Question about Sony Playstation 3 (PS3) Console
No pic or sound just blue screen hdmi cable worked before wont work now have tried switching cables holding down power button waiting for beeps nothing changes even tried holding down button and switching power back on
SOURCE: Playstation 3 Does not display on TV using HDMI or regular video
I posted to your problem with a similar one. I was able to get my PS3 to work by:
1.) Powering down both the PS3 and ViewSonic LCD
2.) Unplugging the power cables to both PS3 and LCD
3.) Waiting at least 10 or more seconds
4.) Plugging in the power cables to both PS3 and LCD
5.) Turning on the ViewSonic LCD
6.) Turning on the PS3 and holding down the power button until the beep
After this sequence I heard the bootup audio and the menu appeared on the screen- which detected the HDMI connection to my LCD.
Very odd.. I've had my PS3 in the same place for months and just today this happened.
I wanted to post my success. Best of luck!
Seth
Posted on Jan 12, 2009
Agonyscreams
  • 63 Answers
SOURCE: All of a sudden, no sound on PS3, great pic
I agree with the guy from Sony, the reason for this is the HDMI cable should support the transfer of audio and video over the same cable, if your only getting video over it, the cable could be defective, or its possible that you have another cable in the spot where speakers should go that is over riding the HDMI.
What exactly is the HDMI cable plugged into? Is it direct from TV to PS3?
If you have a stereo set lying around that supports HDMI - try having it run through that.
Is the TV muted? check if you can get sound while watching normal TV channels.
Worst comes to worst, use RCA Plugs remembering that the composite video is (yellow) and stereo audio is (white and red). You don't need to connect the composite video, but connect the stereo audio.
If this did not solve the problem, please leave a comment and I'll get back to you once I can =)
Posted on Jul 17, 2009
  • 23 Answers
SOURCE: unable to solve Blank screen
hmm confusing but try turning your ps3 off at the wall give it 5mins and try again if nothing happens try it on another tv
Posted on Sep 25, 2009
JEFerrer
  • 87 Answers
SOURCE: I have a HDMI problem with my PS3. I have it
Try entering Recovery Mode and choose "Restore Default Settings".
If that doesn't help, you may have an HDMI port failure - which will require returning the unit to Sony or sending it to a third-party PS3 repair shop.
Posted on Mar 30, 2010
hankjones65
  • 38 Answers
You will need to turn on the PS3 and hook it up with rca so you can access the console menus. Turn it on and get to the main dashboard. 1. Go to Settings -> Display Settings (not video) 2. Select [ Video Output Settings ] 3. Select HDMI 4. Select Resolution 5. Select Screen Size 6. Save the settings 7. Reboot the console. This should resolve the problem. We've seen PS3 consoles that would not reset by performing a hard reset. We were able to resolve this issue through the settings menu though. Let me know if it is still giving you issues.Hank GATpro Repairs
Posted on Jun 14, 2010
Mitsubishi wd-60737 HDMI port 1 connected to cablebox. Screen is black and no sound. Cablebox is on, all cables connnected correctly and was previously working. Nothing new was done.
have you tried resetting your cable box? you can do this usually by either holding its power button in until all 3 lights light up, or by unplugging it from power , wait @ 30 seconds & plug back in .
Feb 07, 2015 | Mitsubishi Televison & Video
My ps3 console signal isn't working but the sound works but there is no signal! not even a hdmi cable works help!
Try these tips to fix the so-called "black screen of death".
Tip 1: The main reason of HDMI black screen problem due to HDMI cable may be damaged and not properly connected to the PS3 console. Please follow below step to troubleshoot PS3 HDMI cables problem:
1) Restart your PlayStation 3.
2) Look for loose cables.
3) Try to unplug all cables except the power cord, and plug them back in. If you found out that your HDMI cable is damaged, borrow a friends cable and try it. If your friends cable works fine, and the black screen error disappears. Then you can buy a brand new HDMI cable for a replacement.
Tip 2: Only try as last resort. There is a possibility you'll lose all data on your PS3's hard drive. If tip 1 didn't work, you will need to go a step deeper and reset your console. Most PS3 gamers are not aware that Sony actually included a black screen of death troubleshooting method and other HDMI problems in the PS3 manual, you can find it under the troubleshooting section - topic "console reset".
If you do it correctly, the console reset fix will allow you to reset back your PS3 to its default HDMI settings without impacting your gamer profile, and other storage data on the hard drive.
You will need to perform the following steps:
1. Place your PS3 in stand-by mode.
2. Hold down the touch power button until a series of beeps are heard.
3. Listen for one long beep, followed by two shorter beeps.
4. Release the power button.
5. Follow the instructions on screen.
If it works you should be good to go.
May 20, 2012 | Sony Playstation 3 (PS3) Console
PS3 shows a blank screen when I use the RCA jacks but works well when watching DVD movies when using a HDMI cable. When using the HDMI cable the sound is distorted whe I insert a game disk
Well heres the problem when you set your ps3 to be on 1080p using a hdmi cable the rca jacks wont work. to reset it power down the console. Then hold your finger on the power button you will hear it beep twice i believe rca jacks should be working now you will have to do that everytime unless you change it with hdmi cable plugged in to where you can see.
Jun 06, 2011 | Sony Playstation 3 (PS3) Console
I have a black screen when I connect the HDMI cable. When I connected it originally it worked for about 5 minutes but now I get nothing but the black screen. I tried connecting a different HDMI cable to it...
The main reason of HDMI black screen problem due to HDMI cable may damage and not proper connected to the PS3 console. Please follow below step to troubleshoot PS3 HDMI cables problem:1) Restart your PlayStation 3.
3) Try to unplug all cables except the power cord, and plug them back in. If you found out that your HDMI cable is damage, do borrow your friend cable and have a try. If your friend cable work fine, and the black screen error disappear. Then you can buy a brand new HDMI cable for replacement.
Tips 2: If tips 1 not working, you need to go another step deeper by reset your console. Most of the PS3 gamers not aware that Sony actually done include in the black screen troubleshooting method and other HDMI problems in the PS3 manual, you can find it under troubleshooting section - topic "console reset".
If you do it correctly, the console reset fix will allow you to reset back your PS3 to its default HDMI settings without impacting your gamer profile, and other storage data in hard drive.
3. Listen for one long beep, followed to two shorter beeps.
Jan 11, 2011 | Sony Playstation 3 (PS3) Console
My plastation 3 works when i hook it up through the hdmi cable but not the regular cables that come with the consol. is there a setting i need to change?the cables are not broken nor are the hookups on my...
Ok, you need to reset the PS3 back to standard video settings by doing the following :
Step 1. Turn the PS3 off into standby mode (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later. Release the power button when you hear this second beep.
Step 3. Wait for the display to initialize.
Hope this helps
Nov 25, 2010 | Sony Playstation 3 (PS3) Console
Hdmi cable works but the av scart cable tht I got with the PS3 wont work now and it was working the other day ever since I put the hdmi lead in can you help thx
This is a typical problem with the PS3 after you hook it up to your tv with an HDMI cable. You will have to reset your PS3 to get it to work with just the a/v cable. To do this, turn off the PS3, unplug the PS3, wait a minute or so and then plug it back in, press and hold the power button until you hear 4 beeps (1-1-2), You may have to power cycle the PS3 a couple of times or more for it to do the 4 beeps. After the 4th beep take your finger off the power button and follow the directions and prompts on screen. This could erase all of your saved data when you do this. Please leave feedback and a rating vote on the info I've provided.
Jul 02, 2010 | Sony Playstation 3 (PS3) Console
My Mitsubishi WD-62627 has no pic/sound w/ PS3
you just have to keep switching the back button off and when u turn it back on hold the front power button till you get 2 beeps
Apr 18, 2010 | Sony Playstation 3 (PS3) Console
PS3 Problem... I turned on my ps3 but nothing shows up on the television screen and controls wont even detect... PS3 shows that it is receiving power because the power light on ps3 is green. Can someone...
Turn the power off on the switch on the back, and then back on again. Hold down the power button, keep on holding it down after the first beep, but let go once another couple of beeps sound. It should then take at max a minute but then it should show a screen set up section.
Apr 09, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont start up
send it back under warranty,
The power supply may be faulty.
Feb 18, 2008 | Sony Playstation 3 (PS3) Console
It POWERS ON BUT HAS NO PICTURE,
Okay, I am now going through all the unsolved problems for which previously I had the same problems and now posting our solution. First, if you have no pic due to swiching of the cables (ie, cable av, hdmi) WHENEVER you switch your cable output, the ps3 also switches it's output. Make sure when there is no picture due to this problem to turn off the game console, then turn on, hold down the power button for approx. 5 SECs, there will be a BEEP. Let go of power button, the ps3 has then switched back to the output it is currently plugged in and will work. (ALSO sometimes you have to have ONLY the ps3 and tv hooked up) Hope this helped. I know how stressful this can be!
Nov 22, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
74 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
