Question about GE Â 17.9 Cu. Ft. Top-Freezer Refrigerator
I have a GE bottom freezor model#GBS22HCPAWW.The fill tube has frozen four times after thawing.What are possible reasons.
  • Anonymous Mar 23, 2014
    how do you get to and thaw the freezer fill tube
  • 4,059 Answers
The fill tube at the ice maker will freeze up when you have a leaky water inlet valve. It's on the back where the water source is connected to the unit. You can disconnect the water line that goes up to the ice maker and watch and see if you have a drip. This water will go to the fill tube and gradually block the tube as it is frozen when it reaches the cold air in the fill tube. You may be able to clean the valve out or just replace it.
Posted on Nov 18, 2009
My ge profile frig had one issue that I don't understand the water works whenever it wants too, oh and that is never even I want water no matter the time. It does with though from time to time. What weeks...
Sometimes especially in GE SXS refrigerators the water tube freezes in the door. You will have to see if you are getting water to the door by disconnecting the couple under the freezer side and tap the water dispenser if you get water there then the tube is frozen and you will have to thaw out the door for a couple hours. A slight possibility is the water reservoir in the fresh food section behind the crisper could be frozen. Again you will have to thaw it out.
Aug 15, 2014 | Refrigerators
Water is frozen in fill cup inside the ice maker
Put your frozen food in a cold place.Unplug the fridge, leave the freezer door open for 12 hours. Dont mess with hair dryers
Jan 30, 2013 | GE GSS25LGM Side by Side Refrigerator
The front egde of the ice maker overflows into tray and causes big ice block in tray.
Start with changing the water valve in back of box. Take the water line from the valve and blow in to line to see if fill tube is frozen also. If it is take a hairdryer and thaw the fill tube. Turn off the box while thawing tube then turn on. If all this dont fix it time for new maker. But dont replace icemaker till you check the rest because It wont work if the tube is frozen or bad water valve. I hope this helps.
Aug 29, 2011 | Refrigerators
The water dispenser keeps freezing. The Ice Maker is fine. This is happening everyday.; We thaw it out and then is does it again. Fridge is set at 37 and freezer is a 5
if this is a side by side frige the water tube that runs inside freezor door pulls away from insulation causing it to have no insulation between the freezor and the tube alot of then you can thaw one time and there fine. disconnecting the water line at bottom of frige behind toe kickin front and usually is a push in an d release tab connectors or plastic threaded nuts blowing air through can use air compressor not at full blast works great and then once you have it flowing run gallions if possible though to make sure no water deposits no debrie to slow water down to give more chance to freeze oh and if it hasa filter make sure its update and replaced this will help also if still problem persists may need new door they foam insullat these things at the factory cant just move it or put more insulation inside door , door are spending too
Mar 03, 2011 | Kenmore Refrigerators
I have a GE side-by-side refrigerator - new in 2005. The fill tube has frozen and the inlet is frozen shut. How can I repair this.
You can use a blow dryer carefully to thaw out till ice drops out of fill tube . Do not overheat the plastic liner or other parts
Nov 17, 2010 | Refrigerators
I have a GE stainless steel side by side model PSW26MSRB. Incoming water supply line to ice maker popped out from back panel of unit spilling water (looks like it was originally attached with adhesive...
Your water valve has failed. the valve is slowly seeping water eventually causing the fill tube to completely freeze over. You are right - the incoming pressure is causing the tube to pop out. you can usually pull the feed tube out from inside the freezer and thaw/clean it out. but you will need to first replace your water valve.
Aug 06, 2010 | GE PSW26MSR Stainless Steel Side by Side...
Easiest way to thaw out a possible frozen water reservoir in my GE side by side fridge?
Hair dryer is the easiest way to thaw. To find cause: Remove lower grill and disconnect the water line going through the freezer2_bing.gif door hinge. Usually it is a push lock fitting, which requires you to push the ring2_bing.gif on the end of the fitting toward the center of the fitting while pulling (not hard) on the plastic tube. Now place a pan under the separated plastic hose and try the water dispenser. If water comes out, your problem is a frozen water line in the freezer door. A warmer freezer temp may help, or you can order and install a WR49X10173 water tube heater2_bing.gif. (the heater may take 24 hours to thaw the line, but I have used it successfully several times. Cost about $50) If no water comes out the separated tube when you try to dispense water, reconnect the tube at the hinge by pushing the plastic line back into the fitting. Now, at the back of the refrig., disconnect the water line going from the water valve to the fresh foods compartment. Try to dispense water. No water at valve outlet = bad valve. Water dispensed from valve now = frozen water filter2_bing.gif or water line at back bottom of fresh foods compartment. (make sure you disconnect the right tube. If in doubt, disconnect them both, just get them back correctly so your icemaker continues to work) Send me additional comments if needed. Don't rate before you try all the steps.
If water filter or water line/ reservoir is frozen, thaw with a hair dryer. If reservoir is frozen, check to make sure there is no frost on back wall of inside freezer, preventing normal air flow, allowing cold air to enter fresh foods compartment through return air vent at lower back of fresh foods compartment, resulting in freezing of water line / reservoir and possibly food in bottom bin.
Nov 18, 2009 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
The water filling the ice maker freezes in the filling tube.
You can thaw the frozen water with a hair dryer but to stop this from happening the water control valve may be the reason for this to happen. When the ice maker calls for water to refill it is timed. If the water control valve located on the rear of your refrigerator is not closing all the way for the ice maker side it causes the water to freeze in the tube because it slowly flow to the ice make just enough to seal the fill tube.
Thanks and let me know what you find, Sea Breeze
Oct 12, 2009 | GE Refrigerators
G.E. Side by side model quit dispensing water. The refrigerator door was not completely closed overnight. Is is possible the water line froze since the freezer had to run so much
It is possible the water line inside the freezer door froze . Remove the bottom kick plate and follow the white tubing about 6" to a coupling . Push in on the white ring and at the same time , pullout on the tubing . Push the water dispensor , and if water comes out of the hose going under the fridge , this means the line is frozen in the door . If no water comes out , it means the water tank at the bottom of the fridge section (behind crispers ) is probably frozen . A hair dryer should work on the tank , but , a different procedure will be needed to thaw the door . Come back if door is frozen for the procedure .
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE arctica profile - the water dispensing "bucket" somehow filled with water and froze over. Water spilled over and froze on other parts of the ice maker. Tried taking it out to thaw it -...
This is very possibly due to a defective water control valve and a fill tube being frozen over due to the constant flow of water to the ice maker when the water valve should be off. You will need to tun off the water supply before the valve behind the refrigerator before replacing the valve. If you could tell me which model number you have that will help us find the correct parts. Thanks, Sea Breeze
Aug 19, 2009 | GE Profile¿ Arctica® Energy...
GE Â 17.9 Cu. Ft. Top-Freezer Refrigerator Logo
205 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
