Question about Car Audio & Video
JAMMED IN DASH CD PLAYER
2005 EQUINOX WITH AN 5 DISK CD PLAYER IN THE DASH THAT IS JAMMED. HOW DO I GET THE DISKS OUT OF THE PLAYER.
  • murph7386 May 28, 2008
    2005 Equinox 6 disc cd changer - given a cd error on the dash. pulled the fuses and nothing radio works fine just cant get the cd's to eject any help?
  • Lavon
    Lavon Jan 17, 2009
    I am having the same problem!! Did you repair yours? Please share!
Try taking out the fuse to let the cd player reset itself. It worked for me.
Posted on Feb 20, 2008
Cd player not reading cd
Did you try to play severak disks? If can't play any, it is defective. Sometimes can be cleaned with CD cleaning tor repaired.
Apr 29, 2015 | 2005 Infiniti G35
What is the proben with an RBQ car disk player that came with a 2005 Jeep Liberty that wont load or eject the disks on a 6 disk player load or eject the disks?
check fuses
if good fuses, the deck is bad.
upgrade time. go diskless like all us.
we use flash USB sticks.
discs are dead. end of life and era. and weak tech.
i have 4000 songs on a stick , no CD no DVDs. zero.
buy any cheap media head end player and install it.
Aug 19, 2014 | 2005 Jeep Liberty
CD will not come out of player
Get cople screw drivers remove it and open it up. What type of player it. If multiple disk player be Carefull you could crack the casing. Try ejecting while pulling cd out like playing with it. Good luck.
Nov 23, 2010 | 2005 Chevrolet Equinox
I have a cd stuck in the cd player. help.......2005 vw beetle
grab some hemostats and probe the middle of the slot for the cd's edge. Clamp and pull.
The only option other than reaching in a grabbing the disk would be to remove the entire middle dash panel by systematically removing all bolts, removing the cd player, opening the top of the unit and "plucking" the disk out, only thing is you are likely to continue having this problem unless the unit is replaced or you found something obstructing the disks path the you where able to remove.
Feb 22, 2010 | 2006 Volkswagen New Beetle
Equinox cd player
Check your owners manual and original paperwork for the code to your radio.
Aug 15, 2009 | 2005 Chevrolet Equinox
Speakers thumping and crackling even when turned off ,varies
im not knowledgable about car audio systems, but i would check to make sure your deck/changer is clean. it takes very little debris getting into your changer/deck to foul cd deck mechanisms. if you dont regularly check the surfaces of your disks for prints/smudges/exc.. you can easily foul the deck by repeated insertion of dirty disks. it could be that an internal motor is weak, a tiny drive belt could be sheared, or a gear inside has broken teeth. the lens that reads the disk information (instances that the disk did load) can be fouled leading to messages on your deck face. both problems you mention , to me, seem to point to fouled internal mechanisms. if you have kids, they can do awful things to your car when you are not around. im a parent and i know lol. the only thing i know to suggest to you to slove these problems is if it is after market deck, you may need to remove it and take it to a repair facility because most cd decks at least the ones ive had arent shade tree mechanic friendly. if the deck is your factory installed, check your car owners manual for information. lastly, if it were me, i would use a multi-meter and check for proper voltage at the wire terminals. good luck!
Jan 15, 2009 | 2005 Chevrolet Equinox
NO DISK message
There is nothing an end user can do to fix this unit except to try and run a lens cleaning disc thru it. If cleaning the lens helps, you have just dodged a bullet. It says "no disc" because the laser pick up can't see, it is blind. It can't read any disc's so it says "no disc" even if there is one in it. I work at a Panasonic authorized service center and have repaired this exact model many times. The repair will cost about $125 or more to replace the laser. This is due to the high cost of the laser pick up.
Unless this is under the warranty, you really should just get a new one. This model of Panasonic normally has an issue with the trays getting jammed and are a technicians nightmare to repair. So, I don't really like to see them in my shop. It was a very bad design for Panasonic, they have had more trouble with the cd mech in this model than any other cd mech I have seen for them in the last 17 years I have been repairing them.
I am sorry to give such bad news, but it really is true. If I can be any further help, please feel free to let me know.
Dave
Jul 07, 2008 | Panasonic SC-PM19 CD Shelf System
CD jammed in player
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent. regards Mark www.carradiospares.co.uk
Aug 05, 2006 | Alpine CHM-S630 6-Disc CD Changer
Car Audio & Video Logo
267 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
