Question about Kitchen Ranges
I have a GE electric double wall oven. The lower oven works well. However, the upper oven is not heating properly. In fact, the elements weren't heating at all until I removed the thermostat knob and chipped off a hard substance from the screw area on the oven. I don't know what it was. So now the elements are heating, just not like they are so suppose to. GE Model #JKP27G, Serial #607205G.
  • 1 more comment
  • PeepAnne Nov 18, 2009
    Thanks! I forgot to mention that the elements are new. They were replaced when we initially noticed the problem (2 years ago). In fact, we had the old ones tested and they were ok. A repairman came out and told us that we needed to replace the entire control panel. But it would be hard to find. I found the control panel in stock at partselect.com. So, do you think the problem might be the thermostat control or the entire control panel? By the way, do you have any idea what the substance was I had to chip away? PeepAnne
    Sorry, one more comment. I know we did not wrap any white fiber glass tape around the terminals. Would that make a difference?
    Thanks for the solution and the quick response!
    Top Expert:
  • Kitchen Ranges Master
  • 76,164 Answers
U are going to need to replace the thermostatic control for the upper oven and the heating element as well, most likely the heating element is going out and has damaged the thermostat, the connections sound like they were burnt or heat damaged, this always requires a new part, any local appliance parts store can supply these parts or order them for you.here are te general instructions on how to replace the ovens heating element.
Instructions Things You'll Need:
  • Screwdriver
  • New bake element
  • Electric tape
  • Fiberglass tape
  • Flashlight
  1. Step 1 The first step when it comes to working on your electric oven, is to turn the breaker OFF! This is extremely important, because most electric ovens require 3-phase, 220-volt electricity to operate, and that voltage won't only hit you hard, it can kill you.
    Place a sign on your breaker panel stating that you are working on the electric.
  2. Step 2 Remove all of the racks from the inside of the oven. If it makes it more comfortable, you can even remove the oven door by opening it and sliding it off of the "arms" which hold it in place.
  3. Step 3 Locate the bake element. It resembles a metal tube that's been bent into a square shape and it is located on the bottom of the oven's interior.
    Be sure that the oven has not been used in a while and that the element is completely cool.
  4. Step 4 It can be quite dark inside the oven, so grab your flashlight and shine it to the rear of the oven's interior to locate where the bake element is connected to the oven wall.
  5. Step 5 There will be two screws holding the bake element in place. Remove the two screws and place them somewhere where you will not lose them.
    Now, pull the bake element out of the oven wall. There will be wires attached to each "leg" of the bake element.
    Note: There is usually not much wire to work with, so do not pull too hard. Once you have about 4 or 5 inches of wire exposed, place a piece of black electric tape over the wire at the point where it enters the oven. This will help keep the wire from falling back inside the hole.
  6. Step 6 At the point where the wires are connected to the bake element, you should see a screw. Remove the screws and separate the wires from the bake element. Throw out the old bake element.
  7. Step 7 Connect the wires to the new bake element the same way as you removed the old one, connecting one wire to each leg of the element with the screws. Wrap a layer of white fiberglass tape around the terminals.
    Next, push the wires back through the holes in the rear of the oven until the bake element is back in position. Use the screws to secure the new element in place.
  8. Step 8 Replace the oven door if you removed it earlier and turn the breaker back on. Turn the oven on and you should see your bake element flare up.
    You may notice some smoke coming off of the element as it heats up for the first time. This is OK, as these are just oils burning off of it. The smoke will stop in a few seconds.
  9. Step 9 That's all there is to it! Let the oven cool back down and replace the oven racks.
Posted on Nov 18, 2009
  • yadayada
    yadayada Nov 18, 2009
    the fiber glass tape is resistant to heat for obvious reasons, u should wrap the connections with it if there is any poss of them touching metal parts nearby, otherwise it should be ok. Never use regular electrical tape to the fact it is flammable.
  • yadayada
    if the thermstatic control is seperate from the the control panel then just try replacing the thermostat that goes into the oven, but of course it can be either part casuing the problem, but would go with the T-stat 1st.
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Clean between the glass on double wall oven
Unscrew the handle and screws at the bottom. Carefully separate the outer panel from the frame
Apr 09, 2014 | Frigidaire FPET2785KF Professional Series...
Hotpoint 24in double electric wall oven 20RJ83D not heating, element is working
The thermostat for the upper element has gone bad. Needs to be replaced.
Apr 15, 2017 | Ovens
Maytag electric oven model cwe5800acb. The lower element in the upper oven will not heat up. Can the lower element be replaced without removing the oven from the wall.
Yes, replace the lower element by first turning off the circuit breaker to the oven (110V is still to half of the 220V element circuit even though the oven setting is turned off), then unscrew the two screws holding the element to the back wall of the oven, then pull the element out (may have to tug it a bit to get the connectors through the insulation), and pull the wire connector clips off the element.
Mar 14, 2011 | Maytag CWE5800A Electric Double Oven
GE Profile JTP85 (installed 1998). The lower heat element in the lower oven will not heat. I can make the upper element heat up by using the BROIL function, but neither element gets warm on BAKE.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Dec 11, 2010 | GE JTP85 Electric Double Oven
In the upper oven, the lower heating element started sparking when turned on, and now it looks like it has a 'bubbled' area (about inch long) on it and it looks bent on one area. I guess I need to...
Hi, Yes, that element is toast...
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
heatman101
Sep 20, 2010 | GE JKP27 Electric Double Oven
Oven not heating up properly
You could very well have an electrical problem. You may not be getting the full 220 volts needed to make the oven function correctly. Call a local appliance technician or electrician for service.
Dec 28, 2006 | GE Profile JTP56 Electric Double Oven
Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Nov 17, 2006 | GE Profile JTP56 Electric Double Oven
GE electric double oven
Colin, the TCO is located on the back of the oven. It will open L2 to the heating element in the event it is open. If this TC0 opens it will not show any error codes. This is for the 27 inch wall oven models only. Catriver...post back.
Nov 09, 2006 | GE JTP48 Electric Double Oven
Kitchen Ranges Logo
50 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
