Question about Hotpoint Dryers
My door for a hotpoint ctd40 tumble drier wont stay closed. The spring latch seems ok but not holding dooe closed. Any ideas since it dont say anything in my manual about it and its 2 yrs old. cheers andy
    Scholar:
  • 62 Answers
Hi andy.
the fault is likely to be in the roller catch mechanism. Hotpoint have modified these. Part Number is C00257618.
It includes both door latch and catch.
If you have problems obtaining one please email me on: aardvark.repairs@btinternet.com or call me on 01733 307019
Regards
aardvark repairs
Posted on Nov 18, 2009
Door will not stay close
Not much data to go on here. The latch on the door has a spring that holds it down in the locked position. when you pull the handle the latch goes up and you pull the door open. You will have to take the door apart and see if the spring broke or the plastic tab that holds the end of the spring is broken.
Feb 25, 2015 | Maytag Appliances Over-the-Range Microwave...
My dishwasher door wont shut
see this causes, and use the common sense. God bless you
When your dishwasher door has a problem, check these: Latch Springs Hinges Door seal Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch. Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs. Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough. Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 19, 2012 | Hotpoint 24 in. FDW60 Free-standing...
Hi I've Got A Hotpoint Aquarius CTD40 Tumble Dryer
that isn't a model number,open the door to the dryer,look around the opening where you put the clothes in and send the full model number,
Dec 21, 2017 | Hotpoint Dryers
Driver door wont close- latch on door is jammed
The claw on the latch is probably just latched without the striker being in it. Try holding one of the door handles in the open position and use your finger to rotate the latch to the open position then release the handle and see if it will shut. Hope that helps
Feb 02, 2011 | 2000 GMC Jimmy
Door will not stay closed unless latched. spring
Adlust the level on the fridge so that the hinged side is slightly higheer than latch side. They reley on gravity to stay closed.
Dec 24, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Hotpoint ctd40 t dryer. wont start just ticking.
do you hear anything running?,might have broken the belt or idler wheel,motor runs but no tumble,need to look inside,warning !! unplug ,high voltage.be carefull
Sep 22, 2009 | Dryers
The door on my tumble drier wont stay shut. The drier runs if I hold it shut. I have checked the peg and the door and cannot see anything wrong with them?
Buy a new door latch kit aprox $5.00. When you install these parts make sure the latch and the peg are lined up in the same direction
Aug 04, 2009 | Hotpoint Dryers
Hotpoint aquarius tumble dryer, drum not going round but still
If you can hear the motor going, then the belt probably needs replacing, if no motor action, then prob is more serious.
Please rate my solution.
Thanks.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Dryers Logo
436 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
