Question about Magic Chef 31000 Gas Kitchen Range
The kitchen range electronic spark system does not work
  • 906 Answers
Good day,
hope this link below will solve your problem.
kitchen
Posted on Aug 04, 2010
Maytag mer5875rcs the electronic ignitor does not work
If all the other burners are igniting then you need a new switch if they all don't light on their own then you need a spark module
Nov 09, 2013 | Maytag MER5875RAS Stainless Steel Electric...
I have proble with whirlpool gas range SF265lxtq When I tried to use the oven, I setup the oven by the keypad, but the oven does not get hot, and i did not smell gas. What should I do ?
Your Direct Spark Ignition System contains a
Gas Distribution Valve and a Direct Spark Ignition
(DSI) Control that interfaces with the
Electronic Oven Control, and spark electrodes.
This provides the direct spark ignition and gas
distribution for Whirlpool self-cleaning gas freestanding
ranges. You must familiarize yourself with this system
before attempting any repair. Look through this service
repair manual for direct spark HERE
Mar 01, 2010 | Whirlpool SF265LXT (Gas ) Kitchen Range
My gas stove keeps on clicking after the burner is lit
your range has a Electronic spark modual with reignition. First look at the electrods on each burner and make sure they are clean all the way around them. (( dirt can cause them not to send the votage back created by the heat. )) If this does not solve the problem then you will need a new spark modual system.
Jan 11, 2010 | Wolf Range fs-0-27-ft36 Gas Kitchen Range
Range top ignitor stopped working. electronic panel and oven work normally. Any idea what the problem is?
Hi, your spark module,for ignitor could be damage, sometimes they burnt out, or could be broken wires, or corrosion at electrical connection, (terminal) , normally it's spark module, that's faulty or burnt out. let mechanic check. or remove range plug from receptacle, and lift top of range, check all electrical wiring, check all connection for rust (corrosion) clean and retry range, if it didn't work, call mechanic to check spark module. good luck.
Aug 12, 2009 | Amana ACS3350AS Gas Kitchen Range
My wolf rage doesn't light anymore by turning a nob
some models have one gas pilot for 2 burner front and rear and there is a small pipe that goes front the burner to to the pilot, the burner has small holes facing the pipe the goes to the pilot that's where you take a paper clip or a safety pin and clear or clean the holes, the same thing on the electronic ignition, but some electronic ignition they have a spark right nest to the burner and by looking at the other burner that are working you can see where it's sparking, and clean in between the burner and the spark.
Dec 12, 2008 | Wolf Range fs-0-27-ft36 Gas Kitchen Range
Burner switches got wet, sparked, daughter put baking soda on them, and two front burners won't light.
I also got too much liquid into control switch area & had sparks. Mine needed a new electronic ignition system. I purchased my range in Jan 06 and they are covering it under warranty now, Nov 08. To open the top, unscrew 2 small screws inside the front top oven. Then unscrew all 5 burners (10 screws). Then you should be able to open the lid about 12". Repairman propped mine open with a screwdriver while he worked under there.
Oct 18, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Electronic igniters Model SEG196
there is a spark module that controls all four surface burners usually located behind the rear access panel. This may have been a casulty of the outage. good luck
Jul 16, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
Tappan 30 Series Range ignition system
no fuse/ with execption of trying to reset circuit breaker. perhaps the power tripped the breaker om the electrical panel, if the power supply is goos to the unit i would look to the spark module( it contorls all electronic ignition function
May 08, 2008 | Tappan TGF320 Gas Kitchen Range
Gas kitchen range
Most problems with gas ranges have to do with the flame--either it isn't quite right or it's nonexistent. Most new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners. If, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
Jan 18, 2006 | Crosley CE35100AA Electric Kitchen Range
Magic Chef 31000 Gas Kitchen Range Logo
54 people viewed this question
Top Magic Chef Kitchen Ranges Experts
paulcarew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
