Question about Ovens
I HAVE A WHIRLPOOL STOVE MODEL RF341BXHW. WE HAD A POWER OUTAGE,AND A LIGHT ON THE OVEN DIAL CAME ON WITH THE POWER--AND A BEEPING NOISE--THE FLASHING LIGHT SAYS,IF THIS IS FLASHING, TURN OFF THE OVEN. THE OVEN IS COLD--NO HEAT AT ALL. ANY IDEAS?
4 Suggested Answers
SOURCE: F 9 on a oven
The "F9" error code means the EOC (electronic oven control) has found the lock motor switches to be out of sequence or shorted.
Test switches and if there is nothing wrong then replace the EOC.
Posted on Dec 23, 2008
  • 59 Answers
SOURCE: GE Evolution stove/oven. My oven is not working,
remove heating element an check with ohm meter. pretty simple really.
Posted on Jun 19, 2009
SOURCE: Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
Posted on Aug 07, 2010
My ge oven stopped working after power surged code coming up on front panel: LCDBoard 'T_PP_Profile_V_3_35' Main relay V3.2, Aux Relay V3.2 EEPROM PARAMETER PAGE CRC 15 OEBC Initalization in progress
How to repair an oven: resetting the power - YouTube
? 3:13
https://www.youtube.com/watch?v=HenawxpSYow
Feb 14, 2011 - Uploaded by VideoJoeKnows
How to repair an oven: resetting the power might be the only thing you have to do....can you imagine? "You mean it ... My ovendoesn't work: what do I do now? ... How to Fix an F1 Error On a Kenmore or GE Range - Duration: 11:41. ... Oven Repair-Not heating after self clean-Kitchenaid,Whirlpool,Maytag ...
GE Oven quit working, after power outage - DoItYourself.com ...
www.doityourself.com/.../363632-ge-oven-quit-working-after-power-ou...
Oct 14, 2008 - Hi, our GE Glass Top Stove/Oven stopped working after a power outage ... My guess: the circuit board on the oven (behind the digital display) ...
Dec 29, 2015 | GE Ovens
After a power outage my oven does not work and only the left half of the stove is working, any thoughts?
Needs resetting. With power off, press middle button and hold in. Turn power on and continue to hold middle button until STOP disappears. Should now be able to reset.
Aug 27, 2014 | Whirlpool Ovens
What causes the beeping sound coming from my Hearthstone propane stove? I bought my Hearthstone propane stove secondhand.
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
Jan 19, 2014 | Thermador Ovens
After a power outage / low current power problem this evening, my whirlpool range, Model # SF315PEKW0 started beeping annoyingly, and displayed the following code F1 E1. Also, after, the oven would not...
The "F1-E1" fault code signifies an EEPROM checksum failure within the electronic oven control. Disconnect power to the range for longer than 30 seconds. Re-apply power and observe the display for longer than a minute. If the failure remains, disconnect power and replace the electronic oven control board.
Jul 24, 2011 | Ovens
After a power outage oven will no longer work
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Getting error F1 on digital display
F1 Board failure Replace control board (also called ERC or clock).
Mar 20, 2009 | Ovens
Display is in LOC but door is not locked. Can't set temp. to bake
check if u can find any reset procedure.
alsio u can let it with no power for 30mi that will reset it Int.Memory.
Feb 16, 2009 | Whirlpool RBS275PD Electric Single Oven
WHIRLPOOL SUPER CAPACITY 465 (ELECTRIC) MODEL RF366PXGQ - F3 E0
Same thing happened to me about 1 month ago... Did you get some kind of power outage or lightning strike??? I am pretty sure the stove part works but the oven doesn't right?!?! It might be 2 things.. Either the temperature sensor inside the oven doesn't work or it's the control board (where the clock is). I tried to chaned teh temp sensor but it did not work. I then changed the Control Board and oven works again...
Sep 24, 2008 | Gaggenau EB 270/271 Electric Single Oven
Power outage issue
You unit is stuck in the "Display Model Mode". Hold the stop/clear button for at lest five seconds in insure the interlock activates. If it does not activate then the electronic range control (erc) is not functioning. Replace the erc (Clock/Display.)
Jan 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
61 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
