Question about Candy CPCA270FFK Bottom Freezer Refrigerator
Candy CPC 290 FF
Fridge is not cold enough (probably 10 degrees) even on maximum cold setting. Tried disconnecting for an hour and switched back on. The compressor works for 3 seconds then stops - irrespective of how the cold control is set.
(Note the fridge/freezer was left on with hardly anything in it. After a month we noticed a sheet of ice in the back of the freezer)
  • Elif Jan 11, 2008
    Thanks for your help washdoctor. I'm really impressed with the Fixya site
  • Elif Jan 11, 2008
    I may be clutching at straws..but ...
    As I wrote the compressor kept making this clicking sound as I turned the fridge on and off and the compressor went off after a few seconds after I turned the fridge on.....but later last night the compressor started up again on its own and ran for 45 mins before stopping.
    Overnight I checked it several times.
    It now seems to be running in intervals as a 'normal' fridge but still is not reaching the desired temperature.
    Could the problem be 'just' the thermostat..can it be replaced?
    i.e. Have I any hope of not having to buy a new fridge?
  • 139 Answers
Hello
Well the sheet of ice was caused by the thermostat failing and causing the fridge to continously run therefore causing the over freezing..
Like a car engine if you leave it running for weeks on end without stopping it probably will burn out...
Or like a horse is you have it working day in day out with out rest it will die..
you compressor on your fridge is no more... it ran and ran and now its all worn out .....
The clicking noise at the back of the fridge is the compressor trying to swtich on but it can't
only a professional can legally change over the compressor
as it is a techincal process recharging the fridge with gas
if you need any other help let us know...
you need a new fridge by the way
Posted on Jan 11, 2008
Fridge now constantly CYCLES ON AND OFF for 10 to 15 minutes
Perhaps calling in a refrigerator repair man so he can check the freon as that is what causes them to run alot more than normal
Jun 03, 2016 | Westinghouse Refrigerators
My upright Candy fridge freezer is 14 years old. The fridge is 5 the freezer is -27.9 how can i adjust it?
turn the dial to a lower number . wait a couple hours and check temps if not low enough set even lower number on dial till it gets where you want it .
May 12, 2015 | Candy Refrigerators
Bottles in candy wine cooler ccv 150bl are not cold enough even with thermostat is turned to cold is there any way to solve this
Check the condenser is clean, and the inside not iced up. Is there a fan inside? Check all is operating normally. When you say it is not cold enough, what temperature are you trying to reach? For keeping / storing wine, 8 to 10 c should be fine. For chilling before drinking, take the wine to a domestic fridge to get it to 4c
Apr 21, 2012 | Candy Refrigerators
I have a sharp fridge SJ-P49N-SL. A recent power outtage in the area lasted 8 hours. When the power came back on, the fridge seemed to be ok. But, after 5-6 hours of operation, the freezer is not cold...
Checked Freezer Fan is working. Also checked defrost Fuse in freezer.
To checked freezer fan is working or not open freezer door press Door Switch and checked Cold air is coming from duct or not.
Aug 10, 2011 | Sharp Refrigerators
My kelvinator 290 refrigerator (not fridge/freezer) leaks water which apears underneath the 2 crisper drawers at the bottom? How do I stop this from happening. Can I unblock something?
you need to defrost the fridge. you most likely have a build up of ice in the collector from running the fridge to cold.
once down plug back in freezer and run on low temp for 24 hours and increase in small increments until the fridge is to a good temperature (about 39 degrees F)
Jul 02, 2011 | Refrigerators
Fridge section is too cold causing food to freeze
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 03, 2009 | Refrigerators
Freezer cold, not fridge
24 hours It should be good Do check temp settings.
Aug 05, 2009 | Candy CPCA240FFK Bottom Freezer...
Candy CFC 290 FF
Candy frost free freezers have a 'self defrost' mechanism to remove excess ice build up. What happens is the ice gets packed around the heat exchanger in the back of the freezer and it can't self defrost. This is easy to fix but will require the fridge to be left switched off with the door open for a couple of days so all the ice can melt. Make sure you left the appliance off for as long as you can as if there is any ice left the problem will just come back.
Aug 30, 2008 | Candy CPCA270FFK Bottom Freezer...
Westinghouse Fridge Problem
Is the fan in the freezer running? You should be able to hear it. If not, that is your problem. Check the door light/fan switch or check if the fan has power to it when you press the door switch in by hand. If fan is running, you could have a defrost problem. The defrost timer or the defrost heater could be faulty.
Nov 04, 2007 | Refrigerators
Candy CPCA270FFK Bottom Freezer Refrigerator Logo
497 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
