Question about GE Kitchen Ranges
Gas stove makes a clicking noise once every hour...
My gas stove makes a clicking noise once every hour or so. It's the same noise that it makes when it is trying to start a flame but it only clicks one time. Solutions?
  • 213 Answers
SOURCE: ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Posted on Nov 21, 2007
  • 833 Answers
There is nothing fancy about how the gas controls work on this unit. Do all burners give you the same problem? If so, it could be a kinked service hose or a service valve that has been partly shut. If it is limited to a single burner or two, the valve may be gummed up and should be replaced.
Posted on Dec 13, 2007
rickzilla
  • 706 Answers
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Posted on Sep 01, 2008
frcs68
  • 1605 Answers
SOURCE: GE profile gas stove igniter don't stop igniting
take a look at the igniter located in the center of two burners. clean the gap with a stiff brush between the eletrode and the upper plate. the distance is preset at the factory. you may have enough buildup to close the gap enough to trigger the igniter.
Posted on Oct 23, 2008
SOURCE: gas stove /electric starter won't click to start cleaned stove
Try cleaning the starter with rubbing alcohol and toothbrush. There might be soap or boiled over residue on the starter. If that doesn't work, try using fine 150 grit sandpaper and gentle clean the starter with it. This problems drove me nuts too. Good luck!
Posted on Mar 21, 2009
Amana counter top gas stove when plugged in start making clicking noise and you can smell gas .
on most, your push down and turn to hi to open gas valve and turn on piezio to light burner. it sounds like you have a knob already turned on . the control under the knob may need replacing. kinda an easy replacement if you get new part. check out repairclinic.com for video(maybe) but for parts for sure. be careful. gas is explosive.
Mar 16, 2015 | Amana Cooktops
Stove is making a gurgling or bubbling noise
I am sorry I have a gas phobia after using gas for heating and cooking both cloths and food for some years some 50 years ago.
So everything connected with gas is potentially dangerous.
Kolbrun
Feb 26, 2012 | Kitchen Ranges
My Jenn Air Electric stove is making a clicking noise. When I put my hand on one of the cook top knobs I can actually feel a vibration when the click occurs. What is this?
Gas stove? LP? It is probably the electric spark ignitor. Many times when you clean the stove top water from the sponge gets below. The water droplets (align mysteriously) make the connection between the wires, and the stove thinks it's supposed to be igniting. When the water evaporates, the switch will work fine again & the clicking should only occur when igniting & then backed off.
This happened to me once before.
Nov 21, 2010 | Jenn-Air 4 in. JEC0536ADS Electric Cooktop
The gas jets are making a sparking noise and popping and the stove is not on
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Sep 25, 2010 | KitchenAid KGST307 Gas Kitchen Range
My stove is making strange clicking noises. please help.
It sounds like the ignition knob is stuck in the "ignitor" position. Try taking it off, clean it and adjust it. If that doesn't work, it will have to be replaced with a new one. If yu leave it alone, it will probably wear itself out. Just make sure that the gas valves on the stove are in the off position so that they don't accidentally light on their own. Good luck
Jul 13, 2010 | Cooktops
No clicking noise when turning the nob..
Most modern gas ranges do have an electric pilot light. This one however does not. Normally you should always get the ignition (clicking noise) whenever you turn the temperature control knob. Provided that the stove is plugged into an electrical source. If you are not, then your ignitor could be out. Replacing it is fairly easy with a difficulty scale of 5/10.
But on to your problem. If you lift the lid on the stove top you will see two holes about halfway between the front and rear burners. Just connect the stove to a gas source and put a match or lighter to this hole. Don't worry, it won't blow up or flare up on you. You will need to do the same thing to the oven. If you open the broiler part of the stove, use a flashlight and look inside. You will see a similar type of gas line. Do the same with a match or lighter.
As with all gas appliances, ALWAYS check your gas lines for leaks using soapy water. If you see bubbles after spraying the solution on, then you have a leak and shouldn't turn the gas on until it's foxed. Use yellow Teflon tape or "pipe dope" on all gas connections.
Sep 30, 2009 | Sears 61301 Gas Kitchen Range
When I plug in my gas stove, it makes a clicking sound
That is just the electric igniter clicking because the module or switch got damp.try unpluging the range for at least 12 hours and retry,if it stays clicking the module will need to be replaced,but alot of times it will dry out and be ok,there is no of gas leaking if the valve is in the off position. hope this helped you understand your clicking noise.
Aug 18, 2009 | Stoves 600SiDOm Gas Kitchen Range
Gas stove ignator makes
sounds like you got the electronic ignitor valves wet try blowing them out with air or don't use for a few hours
May 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas stove makes clicking noise when turning on
When a gas stove is clicking, it means it is trying to ignite the burner. If the knob is held in the ignite position for more then 3 seconds and the burner does not ignite, it means that (1) the gas is shut off to the stove, (2) she does not have gas service set-up yet at the apartment, or (3) the gas nozzles feeding the burner are dirty and clogged.
Most of the time, when you move to a new apartment, you need to call the gas company and have the gas turned on, unless it is included in your rent. Either way, when a house or apartment is unoccupied, the gas is turned off for safety reasons. I would contact the landlord to be sure.
Mar 22, 2009 | Stoves 600SiDOm Gas Kitchen Range
Super Capacity 465 Gas Range
my gas stove top burner will not ingnite when I turn on the gas.
I have gas supply to the house, the gas stove top makes the tick tick noise when you
turn one of the burners on, but no flame, even if you try using a match.
What all can I checK?
Sep 20, 2008 | Kitchen Ranges
Kitchen Ranges Logo
114 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
