Question about Xerox 8400B Phaser Color Laser Printer
Ink sticks jammed - Xerox 8400B Phaser Color Laser Printer
    Guru:
  • 110 Answers
This error is cause by 3rd party ink, installing peaces of ink sticks instead of whole ink sticks or installing wrong ink sticks. Another thing that can cause this error is a sensor on the inkloader, which can brake or is not connected properly. So what you can do is take of the inkloader then make sure there is no ink peaces in the inkloader shaft. With a small thin flathead screw driver you can brake peace of ink that are stuck inside the inkloader carefully without damaging the inkloader of course. Then put it back in it's place and make sure all connections are good and no wires are ripped. If they are ripped you have to buy a new inkloader. Install only new OEM ink sticks and good luck. Below I have written the website and the illustration number so you can search the manuel on how to remove the top inkloader.
https://www.office.xerox.com/partners/products/Phaser8400/SQRG/8400_85XX_Service_Manual.pdf
Ink Loader (PL1.0.8) <--copy past on search bar.
Posted on Nov 18, 2009
Testimonial: "It worked! Thank you!!"
Xerox Phaser 8860 error 09,005.40:71198
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1877-778-8@9@6@9 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Oct 30, 2014 | Xerox Phaser® 8860/8860MFP Extended...
My Xerox 8550 says 'ink sticks are jammed'. Yet,
This could be a print head problem. If the print head is calling for ink and the sensor is bad the ink melter will continue to melt ink and over flow the print head. In which case the print head need to be replaced.
Also it could be a problem with the ink melter. If it isn't melting the ink it will cause this error.
To get to the ones at the end of the chute I stick a long screwdriver and break it free from the melter.
Harry
Jun 04, 2010 | Xerox Phaser 8560MFP Laser Printer
Error code 09038.46:72241
That code is a back stick count failure.
You want to look in your ink loader, see if there is a stick jammed, twisted, broken or in anyother way out of place or hung up in the slot.
Be sure you loaded a 8550 stick also, since the shapes on the different phaser printer sticks are all different.
You may have to carefully remove the black sticks and reload them. You can take a screw and screw it into the ink stick, slide it back and remove.
Most likely you will find a gap in the ink sticks causing the problem. Here are the Xerox support page instructions.
  1. Open and close the Top Cover to resolve the problem.
  2. If the problem persists, arrange the ink sticks until there are no spaces between sticks of the same color.
  3. Check for non 8500/8550 ink sticks jammed in the ink load chutes. If non 8500/8550 ink sticks, whether manufactured by Xerox or by a non-Xerox ink vendor, caused the ink sick jam, contact support to place a service call.
Mar 09, 2010 | Xerox Phaser 8560MFP Laser Printer
Ink not being removed from metal drum, causing jam
Normally indicates that the mintenance kit is drying out and not properly lubricating the drum.
Or non xerox ink sticks have been known to cause that.
Jul 14, 2009 | Xerox Phaser 8400N Thermal Printer
Phaser 8560 Error Code 09,005.40.5185
Hi mark711:
Here is you problem.
9,005.49: Ink loader fault. The cyan ink melt heater is on, but the ink does not
appear to be dripping.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Are the ink sticks all Xerox ink? Go to
Step 2.
Advise
customer. Run
clearISCfault
test to clear the
error.
2 1. Manually verify that the ink stick is able to
advance in the ink loader chute.
Go to
Step 3.
Remove any
blockage and/
or replace the
ink stick.Run
clearISCfault
test to clear the
error.
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace
the
printhead.
Replace the ink
loader
assembly. Run
clearISCfault
test to clear the error.
Hope this helps
Apr 23, 2009 | Xerox Phaser 8500/DN Printer
ERROR PROBLEM
Do not use the ink sticks if they have a hairline crack in them. They eventually crack and jam the printer. So far I've only noticed this with the black ink sticks. 5a7294b.jpg
Jan 21, 2009 | Xerox Phaser 8500/DN Printer
Error messge xerox Pahser 8200 09.007.42:11683
The yellow ink sticks are jammed.
Open the ink loader and ensure that the yellow ink sticks are able to slide in the ink loading chute. Remove any broken of partial ink sticks.
Dec 07, 2008 | Xerox Phaser 8200 Laser Printer
XEROX 8550 DP ERROR
when are you getting this error message?
Oct 28, 2008 | Xerox Phaser 8550DX Laser Printer
Phaser 8200 printer error service report 09.008.43797s
The black ink sticks are jammed.
Open the ink loader and ensure that the black ink sticks are able to slide in the ink loading chute. Remove any broken of partial ink sticks.
One of your black sticks is not advancing properly.
Make sure one isnt cracked or twisted. If you happened to have put in a stick for a different phaser model, it may not be the same shape and would not hut the actuator at the bottom of the ink loader.
Raise your cover where you add your ink sticks and look at the black sticks. One is stuck somehow.
If you need to remove them, take a screw, a drywall type screw is best, and twist it into the ink block and slide it up and out, then reload the ink loader with good sticks. That shoulf do it. I ihave never witnessed the ink loader itself be the problem.
Sep 15, 2008 | Xerox Office Equipment & Supplies
Error Code 09,038.46:103468 help!
Mar 20, 2008 | Xerox Phaser 8550DX Laser Printer
Xerox 8400B Phaser Color Laser Printer  Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
