Question about Compaq Presario 5000 PC Desktop
My monitor screen is ok for awhile but suddenly turns a dull yellow color. I just bought it a few months ago.
    Novelist:
  • 136 Answers
you must adjust the display settings in the software program that was being used to change the display setting.
  • If you have a flat panel LCD monitor, unplug the monitor power cable, wait about 30 seconds, reconnect the cable and then turn on the monitor. This resets the electronics on the monitor.
  • Make sure the monitor has power - the light on the monitor is on. If the light on the monitor is off, the monitor does not have power. Connect it to a different power outlet.
  • If the monitor has a detachable video cable, obtain a second monitor cable for testing purposes in case the cable is bad.
  • follw the another steps-
  • Replace the monitor power cable.
    1. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    2. Replace the video cable. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    3. If the monitor does not work after replacing the cables, replace or service the monitor
  • Thanks,
    Posted on Nov 19, 2009
    Hello, My name is Diane. I've had my flat screen Acer monitor for 14 months and all of a sudden my monitor has no red, orange or pink color. My screen colors are green, blue and yellow. What is the...
    hello Diane, actually yellow is mixed red and green.
    I thing you should check your cbf cable first (VGA cable).
    Or if you have pattern test, use it to make sure which color has lost.
    Change VGA cable may can solve it.
    If any problem, please let me know.
    Thanks and good luck.
    Mar 27, 2011 | Computers & Internet
    Princeton 19" went from bright white to dull white
    david78910, First disconnect and reconnect the monitors VGA plug from pc vga port a few times to make sure of good connection at the port. Report back here with results! If that doesn't fix your "pink screen" symptom, then possible bad inverter supply inside unit or the CCFL tubes may have lots and lots of "on" hours use on them and need to be replaced. Yes, you could also have bad (almost dead) switch-mode-power-supply inside unit if "known-good" monitor works perfectly with your pc. 12fixlouie
    May 20, 2010 | Princeton Digital VL1916 19" LCD Monitor
    Blue haze and dull yellow patches on screen
    The light engine in your set has gone belly up. It is a very expensive repair. Good news is that on a whole bunch of models like yours Sony has extended the waranty on the light engine. Check with a local authorized Sony service center and give them the model & serial number and you might get a free ride. If I were a betting man I'd take odds on 'you're in luck'. LOL
    May 28, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
    Some green color patch in the middle of the screen
    Looks like you have an LCD. I was guessing it may be magnetic related in which case I would recommend you degaussed your display using the degauss function but your monitor won't have it since it's not a CRT by the looks of it. I would recommend contacting your dealer or where you purchased the monitor at a retail store. Since it's only 8 months old, you may be able to return it under warranty. If your retail store doesn't let you do that, talk to View Sonic directly and see if you can RMA your product for returning to the manufacturer and receiving a new or repaired unit.
    Check out Viewsonic's website for more information.
    Mar 24, 2009 | ViewSonic VX922 19" Monitor Flat Panel
    No image on monitor
    Looks like the Video card, or Video chip has bought the farm
    Try hooking up to another monitor to confirm where the problem is.
    Jan 30, 2009 | ViewSonic VX922 19" Monitor Flat Panel
    Color and other problems with SyncMaster 910 MP monitor
    Go to => http://www.samsung.com/us/
    Type 910mp in the search dialog box.
    Select Download English Manual. It's about 20mb.
    The manual has instructions for setup including adjusting your monitor. There is even a section troubleshooting and a self-test. Good Luck.
    Dec 12, 2008 | Samsung SyncMaster 910MP 19" LCD Monitor
    CRT monitor's background colour is changed to dull yellow colour
    hello,
    i think this problem accure due to chage of CRT CATHODE. if you are not a hardware engineer then check it from hardware engineer. any crt monotor have 3 RGB Cathode to release electron on screen. the electron comes shodow mask and create a pixel on the screen the pixel make a picture. The RGB color make the perfect picture. if your picture is dull then i think that happen due to less negative chage of Cathode or any Crt base Bios ic is failior. so you have to checked it from hardware engineer.
    ok
    bye
    Oct 22, 2008 | Samsung 21" FLAT CRT COLOR MONITOR
    Dell E193FP Problem
    Probably a failing power supply
    Apr 17, 2017 | Dell E193FP 19" Flat Panel LCD Monitor
    Color problem MAG Innovision 14" monitor
    1. try to connect to another computer . if it is fairly good then it must be your computer is having a problem.may be your video card problem.
    Mar 21, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
    Compaq Presario 5000 PC Desktop Logo
    585 people viewed this question
    Top Compaq Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Alun Cox
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
