Question about HP OfficeJet K80 All-In-One InkJet Printer
My officejetK80 says to insert color cartridge when there is already one inserted
    Genius:
  • 1,018 Answers
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Nov 18, 2009
Replacement color cartridge is not shaped the same as the original color cartridge and does not fit into the cartridge slot.
Make sure you are inserting the correct cartridge versions in your Lexmark printer. The Lexmark X5470 uses the 32/34 black cartridge and 33/35 color cartridges.
If these are the cartridges you are inserting, please contact Lexmark Technical Support Center for additional assistance.
Aug 17, 2011 | Lexmark X5470 All-In-One InkJet Printer
I put the new black and color ink today, but color sign does not show up. It saysYOUR PRINTER HAS PROBLEM. Printer does not working at all. I check the cattridge both of them. Please give me the...
Make sure the cartridges are properly inserted in the carrier. Please follow steps below to determine and fix the issue:
  1. Open the printer cover and remove both cartridges. Close the cover.
  2. Unplug and re-plug the printer into the power source to reset it.
  3. When the printer turns on, re-insert the black cartridge first. Close the cover and check for any errors.
  4. If none, re-insert the color cartridge and close the cover.
  5. Replace whichever cartridge is causing the problem. You can also try to insert a different known working cartridge to determine if the other is faulty.
If no errors, try to print a document.
Jun 24, 2011 | Lexmark X1270 All-In-One InkJet Printer
Copier keeps asking to insert color cartridge but cartridge already in place.
most times an allignment and clean is requested switch off power for 1 min then see what the display says follow the requests
Aug 16, 2009 | HP 310 Color Copier
Says "insert color cartridge," but color cartridge is inserted
some times the cartridge will not detect properly, it will happen due to either its not inserted properly or cartridge problem.best u change new another cartridge and verify it.
Jul 08, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
Dell 926 won't recognize new color cartridge
Try this...shut down the printer. Insert new cartridge, let the printer cycle out with new cartridge. then reboot the computer. This should solve the problem. The cache in the printer will not cycle out. It wants to see the printer as a new entity
Jun 17, 2009 | Dell 926 All-In-One InkJet Printer
How do you remove toner cartridge from a Dell 3010cn color laser printer correctly.appears to be stuck trying to remove
This is how to Install or replace the Toner Cartridge.
Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier does not rotate).
1. After confirming the Insert Yellow Toner(Y) message, open the front door.
2. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
NOTE: You need to remove the protective cover only the first time that you install the toner.
NOTE: Dispose of the protective cover after you remove it.
NOTE: The protective cover is attached to each toner cartridge mount.
3. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
4. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
5. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
6. Close the front door.
NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly.
7. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
8. Repeat steps 1 through 7 when inserting the remaining cartridges.
Cheers!!
Apr 21, 2009 | Dell 3010cn Laser Printer
Copier states to ''insert color cartridge''
When you installed the new cartridges, did it ask or display if you "installed a new ink cartridge" press the ok botton to rest the cartridge back to new. Then it will ask you to aline the cartridge and it will print a test print and ask you to place the print out on the glass. Do the same for the next cartridge..... I have one question, is this a new problem with the new cartridges????
Mar 24, 2009 | Office Equipment & Supplies
Continually says align print cartridges
My guess is that the color cartridge is either defective or not inserted correctly. I have a 6110 and know that inserting a print cartridge is a little tricky. If it isn't completely inserted and the top latch fastened correctly, the cartridge either won't work or produce errors.
Try reseating the color cartridge so it's inserted in exactly the same way as the black cartridge and run a print job again.
Open the following web page and go to Step three to see the instructions for cleaning the electronic contacts on the cartridge and print carriage.
Ink Cartridge Alignment Fails
Those seem the most likely causes and solutions to me. Good luck.
Oct 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
ASKING INSTALL COLOR CARTRIDGE
Check if the cartridge was inserted correctly (right slot) (remove it and insert it again)
Check if the cartridge is original and the sticker was removed. Turn off your computer, and your printer. Start up your computer and after your printer. Try again.
If the problem continues, insert the old one cartridge (which was removed before) and see what happen...
If stop asking for install color cartridge, you have failure on your new cartridge
and need to be replaced.
Sep 24, 2008 | HP DesignJet 750c plus InkJet Printer
Error check ink cartridge
Hi ,
As per the information provided by you it seems to be a hardware issue however u cvan try these steps .
Steps >
Take out the ink cartridges from the printer > without turning off the printer unplug the power cord > press # and 6 key together , now without releasing the keys plug in the power cord .
keep on holding the keys down until the machine turns off automatically .
after the unit turns on again it would do the allignment give a msg for insert ink cartridges . insert the cartridges at that time . and see how it works out .
Thanks
MAC.
May 24, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet K80 All-In-One InkJet Printer Logo
121 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
