I have a d52w27d the standby light comes on for 5 sec and goes off for 4 sec it does this three times before it completely stops. it never turns on. there was a capacitor that had burned a hole through the board. the cap is located in front of the flyback. it is .oo87uF at 2000vdc. thank you for your help in finding this problem.
  • vernon johnson
    vernon johnson Nov 18, 2009
    wassup sensei. you already know i am going to give you high marks. i bet you saw vljenterp81 and lit up like a candle. i have already cleaned the board and reconnected the cap. the cap is burned though but it still reads fine. what i am going to do is find a cap like this and replace it. i am assuming that the transistor is the h.o.t. that you are talking about. i had thought about doing so but i did not do it but now i am going to try that also. i willbe talking to you when i achieve these.
  • vernon johnson
    vernon johnson Nov 19, 2009
    as usual you are the man for the job. look for rca e 13209bc
  • 5,807 Answers
You may need to scrapped the board with a paper cutter gently
so as to remove the burned printed circuit board. and replace the said bad capacitor. then clean that part of the board with an unused brush soaked in lacquer thinner to totally remove the burnt part .
you might also have a resistance check on the collector and emitter
of the transistor. usually the center and the rightmost pin. it should
not be almost near zero reading.
do all of these with the unit unplugged from the wall outlet.
Posted on Nov 18, 2009
  • 3 more comments
  • Rommel Cana
    Rommel Cana Nov 18, 2009
    might as well measure the voltage on it, or after the primary winding , only if there is a replacement capacitor installed . . it is called B+
    have a resistance check first to be safe.
    look /check also for other might be bad capacitor 330 uF 35V near the chopper secondary windings
  • Rommel Cana
    watch out also it might be bluest white ( arcing) once you turn it on
  • Rommel Cana
    if you have a variac , or an step down transformer, might be better to use it , during troubleshooting , if none use 100w incandescent bulb.
  • Rommel Cana
    it will be connected in series in the main power supply
  • Rommel Cana
    B+ should never exceed 135V having more is bad.
Picture and sound turn on and off
I believe that model has a logic board in it and that is what it sounds like to me. That is just off top of my head, but I believe if you will notice the standby light it will be blinking so many blinks and stop and then blink again. If so this is a code that you can look up on the Samsung web site and plug in your model and it should tell you what just say ~ 4 blinks means. I worked on so many and it has been a while but I believe the last one I had was a Samsung and I put a logic board in it. If I can be of any further assistance please let me know.
Mar 12, 2014 | Samsung HL-R5078W 50" HDTV
Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
Alarm light on and u051 error mx310
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
Please rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
POWER LIGHT FLASHES 3-4 TIMES AND SOUNDS LIKE TRYING TO COME ON B
This will need a capacitor replaced on the power/deflection board. (CP150) This is a very common problem on these sets. Service man will probably charge at least $200
Jul 05, 2009 | Televison & Video
I was watching my kp61v80 and the screen went black-can you give me the trouble codes for the flashing standby light
Diagnosis item
TIMER/STANDBY
Indicater
Number of blinks
Supposed malfunction Condition
Self-diagnosis
screen display,
Diagnosis item: Results
•Power not ON 0
[Standby Power Supply System]
F601 open.
R607 open.
Q601 short circuit
[Main Power Supply System]
IC601 and R612 are broken.
VDR601 short-circuit
Cannot turn on the power.
LED doesn't blink.
+B OCP detection 2times Short circuit of power supply system in each circuit.
Goes to the standby mode
Short circuit of +B line
2 : +B OCP 000
+B OVP detection 3 times
T603 pin 78 open.
R672 open.
Malfunction of power supply circuit
3 : +B OVP 000
Vertical deflection stop 4 times
IC1509(V out) is broken.
Q1505(V Pulse Buffer) is broken.
Raster goes to one line horizontally, Aand then video
signal is muted.
4 : V Stop 000
Video out abnormality detection 5 times
Video out, Q705, 732, 761 and others in C board
circuit.
Q218, 219, 220 (A board)
TIMER/STANDBY LED blinks approx. 30 seconds,
and then blinks for the self diagnosis.
5 : AKB 000
Horizontal deflection stop 6 times
C515, 516 open.
IC206(YC Jungle) is broken.
Raster doesn't appear. 6 : H Stop 000
Audio abnormality detection 8 times
IC406(Audio amp.) is broken.
PS401, 402 open.
The sound is not out.
8 : Audio 000
Jun 17, 2009 | Televison & Video
Sxrd rear projection standby light blinking 4 times. I unplugged tv and when I turn it back on,it comes on for about 5 sec then goes off and red light blinks 4 times. Changed bulb about 2 months ago. And...
check the bulb door and make sure its closed all the way. be sure the bulb is firmly pushed into its socket. if the problem is still there you may need to repair the power supply board.
Jun 17, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Tv's green light comes on then off three times
Check capacitors cp150 ,114, 120 ,if cp150 is puffed up on top it is bad.2200uf 16v and the other 2 are 220uf 35v.
Feb 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Lamp indicator flashes red 3 times every 5 secs.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 31, 2009 | Panasonic PT-44LCX65 Television
Turns off after 4 secs or so....From Green to Red,
Receiver turns on Green but on pressing button again for red light standby, red light will not come on for this Denon receiver. Recently light came on saying Panel Lock is on. I was not able to get tuner to work.
Aug 25, 2008 | Denon AVR-1905 Receiver
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
