up and everything is fine. If it is not freeze damage, the check valve may have gone out on the soap injector, causing pressure to back flow through the inlet barb. Otherwise, you may have a worn/leaking pump seal.
This is a consumer (throw-away) pressure washer. If it's not a loose fitting which can be tightened, the unit is probably not worth fixing.
Jul 01, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
Where is the cold water valve on amana washer
the cold water valve is at the end of the hose at the back of the machine
if the cold water pipes run outside to the garage , it is a fair bet that the water in the pipes has frozen
easy to check --take the cold water hose of the tap and see if it runs
if it runs replace the solenoid for the cold water valve
May 10, 2017 | Amana Washing Machines
Engine runs but only a steam of water comes out of gun with trigger on. washer is stored in a heated garage in winter.
you need to remove and clean the unloader valve. The way this valve works is when you release the trigger the pressure is diverted around the pump through the inlet side so you don't cause damage to the pump. This valve is usually located next to the discharge pipe on the pump where your pressure hose hooks up to. Remove and clean. Be sure to clean port that you remove the valve from also. Use carburetor cleaner. Lubricate the valve with a light coat of lithium grease. This should cure the problem. If not let me know.
Jul 25, 2011 | Briggs Stratton 020273 Elite Series...
Hooked it up with water started engine and no
Your water system is plugged with "gunk"
You will need to slush it out with water and air pressure if you can until it runs clear
Apr 04, 2010 | Briggs Stratton 020273 Elite Series...
Not getting water to ice maker and water dispenser
No model # to reference. Althou alot of issues might cause problems, some are really mondain. (e.g. is the valve on, has any plumbing work been done recently, if inline filter how old is it). Checking fill valve, access valve area, remove from bracket remove tubing and wire connectors from valve. Use jumper cord and power each valve solenoid put valve output ends in glass to test. If valve sends water from each valve if OK keep looking. If refer has internal filter, hook all back up to test. would need model # to give more help.
Ric
Mar 10, 2010 | Frigidaire FRS23R4A Side by Side...
I have gilmour 9400 water timers ,some froze,need parts
I have the same problem. Mine blew out the O ring and it pops back out when under pressure. I just need the black back part, the electronics are fine.
Jun 04, 2009 | Garden
My husband forgot to winterize our Kenmore Elite H3 washer when we moved. It was stored in our garage for 5 months(September - February). When we hooked it up water immediately started pouring from the...
Its most likely the rubber tubing, and sack that connect the drum to the drain pump. You can either remove the back panel, or the panel in the bottom front of your washer to check for cracks in the rubber. It might be as simple as the tube came out of place during the move.
Mar 13, 2009 | Washing Machines
Open Questions:
Refrigerators Logo
70 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
